Hey, my GWE is not working when trying to open
when ran GWE in terminal getting the following error :-
  File "/usr/bin/gwe", line 53, in <module>
    from gwe import __main__
  File "/usr/lib/python3.11/site-packages/gwe/__main__.py", line 52, in <module>
    locale.setlocale(locale.LC_ALL, locale.getlocale())
  File "/usr/lib/python3.11/locale.py", line 626, in setlocale
    return _setlocale(category, locale)
locale.Error: unsupported locale setting
  Kernel: 6.5.7-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=139b286e-1f9b-4e26-9778-b50a5fff50a7 rw rootflags=subvol=@
  Desktop: GNOME v: 45.0 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM
    v: 45.0.1 Distro: Garuda Linux base: Arch Linux
  Type: Laptop System: LENOVO product: 81Y4 v: IdeaPad Gaming 3 15IMH05
    serial: <superuser required> Chassis: type: 10 v: IdeaPad Gaming 3 15IMH05
  Mobo: LENOVO model: LNVNB161216 v: SDK0Q55724 WIN
    serial: <superuser required> UEFI: LENOVO v: EGCN36WW date: 02/14/2022
  ID-1: BAT0 charge: 38.1 Wh (95.0%) condition: 40.1/45.0 Wh (89.1%)
    volts: 12.6 min: 11.4 model: SMP L19M3PF7 type: Li-poly serial: <filter>
    status: not charging cycles: 89
  Info: model: Intel Core i5-10300H bits: 64 type: MT MCP arch: Comet Lake
    model-id: 0xA5 (165) stepping: 2 microcode: 0xF8
    L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 851 high: 900 min/max: 800/4500 scaling:
    driver: intel_pstate governor: powersave cores: 1: 900 2: 900 3: 900 4: 800
    5: 800 6: 899 7: 810 8: 800 bogomips: 39999
  Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Lenovo driver: i915
    active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9bc4
  Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Lenovo
    driver: nvidia v: 535.113.01 alternate: nouveau,nvidia_drm non-free: 535.xx+
    status: current (as of 2023-09) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s
    lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0
    chip-ID: 10de:1f99 class-ID: 0300
  Device-3: Bison Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3 chip-ID: 5986:212b
    class-ID: 0e02
    compositor: gnome-shell driver: X: loaded: modesetting,nvidia
  Monitor-1: eDP-1 model: AU Optronics 0xd1ed built: 2019 res: 1920x1080
    hz: 120 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
    ratio: 16:9 modes: 1920x1080
  API: EGL v: 1.5 hw: drv: nvidia platforms: gbm: drv: nvidia
  API: OpenGL v: 4.6.0 compat-v: 4.6 vendor: intel mesa v: 23.2.1-arch1.2
    device-ID: 8086:9bc4 memory: 7.45 GiB unified: yes
  API: Vulkan v: 1.3.264 layers: 8 device: 0 type: integrated-gpu name: Intel
    UHD Graphics (CML GT2) driver: mesa intel v: 23.2.1-arch1.2
    device-ID: 8086:9bc4 surfaces: xcb,xlib device: 1 type: discrete-gpu
    name: NVIDIA GeForce GTX 1650 driver: nvidia v: 535.113.01
    device-ID: 10de:1f99 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
  Device-1: Intel Comet Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel
  Device-2: NVIDIA driver: snd_hda_intel v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10fa class-ID: 0403
  API: ALSA v: k6.5.7-zen2-1-zen status: kernel-api tools: N/A
  Server-1: PipeWire v: 0.3.82 status: active with: 1: pipewire-pulse
    port: 3000 bus-ID: 0c:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp12s0 state: down mac: <filter>
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:4 chip-ID: 8087:0026
  Local Storage: total: 476.94 GiB used: 46.74 GiB (9.8%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: MTFDHBA512QFD
    lanes: 4 tech: SSD serial: <filter> fw-rev: 0013P6LN temp: 47.9 C
  ID-1: / raw-size: 80 GiB size: 80 GiB (100.00%) used: 46.7 GiB (58.4%)
    used: 33.8 MiB (13.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 80 GiB size: 80 GiB (100.00%) used: 46.7 GiB (58.4%)
  ID-4: /var/log raw-size: 80 GiB size: 80 GiB (100.00%)
    used: 46.7 GiB (58.4%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
  ID-5: /var/tmp raw-size: 80 GiB size: 80 GiB (100.00%)
  ID-1: swap-1 type: zram size: 7.63 GiB used: 2.43 GiB (31.9%)
  System Temperatures: cpu: 69.0 C pch: 64.0 C mobo: N/A
  Processes: 333 Uptime: 3h 47m wakeups: 1329 Memory: total: 8 GiB
  available: 7.63 GiB used: 4.15 GiB (54.4%) Init: systemd v: 254
  default: graphical tool: systemctl Compilers: gcc: 13.2.1 Packages: 1400
  pm: pacman pkgs: 1377 libs: 466 tools: gnome-software,pamac,paru pm: flatpak
  pkgs: 23 Shell: fish v: 3.6.1 running-in: gnome-terminal inxi: 3.3.30
Garuda (2.6.17-1):
  System install date:     2023-10-14
  Last full system update: 2023-10-17 ↻
  Relevant software:       snapper tlp NetworkManager dracut nvidia-dkms
the garuda-inxi
green with envy is hardcoded to work with en-US locale only. So in your terminal do this,
set -x LC_ALL "en_US.UTF-8"
and then,
gwe
To launch green with envy. It will work.
