Help with Dock settings - need
How to make the dock in garuda mokka opaque and dark? The settings in the pannel settings does not seem to work?
What’s the problem with not posting garuda-inxi?
It contains additional, useful information about the status of your system.
:warning: Missing information requested in the template may result in not receiving assistance
Here is my garuda-inxi
Kernel: 6.18.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=298b5af9-b210-4d8c-8af3-c5d81fec4a62 rw rootflags=subvol=@
quiet resume=UUID=3cd35f2f-c5e7-44da-9a91-509445c14bd3 loglevel=3
Desktop: KDE Plasma v: 6.5.5 tk: Qt v: N/A info: frameworks v: 6.22.0
wm: kwin_wayland with: krunner vt: 2 dm: SDDM Distro: Garuda
Type: Laptop System: Dell product: G7 7590 v: N/A
Mobo: Dell model: 0F7T8V v: A00 serial: <superuser required> part-nu: 08EB
uuid: <superuser required> Firmware: UEFI vendor: Dell v: 1.16.0
date: 07/29/2021
ID-1: BAT0 charge: 34.7 Wh (100%) condition: 34.7/60 Wh (57.9%) volts: 17.37
min: 15.2 model: SMP DELL JJPFK87 type: Li-poly serial: <filter> charging:
status: full control: start: 50% end: 90% type: adaptive
avail: adaptive,custom,fast,standard,trickle cycles: N/A
Speed (MHz): avg: 800 min/max: 800/4500 scaling: driver: intel_pstate
8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 62399
ports: active: eDP-1 empty: DP-2, DP-3, HDMI-A-2, HDMI-A-3 bus-ID: 00:02.0
chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2070 Mobile] vendor: Dell
driver: nvidia v: 590.48.01 alternate: nouveau,nvidia_drm
non-free: 550-580.xx+ status: current (as of 2025-11; EOL~2026-12-xx)
arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-2022 pcie:
gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s lanes: 16
ports: active: none empty: DP-1,HDMI-A-1 bus-ID: 01:00.0
chip-ID: 10de:1f10 class-ID: 0300
Device-3: Realtek Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:2 chip-ID: 0bda:565a
compositor: kwin_wayland driver: gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: ChiMei InnoLux 0x1521 built: 2020 res:
mode: 1920x1080 hz: 144 scale: 100% (1) dpi: 142 gamma: 1.2
modes: 1920x1080
inactive: device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 25.3.4-arch1.1
GT2) device-ID: 8086:3e9b memory: 30.42 GiB unified: yes display-ID: :0.0
API: Vulkan v: 1.4.335 layers: 8 device: 0 type: integrated-gpu name: Intel
UHD Graphics 630 (CFL GT2) driver: mesa intel v: 25.3.4-arch1.1
device-ID: 8086:3e9b surfaces: N/A device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 2070 with Max-Q Design driver: nvidia
v: 590.48.01 device-ID: 10de:1f10 surfaces: N/A device: 2 type: cpu
name: llvmpipe (LLVM 21.1.6 256 bits) driver: mesa llvmpipe
v: 25.3.4-arch1.1 (LLVM 21.1.6) device-ID: 10005:0000 surfaces: N/A
de: kscreen-console,kscreen-doctor gpu: nvidia-smi wl: wayland-info
Device-2: NVIDIA TU106 High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:10f9 class-ID: 0403
API: ALSA v: k6.18.7-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.4.10 status: active with: 1: pipewire-pulse
Device-1: Realtek vendor: Dell driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 3b:00.0 chip-ID: 10ec:2502
IF: enp59s0 state: down mac: <filter>
Device-2: Intel Wi-Fi 5 Wireless-AC 9x6x [Thunder Peak]
vendor: Rivet Networks driver: iwlwifi v: kernel pcie: gen: 2 speed: 5 GT/s
lanes: 1 bus-ID: 3c:00.0 chip-ID: 8086:2526 class-ID: 0280
IF: wlp60s0 state: up mac: <filter>
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5
v: 3.0 port: 5060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 1.82 TiB used: 14.23 GiB (0.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
tech: HDD rpm: 5400 serial: <filter> fw-rev: 02 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT1000MX500SSD4
ID-1: / raw-size: 896.95 GiB size: 896.95 GiB (100.00%)
used: 14.23 GiB (1.6%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 664 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 896.95 GiB size: 896.95 GiB (100.00%)
ID-4: /var/log raw-size: 896.95 GiB size: 896.95 GiB (100.00%)
ID-5: /var/tmp raw-size: 896.95 GiB size: 896.95 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.15 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 34.27 GiB used: 0 KiB (0.0%)
Src: /sys System Temperatures: cpu: 74.0 C pch: 54.0 C mobo: N/A
Power: 12v: N/A 5v: 5 3.3v: N/A vbat: N/A
Memory: total: 32 GiB available: 31.15 GiB used: 4.84 GiB (15.5%)
Processes: 338 Power: uptime: 5h 44m states: freeze,mem,disk
suspend: s2idle avail: deep wakeups: 3 fails: 1 hibernate: platform
avail: shutdown, reboot, suspend, test_resume image: 12.41 GiB
services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd
v: 259 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1223 libs: 319 tools: octopi,paru Compilers:
gcc: 15.2.1 Shell: Bash v: 5.3.9 default: fish v: 4.4.0 running-in: konsole
inxi: 3.3.40
Garuda (2.12.3-2):
System install date:     2026-02-04
Garuda release:          260115
Last full system update: 2026-02-05 ↻
Relevant software:       snapper NetworkManager dracut nvidia-utils nvidia-open-dkms garuda-hardware-profile-nvidia garuda-hardware-profile-standard
25/26 checks run in 1.53 seconds ⌛
Powered by garuda-health 🦅
--- INFO ---
