Help with updating
Hey guys newbie here. I can't seem to complete a update. Here's what I get in the terminal
[sudo] password for jason:
garuda is up to date
core is up to date
extra is up to date
garuda downloading...
core downloading...
extra downloading...
resolving dependencies...
warning: cannot resolve "plasma5-applets-betterinlineclock-git", a dependency of "garuda-dr460nized"
warning: cannot resolve "plasma5-wallpapers-blurredwallpaper", a dependency of "garuda-dr460nized"
:: The following package cannot be upgraded due to unresolvable dependencies:
garuda-dr460nized
:: Do you want to skip the above package for this upgrade? [y/N] N
:: unable to satisfy dependency 'plasma5-applets-betterinlineclock-git' required by garuda-dr460nized
:: unable to satisfy dependency 'plasma5-wallpapers-blurredwallpaper' required by garuda-dr460nized
Press enter to exit
inxi output
Kernel: 6.4.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=8c28b36c-2245-4905-8c1d-c96985d6b272 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.6 tk: Qt v: 5.15.10 info: plank wm: kwin_x11
vt: 2 dm: SDDM Distro: Garuda Linux base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: ROG STRIX B450-F GAMING II v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 4301
date: 03/04/2021
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 2 microcode: N/A
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 4500 min/max: 2200/5744 boost: disabled scaling:
driver: acpi-cpufreq governor: performance cores: 1: 4500 2: 4500 3: 4500
4: 4500 5: 4500 6: 4500 7: 4500 8: 4500 9: 4500 10: 4500 11: 4500 12: 4500
13: 4500 14: 4500 15: 4500 16: 4500 bogomips: 144001
vendor: XFX Speedster QICK 319 driver: amdgpu v: kernel arch: RDNA-2
speed: 16 GT/s lanes: 16 ports: active: DP-2,HDMI-A-1 empty: DP-1,DP-3
bus-ID: 0b:00.0 chip-ID: 1002:73df class-ID: 0300
s-diag: 1052mm (41.43")
Monitor-1: DP-2 mapped: DisplayPort-1 pos: right model: Samsung LC27G5xT
serial: <filter> built: 2021 res: 1920x1080 hz: 60 dpi: 82 gamma: 1.2
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: primary,left model: AOC 32G2WG8
serial: <filter> built: 2021 res: 1920x1080 dpi: 70 gamma: 1.2
size: 698x393mm (27.48x15.47") diag: 801mm (31.5") ratio: 16:9 modes:
API: OpenGL v: 4.6 Mesa 23.1.3 renderer: AMD Radeon RX 6700 XT (navi22
LLVM 15.0.7 DRM 3.52 6.4.2-zen1-1-zen) direct-render: Yes
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0b:00.1 chip-ID: 1002:ab28
bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Logitech G432 Gaming Headset
lanes: 1 mode: 1.1 bus-ID: 3-1:2 chip-ID: 046d:0a9c class-ID: 0300
API: ALSA v: k6.4.2-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.73 status: active with: 1: pipewire-pulse
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000
bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: NetGear A6210 driver: mt76x2u type: USB rev: 3.0 speed: 5 Gb/s
lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-3:2 chip-ID: 0846:9053 class-ID: 0000
IF: wlp1s0f0u3 state: down mac: <filter>
Local Storage: total: 2.84 TiB used: 93.92 GiB (3.2%)
model: WD10EZEX-00WN4A0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: GPT
model: WD20EURS-63S48Y0 size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B speed: 3.0 Gb/s tech: N/A serial: <filter> fw-rev: AB51
scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Kingston model: SV300S37A120G
tech: SSD serial: <filter> fw-rev: BBF2 scheme: GPT
ID-1: / raw-size: 111.49 GiB size: 111.49 GiB (100.00%)
used: 26.08 GiB (23.4%) fs: btrfs dev: /dev/sdc2 maj-min: 8:34
used: 576 KiB (0.2%) fs: vfat dev: /dev/sdc1 maj-min: 8:33
ID-3: /home raw-size: 111.49 GiB size: 111.49 GiB (100.00%)
ID-4: /var/log raw-size: 111.49 GiB size: 111.49 GiB (100.00%)
ID-5: /var/tmp raw-size: 111.49 GiB size: 111.49 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.24 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 41.0 C mobo: 34.0 C gpu: amdgpu temp: 48.0 C
mem: 50.0 C
Fan Speeds (RPM): cpu: 2872 case-1: 0 case-2: 0 case-3: 0 gpu: amdgpu
fan: 0
Power: 12v: 10.03 5v: N/A 3.3v: N/A vbat: 3.18 gpu: amdgpu watts: 27.00
Processes: 376 Uptime: 15m wakeups: 0 Memory: available: 31.24 GiB
used: 3.97 GiB (12.7%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: pacman pkgs: 1886
libs: 537 tools: octopi,pamac,paru,yay Shell: fish v: 3.6.1 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.27
System install date:     2023-07-07
Last full system update: 2023-07-08
Is partially upgraded:   Yes
It looks like you do not have the Chaotic AUR enabled. Did you remove it for some reason?
You can re-enable it by following the instructions here:
How to use it?
First, install the primary key - it can then be used to install our keyring and mirrorlist.
pacman-key --recv-key 3056513887B78AEB --keyserver keyserver.ubuntu.com
pacman-key --lsign-key 3056513887B78AEB
pacman -U 'https://cdn-mirror.chaotic.cx/chaotic-aur/chaotic-keyring.pkg.tar.zst' 'https://cdn-mirror.chaotic.cx/chaotic-aur/chaotic-mirrorlist.pkg.tar.zst'
Append (adding to the end of the file) to /etc/pacman.conf:
[chaotic-aur]
Include = /etc/pacman.d/chaotic-mirrorlist
That got it. Thank you so much :grin: I don't know how I messed that up. But I now I see that chaotic was missing because of something I did.
