when I open a few apps my laptop gets hot and the temperature up to 85 or higher and very high CPU usage
and sometimes open one app like Discord only or chrome only my laptop gets hot and the temperature up to 85 or higher and very high CPU usage
I want to fix the problem and reduce high CPU usage to avoid laptop gets hot
Check out this post:
This will help you in fixing your problem as you are using a laptop
I will try this Solution
Which application is using 100% CPU?
Find that out and you might then be able to
