How do i create a login script?
Hello Garuda users.
Kernel: 6.4.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=ca7a2840-ab48-4222-8dc0-3ec95e53603f rw rootflags=subvol=@
Type: Desktop Mobo: ASRock model: B450M Steel Legend
serial: <superuser required> UEFI: American Megatrends v: P3.60
date: 11/03/2020
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 2218 high: 2657 min/max: 2200/4208 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2202 2: 2110
3: 2200 4: 2657 5: 2189 6: 2195 7: 2199 8: 2200 9: 2122 10: 2199 11: 2200
12: 2143 bogomips: 86402
Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: Gigabyte
driver: nvidia v: 535.104.05 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-08) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 07:00.0 chip-ID: 10de:1c03 class-ID: 0300
Device-2: Microdia USB 2.0 Camera driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:5 chip-ID: 0c45:636b
Screen-1: 0 s-res: 3286x1080 s-dpi: 75 s-size: 1113x366mm (43.82x14.41")
s-diag: 1172mm (46.13")
Monitor-1: DP-1 pos: bottom-r res: 1366x768 hz: 60 dpi: 85
size: 410x230mm (16.14x9.06") diag: 470mm (18.51") modes: N/A
Monitor-2: HDMI-0 pos: primary,top-left res: 1920x1080 hz: 60 dpi: 102
size: 480x260mm (18.9x10.24") diag: 546mm (21.49") modes: N/A
Monitor-3: None-1-1 size-res: N/A modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 535.104.05 renderer: NVIDIA GeForce GTX 1060
6GB/PCIe/SSE2 direct-render: Yes
Device-1: NVIDIA GP106 High Definition Audio vendor: Gigabyte
bus-ID: 07:00.1 chip-ID: 10de:10f1 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
bus-ID: 09:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Microdia USB 2.0 Camera driver: snd-usb-audio,uvcvideo type: USB
Device-4: DCMT USB Condenser Microphone
lanes: 1 mode: 1.1 bus-ID: 3-4:2 chip-ID: 31b2:0011 class-ID: 0300
API: ALSA v: k6.4.12-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.78 status: active with: 1: pipewire-pulse
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: f000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp5s0 state: up speed: 10 Mbps duplex: full mac: <filter>
Device-2: TP-Link TL-WN821N v5/v6 [RTL8192EU] driver: rtl8xxxu type: USB
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:2 chip-ID: 2357:0107
IF: wlp2s0f0u2 state: down mac: <filter>
Local Storage: total: 5 TiB used: 1.34 TiB (26.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNV2S1000G
lanes: 4 tech: SSD serial: <filter> fw-rev: SBM02103 temp: 33.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
ID-3: /dev/sdb maj-min: 8:16 vendor: Toshiba model: HDWT840 size: 3.64 TiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s tech: HDD
rpm: 5400 serial: <filter> fw-rev: 1L scheme: GPT
ID-1: / raw-size: 930.66 GiB size: 930.66 GiB (100.00%)
used: 462.63 GiB (49.7%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-2: /boot/efi raw-size: 866 MiB size: 864.3 MiB (99.80%)
used: 576 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 930.66 GiB size: 930.66 GiB (100.00%)
ID-4: /var/log raw-size: 930.66 GiB size: 930.66 GiB (100.00%)
ID-5: /var/tmp raw-size: 930.66 GiB size: 930.66 GiB (100.00%)
System Temperatures: cpu: 56.8 C mobo: N/A gpu: nvidia temp: 49 C
Processes: 313 Uptime: 21m wakeups: 0 Memory: total: 16 GiB
available: 15.54 GiB used: 5.44 GiB (35.0%) Init: systemd v: 254
pm: pacman pkgs: 1317 libs: 349 tools: octopi,pamac,paru Shell: fish
v: 3.6.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.29
System install date:     2023-07-19
Last full system update: 2023-08-30
Im trying to make a bash script to mount my hdd on login because it takes to much time to do it on bootup. and after that it should open qbittorrnt could you guys give me a light on how to do it. for i have tried and failed.
Im very new to linux and don't know how to code yet.
https://wiki.archlinux.org/title/Fstab
https://wiki.archlinux.org/title/KDE#Autostart
there is no need to write a script, however the creating the partition information needed to insert into fstab will require information you can get at a command prompt. Do remember to use the UUID portion of the fstab wiki entry i posted above as that is what is currently recommended/used.
i have used fstab, i dont want to anymore, my boot takes a minute and a half because of my hdd, i want to mount it after boot
Nope, you may have a mistake inside, so fstab search and search and search :slight_smile:
Try
sudo pacman -S gnome-disk-utility
