Hi Guys I really need some help here I was doing this all wrong
as you see in my picture i did number 1
number 2 i got a messege i dont have the powerpill
but number 3 ad mirrorslist what list? and how?
ystem:
  Kernel: 6.1.11-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    root=UUID=0bcebc11-6ba9-4b23-8b4a-addbda934f51 rw rootflags=subvol=@
    loglevel=3 ibt=off
  Desktop: MATE v: 1.26.0 info: mate-panel wm: marco v: 1.26.1 vt: 7
    dm: LightDM v: 1.32.0 Distro: Garuda Linux base: Arch Linux
  Mobo: ASUSTeK model: PRIME Z490-A v: Rev 1.xx serial: <superuser required>
    UEFI: American Megatrends v: 2601 date: 05/17/2022
  Info: model: Intel Core i7-10700K bits: 64 type: MT MCP arch: Comet Lake
    model-id: 0xA5 (165) stepping: 5 microcode: 0xF4
    L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 3800 min/max: 800/5100 scaling: driver: intel_pstate
    governor: performance cores: 1: 3800 2: 3800 3: 3800 4: 3800 5: 3800 6: 3800
    7: 3800 8: 3800 9: 3800 10: 3800 11: 3800 12: 3800 13: 3800 14: 3800
    15: 3800 16: 3800 bogomips: 121596
    vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands
    ports: active: HDMI-A-1 empty: DP-1, DP-2, DVI-D-1, HDMI-A-2
    bus-ID: 01:00.0 chip-ID: 1002:67df class-ID: 0300 temp: 49.0 C
  Display: x11 server: X.Org v: 21.1.7 compositor: marco v: 1.26.1 driver:
    X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
    s-diag: 777mm (30.58")
  Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: AOC Q32G1WG4 serial: <filter>
    built: 2019 res: 2560x1440 dpi: 93 gamma: 1.2 size: 697x393mm (27.44x15.47")
    diag: 800mm (31.5") ratio: 16:9 modes: max: 2560x1440 min: 720x400
  API: OpenGL v: 4.6 Mesa 22.3.4 renderer: AMD Radeon RX 580 Series
    (polaris10 LLVM 15.0.7 DRM 3.49 6.1.11-zen1-1-zen) direct-render: Yes
  Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
    vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1
    chip-ID: 1002:aaf0 class-ID: 0403
  Sound API: ALSA v: k6.1.11-zen1-1-zen running: yes
    gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 04:00.0 chip-ID: 8086:15f3
  IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Local Storage: total: 3.18 TiB used: 1.1 TiB (34.6%)
    model: WDS250G2B0C-00PXH0 size: 232.89 GiB block-size: physical: 512 B
    rev: 211070WD temp: 35.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Samsung
    rev: 2B2QEXM7 temp: 43.9 C
  ID-3: /dev/sda maj-min: 8:0 vendor: Toshiba model: HDWD130 size: 2.73 TiB
    block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD
    rpm: 7200 serial: <filter> rev: ACF0 scheme: GPT
    used: 14.79 GiB (6.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
  System Temperatures: cpu: 42.0 C mobo: N/A gpu: amdgpu temp: 49.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 1192
  Processes: 355 Uptime: 31m wakeups: 0 Memory: 31.25 GiB
  used: 3.09 GiB (9.9%) Init: systemd v: 252 default: graphical
  pkgs: 1567 libs: 472 tools: gnome-software,octopi,pamac,paru pm: appimage
  pkgs: 0 pm: flatpak pkgs: 0 Shell: fish v: 3.6.0 running-in: mate-terminal
  inxi: 3.3.25
Garuda (2.6.14-1):
  System install date:     2023-02-13
  Last full system update: 2023-02-13
Why do you need to do that?
Chaotic-aur should be already configured in our systems.
thank you for saying that I was just following the steps in the WIKI
why do they still have these steps in the WIKI ?
Navigate to 'etc/' in Dolphin, then right click an empty space and click "open in terminal". Then type 'sudo nano pacman.conf' and it should open up the file that you need to edit.
Then you will add the below to the bottom of that file (assuming you don't have any addition third party repositories).
Ctrl+X to save and exit the file then you can do 'pacman -Su' to update the mirrorlist or just use 'garuda-update'. Sorry, on mobile otherwise I'd use better screenshots.
Because chaotic-aur can be used also in other distros.
Yes it should already be in there. I assumed you accidentally removed it.
@glomar_response
Thanks Bud but no
I got this Part
its the other part
It Doesn't matter any more but only if u guys knew how much i suffered from these steps before :frowning:
Why did you suffer? Chaotic is enabled by default on every Garuda distro, so you shouldn't have had to struggle at all since they were already there...
micro, Garuda use micro :wink:
pacman supports parallel downloads natively now, no need for powerpill.
Maybe someone can change the text on the chaotic web page (@dr460nf1r3 , @Technetium , @Naman (Web designer)) ?
Oops, my bad! My roots came from debian based, so I used nano for years. Will remember for future responses. :sweat_smile:
I Like nano :+1:
Prefer Nano.
Wait, really? I’ve never used Micro, and Nano seems to be the default for some things :thinking:
I’ve only ever used Nano and Vim in the console, lol
Nano is fine, I use it a long time.
Micro is even easier to use and probably included in all Garuda DE's except Xfce?
Why would you want to do Vi(M) for a small change in the / area.
But all have their justification in different areas.
You could extend the elitist Arch saying :slight_smile:
By the way, I use Arch and Vim! :wink:
Because we are already off topic here,
Sending text as an image is counterproductive (not copyable or searchable) and unnecessarily increases the memory, traffic and backups of the forum.
Even more comfortable would be here, open in terminal
sudo micro /etc/pacman.conf
add
[chaotic-aur]
Include = /etc/pacman.d/chaotic-mirrorlist
But life is not a wish concert :smiley:
On the other hand, we don’t want to raise any helper vampires by spoonfeeding them.
@Firas now I finally understand why I keep seeing this output in your inxi!
error: could not register 'chaotic-aur' database (database already registered)
