Hey there,
I'm currently trying to get Hibernation/Hybrid-Sleep to work.
I can confirm, that this is/was working flawlessly, as I've used this for quite a while, but I've made the mistake to edit the service files directly, so when I recently updated, my changes got reverted, and now I can't get it to work anymore.
As for why I am not just using suspend: It recently kinda messed up pipewire and I had to restart my machine - And well that's kinda what suspend should be preventing, isn't it?
╰─λ cat /etc/systemd/system/systemd-hibernate.service.d/override.conf
File: /etc/systemd/system/systemd-hibernate.service.d/override.conf
Environment=SYSTEMD_BYPASS_HIBERNATION_MEMORY_CHECK=1
ProtectHome=read-only
╰─λ cat /etc/systemd/system/systemd-logind.service.d/override.conf
File: /etc/systemd/system/systemd-logind.service.d/override.conf
╰─λ cat /etc/systemd/system/systemd-suspend-then-hibernate.service.d/override.conf
File: /etc/systemd/system/systemd-suspend-then-hibernate.service.d/override.conf
What could I be doing wrong?
Thanks!
System: Kernel: 5.10.70-1-lts x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-lts root=UUID=2a555427-5d35-463f-8011-b023a855b928 rw
rootflags=subvol=@ loglevel=3 quiet splash lsm=lockdown,yama,apparmor,bpf
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 2 dm: Ly 0.5.3.r0.g4094d21
Machine: Type: Desktop System: Gigabyte product: AX370-Gaming 3 v: N/A serial: <filter>
Mobo: Gigabyte model: AX370-Gaming 3-CF v: x.x serial: <filter> UEFI-[Legacy]: American Megatrends v: F50a
date: 11/27/2019
CPU: Info: 6-Core model: AMD Ryzen 5 2600X bits: 64 type: MT MCP arch: Zen+ family: 17 (23) model-id: 8 stepping: 2
microcode: 800820D cache: L2: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 86226
Speed: 3985 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz): 1: 3985 2: 4171 3: 4141 4: 4143 5: 4125
6: 4119 7: 4098 8: 4124 9: 4101 10: 4115 11: 4167 12: 4141
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Baffin [Radeon RX 550 640SP / RX 560/560X] vendor: ASUSTeK
driver: amdgpu v: kernel bus-ID: 08:00.0 chip-ID: 1002:67ff class-ID: 0300
Device-2: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo bus-ID: 3-4:4 chip-ID: 046d:0825
Display: server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: amdgpu,ati unloaded: modesetting
Screen-1: 0 s-res: 3600x1200 s-dpi: 96 s-size: 952x317mm (37.5x12.5") s-diag: 1003mm (39.5")
Monitor-1: HDMI-A-0 res: 1680x1050 hz: 60 dpi: 90 size: 474x296mm (18.7x11.7") diag: 559mm (22")
Monitor-2: DVI-D-0 res: 1920x1200 hz: 60 dpi: 99 size: 495x310mm (19.5x12.2") diag: 584mm (23")
OpenGL: renderer: Radeon RX 560 Series (POLARIS11 DRM 3.40.0 5.10.70-1-lts LLVM 12.0.1) v: 4.6 Mesa 21.2.3
direct render: Yes
Audio: Device-1: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / RX 560/560X] vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 08:00.1 chip-ID: 1002:aae0 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel v: kernel
bus-ID: 0a:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: C-Media USB Microphone type: USB driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-2:3
chip-ID: 0d8c:9700 class-ID: 0300 serial: <filter>
Device-4: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo bus-ID: 3-4:4 chip-ID: 046d:0825
Sound Server-1: ALSA v: k5.10.70-1-lts running: yes
Sound Server-5: PipeWire v: 0.3.38 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte driver: r8169 v: kernel
port: f000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Drives: Local Storage: total: 2.96 TiB used: 1.46 TiB (49.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 4B6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 250GB size: 232.89 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 1B6Q scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital model: WD20EFRX-68EUZN0 size: 1.82 TiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 0A82 scheme: GPT
Partition: ID-1: / raw-size: 195.31 GiB size: 195.31 GiB (100.00%) used: 63.06 GiB (32.3%) fs: btrfs dev: /dev/sda2
maj-min: 8:2
ID-2: /home raw-size: 736.18 GiB size: 736.18 GiB (100.00%) used: 115.56 GiB (15.7%) fs: btrfs dev: /dev/sda3
maj-min: 8:3
ID-3: /var/log raw-size: 195.31 GiB size: 195.31 GiB (100.00%) used: 63.06 GiB (32.3%) fs: btrfs dev: /dev/sda2
maj-min: 8:2
ID-4: /var/tmp raw-size: 195.31 GiB size: 195.31 GiB (100.00%) used: 63.06 GiB (32.3%) fs: btrfs dev: /dev/sda2
maj-min: 8:2
ID-1: swap-1 type: zram size: 31.37 GiB used: 2 GiB (6.4%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 40.4 C mobo: N/A gpu: amdgpu temp: 35.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1420
Info: Processes: 438 Uptime: 8h 8m wakeups: 7 Memory: 31.37 GiB used: 7.61 GiB (24.3%) Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 2079 apt: 0 pacman: 2072 lib: 466 snap: 7
Shell: fish v: 3.3.1 running-in: yakuake inxi: 3.3.06
