System: Kernel: 5.12.10-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=d1b781c9-dd11-4839-886b-14eb42466dec
systemd.unified_cgroup_hierarchy=1 resume=UUID=f047b58c-343e-45f9-af3f-24b0cf4095fd loglevel=3
Desktop: KDE Plasma 5.22.1 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: ASUSTeK product: ROG Strix G512LW_G512LW v: 1.0 serial: <filter>
Mobo: ASUSTeK model: G512LW v: 1.0 serial: <filter> UEFI: American Megatrends v: G512LW.311
date: 01/08/2021
Battery: ID-1: BAT0 charge: 56.9 Wh (100.0%) condition: 56.9/66.0 Wh (86.3%) volts: 15.7 min: 15.7
model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: Not charging cycles: 103
CPU: Info: 6-Core model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake family: 6
model-id: A5 (165) stepping: 2 microcode: EA cache: L2: 12 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 62399
Speed: 4600 MHz min/max: 800/5000 MHz Core speeds (MHz): 1: 4600 2: 4601 3: 4602 4: 4695
5: 4754 6: 3345 7: 4843 8: 4729 9: 4786 10: 4742 11: 4771 12: 4711
Graphics: Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: ASUSTeK driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2070 Mobile / Max-Q Refresh] vendor: ASUSTeK
driver: nvidia v: 465.31 alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1f14
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: modesetting,nvidia
Monitor-1: eDP-1-1 res: 1920x1080 hz: 240 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
OpenGL: renderer: NVIDIA GeForce RTX 2070/PCIe/SSE2 v: 4.6.0 NVIDIA 465.31 direct render: Yes
Audio: Device-1: Intel Comet Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0403
Sound Server-1: ALSA v: k5.12.10-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.30 running: yes
Network: Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel port: 5000 bus-ID: 00:14.3
chip-ID: 8086:06f0 class-ID: 0280
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8169
v: kernel port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-3: KYE Systems (Mouse Systems) GF3000F Ethernet Adapter type: USB
driver: hid-generic,usbhid bus-ID: 1-3:2 chip-ID: 0458:6001 class-ID: 0301
Bluetooth: Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 1-14:4 chip-ID: 8087:0026 class-ID: e001
Drives: Local Storage: total: 953.87 GiB used: 43.73 GiB (4.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW010T8 size: 953.87 GiB
block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD
serial: <filter> rev: 002C scheme: GPT
Partition: ID-1: / raw-size: 338.29 GiB size: 338.29 GiB (100.00%) used: 43.73 GiB (12.9%) fs: btrfs
dev: /dev/nvme0n1p6 maj-min: 259:6
ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%) used: 564 KiB (0.1%) fs: vfat
ID-3: /home raw-size: 338.29 GiB size: 338.29 GiB (100.00%) used: 43.73 GiB (12.9%) fs: btrfs
ID-4: /var/log raw-size: 338.29 GiB size: 338.29 GiB (100.00%) used: 43.73 GiB (12.9%)
fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
ID-5: /var/tmp raw-size: 338.29 GiB size: 338.29 GiB (100.00%) used: 43.73 GiB (12.9%)
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p5
maj-min: 259:5
ID-2: swap-2 type: zram size: 1.29 GiB used: 9.8 MiB (0.7%) priority: 32767 dev: /dev/zram0
ID-3: swap-3 type: zram size: 1.29 GiB used: 9.8 MiB (0.7%) priority: 32767 dev: /dev/zram1
ID-4: swap-4 type: zram size: 1.29 GiB used: 9.3 MiB (0.7%) priority: 32767 dev: /dev/zram2
ID-5: swap-5 type: zram size: 1.29 GiB used: 11.5 MiB (0.9%) priority: 32767 dev: /dev/zram3
ID-6: swap-6 type: zram size: 1.29 GiB used: 11.7 MiB (0.9%) priority: 32767 dev: /dev/zram4
ID-7: swap-7 type: zram size: 1.29 GiB used: 9.5 MiB (0.7%) priority: 32767 dev: /dev/zram5
ID-8: swap-8 type: zram size: 1.29 GiB used: 9.9 MiB (0.7%) priority: 32767 dev: /dev/zram6
