hwdata: /usr/share/hwdata/pci.ids exists in filesystem (owned by hwids)
hwdata: /usr/share/hwdata/pnp.ids exists in filesystem (owned by hwids)
hwdata: /usr/share/hwdata/usb.ids exists in filesystem (owned by hwids)
core is up to date
extra is up to date
community is up to date
multilib is up to date
chaotic-aur 1713.9 KiB 720 KiB/s 00:02 [------------------------------------] 100%
:: Replace hwids with core/hwdata? [Y/n]
resolving dependencies...
:: removing hwids breaks dependency 'hwids' required by corectrl
For some reason, this breaks the corectrl package because it has hwids as a dependency
but the repo uses the hwdata package
weird
just did a build from source code for now
I use KDE and I started the latest upgrade using Konsole. The upgrade is asking:
--> Checking for keyring update before starting full system update..
warning: garuda-hotfixes-1.0.4-1 is up to date -- skipping
warning: archlinux-keyring-20211028-1 is up to date -- skipping
warning: chaotic-keyring-20210617-2 is up to date -- skipping
there is nothing to do
warning: garuda-settings-manager-git: local (1.0.0.r1.g15c4106-3) is newer than chaotic-aur (1.0.0.r1.g15c4106-1)
warning: garuda-settings-manager-kcm-git: local (1.0.0.r1.g15c4106-3) is newer than chaotic-aur (1.0.0.r1.g15c4106-1)
:: Replace hwids with core/hwdata? [Y/n] Y
:: There are 6 providers available for xdg-desktop-portal-impl:
:: Repository extra
1) xdg-desktop-portal-gnome 2) xdg-desktop-portal-gtk 3) xdg-desktop-portal-kde
:: Repository community
4) xdg-desktop-portal-wlr
:: Repository chaotic-aur
5) xdg-desktop-portal-kde-git 6) xdg-desktop-portal-wlr-git
Enter a number (default=1): 5
:: kirigami2-git and kirigami2 are in conflict. Remove kirigami2? [y/N]
In the last line, does the capital "N" mean that it is the default choice?
: kirigami2-git and kirigami2 are in conflict. Remove kirigami2? [y/N] N
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
Press enter to exit
