How do I enable the fingerprint sensor?
Hey there
I just installed Garuda on my new Thinkpad E14. I’m not sure how I’m supposed to enable the fingerprint sensor for unlocking.
fprintd, and libfprint are already installed. I’m fairly new to using Arch. I’d appreciate any help.
Kernel: 6.6.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: hpet available: acpi_pm
root=UUID=c877fe9c-cef9-4c56-9812-62dcfec9364d rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_wayland vt: 1
Type: Laptop System: LENOVO product: 21JRS00U00 v: ThinkPad E14 Gen 5
Mobo: LENOVO model: 21JRS00U00 v: ThinkPad serial: <superuser required>
UEFI: LENOVO v: R2CET32W (1.14) date: 11/27/2023
ID-1: BAT0 charge: 19.6 Wh (41.1%) condition: 47.7/47.0 Wh (101.5%)
power: 14.2 W volts: 11.2 min: 11.3 model: Sunwoda L22D3PG4 type: Li-poly
serial: <filter> status: discharging cycles: 3
Info: model: AMD Ryzen 5 7530U with Radeon Graphics bits: 64 type: MT MCP
microcode: 0xA50000D
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 566 high: 1397 min/max: 400/4546 scaling:
4: 1397 5: 1397 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400
bogomips: 47909
Device-1: AMD Barcelo vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5
lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:15e7
class-ID: 0300 temp: 50.0 C
Device-2: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 04f2:b7ba
Monitor-1: eDP-1 res: 1536x960 size: N/A modes: N/A
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.3.2-arch1.2
renoir LLVM 16.0.6 DRM 3.54 6.6.9-zen1-1-zen) device-ID: 1002:15e7
memory: 1000 MiB unified: no display-ID: :1.0
API: Vulkan v: 1.3.274 layers: 3 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 23.3.2-arch1.2
device-ID: 1002:15e7 surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 23.3.2-arch1.2 (LLVM 16.0.6) device-ID: 10005:0000
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x, snd_pci_acp5x,
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh pcie:
gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.6.9-zen1-1-zen status: kernel-api tools: N/A
port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8852BE PCIe 802.11ax Wireless Network vendor: Lenovo
driver: rtw89_8852be v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:b852 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:3 chip-ID: 0bda:4853
lmp-v: 12 status: discoverable: no pairing: no class-ID: 7c010c
Local Storage: total: 476.94 GiB used: 12.43 GiB (2.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WD PC
SN740 SDDQMQD-512G-1201 size: 476.94 GiB block-size: physical: 512 B
fw-rev: 73116101 temp: 32.9 C scheme: GPT
ID-1: / raw-size: 244.33 GiB size: 244.33 GiB (100.00%)
used: 12.4 GiB (5.1%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
used: 33.4 MiB (13.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 244.33 GiB size: 244.33 GiB (100.00%)
ID-4: /var/log raw-size: 244.33 GiB size: 244.33 GiB (100.00%)
ID-5: /var/tmp raw-size: 244.33 GiB size: 244.33 GiB (100.00%)
ID-1: swap-1 type: zram size: 14.46 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 58.0 C mobo: N/A gpu: amdgpu temp: 51.0 C
Fan Speeds (rpm): fan-1: 0 fan-2: 0
Processes: 311 Uptime: 1h 51m wakeups: 0 Memory: total: 16 GiB note: est.
available: 14.46 GiB used: 4.34 GiB (30.0%) Init: systemd v: 255
pm: pacman pkgs: 1332 libs: 400 tools: octopi,paru Shell: fish v: 3.7.0
Garuda (2.6.22-1):
System install date:     2024-01-06
Last full system update: 2024-01-06 ↻
lsusb output:
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 04f2:b7ba Chicony Electronics Co., Ltd Integrated Camera
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 002: ID 27c6:550a Shenzhen Goodix Technology Co.,Ltd. FingerPrint
Bus 003 Device 003: ID 0bda:4853 Realtek Semiconductor Corp. Bluetooth Radio
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Please always provide your garuda-inxi as required in the topic template.
Hello
I ran garuda-inxi on my terminal. It gave a long output of system specs, network, partition, graphics, etc.
Am I supposed to paste the whole thing? It’s quite long.
Yes, please, paste them here formatted
like this
Which becomes
like this
I edited the post. Is that sufficient?
We need all :slight_smile: , but arch wiki said for gen3
https://wiki.archlinux.org/title/Lenovo_ThinkPad_E14_Gen_3_(AMD)
no driver
Post also output from
lsusb
Done. Please check again.
Fingerprint reader 27c6:5503 No
Using other driver can brake the FPR
According to this, you could use this AUR package
https://aur.archlinux.org/packages/libfprint-2-tod1-goodix
But according to the comments it seems broken currently.
To install from AUR
paru package name
Exit from pkgbuild preview with q and confirm installation.
We can just hope they will fix It…
Uh, its Gen 5?
Proprietary driver for the Goodix fingerprint reader 27c6:550a, from Lenovo E14 Gen 4 Ubuntu driver.
Be careful :slight_smile:
I get the impression that I shouldn’t tamper with it or I’ll screw it up. I’ll just leave it as is for now until I see a fix there.
I hope I haven’t mixed anything up, the driver doesn’t write to the chip.
I need more coffee :smiley:
The ‘swoosh’ indicates you need to reboot since an update. Please do so now.