ID-9: swap-9 type: zram size: 1.29 GiB used: 11.4 MiB (0.9%) priority: 32767 dev: /dev/zram7
ID-10: swap-10 type: zram size: 1.29 GiB used: 9.6 MiB (0.7%) priority: 32767 dev: /dev/zram8
ID-11: swap-11 type: zram size: 1.29 GiB used: 11.8 MiB (0.9%) priority: 32767 dev: /dev/zram9
ID-12: swap-12 type: zram size: 1.29 GiB used: 11.2 MiB (0.9%) priority: 32767 dev: /dev/zram10
ID-13: swap-13 type: zram size: 1.29 GiB used: 7.9 MiB (0.6%) priority: 32767 dev: /dev/zram11
Sensors: System Temperatures: cpu: 69.0 C mobo: N/A gpu: nvidia temp: 63 C
Fan Speeds (RPM): cpu: 3000
Info: Processes: 374 Uptime: 1h 02m wakeups: 1 Memory: 15.45 GiB used: 5.25 GiB (34.0%) Init: systemd
v: 248 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.0 Packages: pacman: 2253 lib: 469
Shell: fish v: 3.2.2 running-in: konsole inxi: 3.3.04
In future, please make sure you provide sufficient information that people can help without having to ask you a series of questions.
Given this is your first time posting, however:
In what way?
If you connect your headphones then the internal speakers will mute.
No idea what this means. The wheel is reversed, or you want it to be reversed? What mouse are you using, and have you looked at KDE's mouse settings?
Slow Wifi after 10 min become slow download speed arrive 30kb i have 100mb speed
and no sound speaker only sound headphones works and the mouse not Natural Scroll
Wifi and Internet connection speed are two different things. You should isolate the issue to your wifi by using an Ethernet cable.
That doesn't provide any more information than before.
Again, look in KDE's mouse settings.
what information you want about sound speaker
what command grep information about sound speaker
I Install Linux Garuda Yesterday i face problem Sound i try a lot solve problem not work
i install Alsa and unmute all speaker devices but nothing work what cause may problem
╭─[email protected] in ~
╰─λ inxi -Fxxxza
Mobo: ASUSTeK model: G512LW v: 1.0 serial: UEFI: American Megatrends v: G512LW.311
date: 01/08/2021
mo
only Heaphones Work
ok i will solve by myself no one care
Are you all right?
Are we your personal assistants here who drop everything to solve your problems in 1 hour?
More respect for the unpaid volunteers here in the forum.
Does it work after fresh install?
What you change between?
You mean you didn't try that before posting?
Unrealistic expectation, perhaps?
Or you expect us to care more about you than you do about us?
i try and solve it about mouse and thermal
i don't want care about me so but i will solve problems all but i don't want be showoff like you
i will help other people
you only care about rules
the problem mouse scroll i solve it by
xinput set-prop 20 "libinput Natural Scrolling Enabled" 1
not work in KDE Setting even not work the mouse speed
and solve about Thermal Problem hots
by echo 1 > /sys/devices/platform/asus-nb-wmi/throttle-thermal-policy
a lot problems i have mybe because i have model asus rog and arch linux not supported that much solve problems heat or something
i will keep try Find the solution problems i have only you replay rules not try write somthings bring information or somethings
thank you for try help me
Since your hardware does not support Linux, we can close this section.
It doesn't help anyone if you insult the moderators.
Besides, this free support does not meet your expectations.
Oh that's so nice of you. I am really looking forward for your contribution and help to the fellow community members.
And if you will spend time helping people out, you will surely know why
Also, if you want any moderator assistance, like opening/closing topics, feel free to message/ping me.
I hope you will contribute significant time to community.
Thank you.
