Help needed after garuda-update
So, the key point is succeed in chrooting.
I’m sorry I never had to use encrypted linux (only personal use at home…), so cannot provide real assistance.
How do you decrypt normally? Try with the CLI instead of GUI tools.
If you do something like:
sudo cryptsetup open /dev/nvme0n1p2 crypto_LUKS
That crypto_LUKS should be used (or whatever the name you use).
You could try:
sudo mount /dev/mapper/crypto_LUKS /mnt/broken
(or the different name used), but you could try also:
sudo mount -o subvol=@ /dev/mapper/crypto_LUKS /mnt/broken
I also just remembered a very long topic where arch-chroot worked instead of garuda-chroot:
You could give it a try. Just change the luks-xxx data with yours and sudo mount /dev/nvme0n1p1 /mnt/boot/efi.
Normally it prompts for the password after the Manufacturer Logo/BIOS (del,f12 screen) and after that It puts me to grub as usual. So I’ve never really had to use the CLI commands for it.
╭─garuda@garuda in ~ as 🧙
╰─λ sudo cryptsetup open /dev/nvme0n1p2 crypto_LUKS
Enter passphrase for /dev/nvme0n1p2:
Cannot use device /dev/nvme0n1p2 which is in use (already mapped or mounted).
╭─garuda@garuda in ~ as 🧙 took 5s
[🔴] × sudo mount -o subvol=@ /dev/mapper/crypto_LUKS /mnt/broken/
mount: /mnt/broken: special device /dev/mapper/crypto_LUKS does not exist.
dmesg(1) may have more information after failed mount system call.
is the the denotation of dm-0 relevant somehow?
Here’s my attempt at following that post:
╭─garuda@garuda in ~ as 🧙 took 0s
[🔴] × sudo mount -o subvol=@ /dev/mapper/luks-c399d964-73af-4850-a7bc-afc679df7a06 /mnt
╰─λ sudo mount -o subvol=@home /dev/mapper/luks-c399d964-73af-4850-a7bc-afc679df7a06 /mnt/home
╰─λ sudo mount -o subvol=@root /dev/mapper/luks-c399d964-73af-4850-a7bc-afc679df7a06 /mnt/root
╰─λ sudo mount -o subvol=@srv /dev/mapper/luks-c399d964-73af-4850-a7bc-afc679df7a06 /mnt/srv
╰─λ sudo mount -o subvol=@cache /dev/mapper/luks-c399d964-73af-4850-a7bc-afc679df7a06 /mnt/var/cache
╰─λ sudo mount -o subvol=@log /dev/mapper/luks-c399d964-73af-4850-a7bc-afc679df7a06 /mnt/var/log
╰─λ sudo mount -o subvol=@tmp /dev/mapper/luks-c399d964-73af-4850-a7bc-afc679df7a06 /mnt/var/tmp
╰─λ sudo mount /dev/nvme0n1p2 /mnt/boot/efi
mount: /mnt/boot/efi: unknown filesystem type 'crypto_LUKS'.
I’m sorry if I’m not seeing something obvious
This should be:
But if that’s not enough, probably there is something obvious I’m not seeing…
[🔴] × sudo mount /dev/nvme0n1p1 /mnt/boot/efi
╰─λ arch-chroot /mnt
==> ERROR: This script must be run with root privileges
[🔴] × sudo arch-chroot /mnt
[root@garuda-dr460nized-gaming /]# garuda
bash: garuda: command not found
[root@garuda-dr460nized-gaming /]# ls
bin   crypto_keyfile.bin  efi  home  lib64  mt   proc  run   srv  tmp  var
boot  dev                 etc  lib   mnt    opt  root  sbin  sys  usr
am i in?
Yes!
garuda-update
It will split for sure many warnings.
If it ends successfully and the kernel is not installed, install it as suggested above.
Okay so I ran garuda-update and it hung up on ttf-google-fonts-git, giving an error like this on a lot of fonts
ttf-google-fonts-git: /usr/share/licenses/ttf-google-fonts-git/LICENSE.zilla-slab-highlight exists in filesystem
Try:
garuda-update -- --overwrite '*'
okay that ran better, there were a few errors here and there like:
File "/usr/lib/libkhotkeysprivate.so.5.27.10" from package "khotkeys" is missing dependency "libkworkspace5.so.5"
File "/usr/lib/qt/plugins/kcm_hotkeys.so" from package "khotkeys" is missing dependency "libkworkspace5.so.5"
File "/usr/lib/qt/plugins/kf5/kded/khotkeys.so" from package "khotkeys" is missing dependency "libkworkspace5.so.5"
File "/usr/lib/qt/plugins/plasma/applets/plasma_applet_windowappmenu.so" from package "plasma5-applets-window-appmenu" is missing dependency "libKF5Plasma.so.5"
Package "python-future" has files in directory "/usr/lib/python3.12" that are ignored by the current Python interpreter
and
Failed to open file "/sys/devices/system/cpu/cpu21/cpufreq/scaling_governor": Read-only file system
Failed to open file "/sys/devices/system/cpu/cpu11/cpufreq/scaling_governor": Read-only file system
Failed to open file "/sys/devices/system/cpu/cpu9/cpufreq/scaling_governor": Read-only file system
Failed to open file "/sys/devices/system/cpu/cpu7/cpufreq/scaling_governor": Read-only file system
Failed to open file "/sys/devices/system/cpu/cpu28/cpufreq/scaling_governor": Read-only file system
Failed to open file "/sys/devices/system/cpu/cpu18/cpufreq/scaling_governor": Read-only file system
Failed to open file "/sys/devices/system/cpu/cpu5/cpufreq/scaling_governor": Read-only file system
Failed to open file "/sys/devices/system/cpu/cpu26/cpufreq/scaling_governor": Read-only file system
Failed to open file "/sys/devices/system/cpu/cpu16/cpufreq/scaling_governor": Read-only file system
also this:
23/39) GRUB update after transactions...
Found theme: /usr/share/grub/themes/catppuccin-frappe-grub-theme/theme.txt
Found initrd image: /boot/amd-ucode.img /boot/initramfs-linux-zen.img
Found fallback initrd image(s) in /boot:  amd-ucode.img initramfs-linux-zen-fallback.img
Found initrd image: /boot/amd-ucode.img /boot/initramfs-linux.img
Found fallback initrd image(s) in /boot:  amd-ucode.img initramfs-linux-fallback.img
/usr/lib/os-probes/50mounted-tests: line 186: 23895 Segmentation fault      (core dumped) grub-mount "$partition" "$tmpmnt" 2> /dev/null
/usr/lib/os-probes/50mounted-tests.orig: line 72: 23904 Segmentation fault      (core dumped) grub-mount "$partition" "$tmpmnt" 2> /dev/null
grub-probe: error: cannot find a GRUB drive for /dev/sdb1.  Check your device.map.
but it ended up finishing!
(38/39) Performing snapper post snapshots for the following configurations...
fatal library error, lookup self
==> root: 1182
(39/39) Syncing all file systems...
Running in chroot, ignoring command 'start'
System updated! 🐧
So now
exit
from chroot, reboot without USB and :crossed_fingers:
Success! I’m logged in!!! TY so much filo, tbg and SGS!
