utopia
25 January 2021 06:44
1
kde- Dr460nized edition
Heat and noise issue.
i fix with this
sudo pacman -Sy mhwd-db-garuda-git
but heat and fan noise are still existing.
My machine is Hawei matebook13 intel-corei5 8gen RAM 8GB SSD 512GB| with nvidia MX-250 and Intel UHD 620 graphic.
SGS
25 January 2021 12:17
4
Include the output of “inxi -Fxxxza” in your post. This gives the people trying to resolve the issue proper information on the hardware used.
Provide the name of the iso (full name!) used to install Garuda on your system
If you include terminal outputs in your post please use the proper output format in your post. Using "~" 3 times above and "~" 3 times below the text block will provide a readable, raw look.
@dr460nf1r3 Maybe we can got "Please no pictures" in big letters in "Reporting bugs"
utopia
25 January 2021 12:21
6
my iso
garuda-dr460nized-linux-tkg-bmq-210107.iso
System: Kernel: 5.10.8-112-tkg-bmq x86_64 bits: 64 compiler: gcc v: 10.2.1
root=UUID=2bc8498a-ecee-4918-b136-2e72931804c6 rw rootflags=subvol=@ quiet splash rd.udev.log_priority=3
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 dm: SDDM Distro: Garuda Linux
Machine: Type: Laptop System: HUAWEI product: WRT-WX9 v: M1010 serial: <filter>
Mobo: HUAWEI model: WRT-WX9-PCB v: M1010 serial: <filter> UEFI: HUAWEI v: 1.21 date: 10/31/2019
Battery: ID-1: BAT0 charge: 13.5 Wh condition: 37.4/41.2 Wh (91%) volts: 12.0/11.4 model: DYNAPACK HB4593J6ECW type: Li-ion
serial: <filter> status: Charging cycles: 180
CPU: Info: Quad Core model: Intel Core i5-8265U bits: 64 type: MT MCP arch: Kaby Lake note: check family: 6
model-id: 8E (142) stepping: C (12) microcode: DE L2 cache: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 28824
Speed: 1922 MHz min/max: 400/3900 MHz Core speeds (MHz): 1: 1922 2: 2733 3: 2664 4: 3745 5: 3825 6: 3803 7: 743
8: 3692
Graphics: Device-1: Intel UHD Graphics 620 vendor: Huawei driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:3ea0
Device-2: NVIDIA GP108M [GeForce MX250] vendor: Huawei driver: nvidia v: 460.32.03 alternate: nouveau,nvidia_drm
bus ID: 01:00.0 chip ID: 10de:1d13
Device-3: IMC Networks HD Camera type: USB driver: uvcvideo bus ID: 1-4:2 chip ID: 13d3:56c6 serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: modesetting,nvidia
alternate: fbdev,intel,nouveau,nv,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 2160x1440 s-dpi: 96 s-size: 571x381mm (22.5x15.0") s-diag: 686mm (27")
Monitor-1: eDP-1 res: 2160x1440 hz: 60 dpi: 200 size: 275x183mm (10.8x7.2") diag: 330mm (13")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2) v: 4.6 Mesa 20.3.3 direct render: Yes
Audio: Device-1: Intel Cannon Point-LP High Definition Audio vendor: Huawei driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3 chip ID: 8086:9dc8
Sound Server: ALSA v: k5.10.8-112-tkg-bmq
Network: Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi v: kernel port: 4000 bus ID: 00:14.3
chip ID: 8086:9df0
Drives: Local Storage: total: 476.94 GiB used: 12.28 GiB (2.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB512HAJQ-00000 size: 476.94 GiB block size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: EXA7301Q temp: 33.9 C
Partition: ID-1: / raw size: 476.64 GiB size: 476.64 GiB (100.00%) used: 12.28 GiB (2.6%) fs: btrfs dev: /dev/nvme0n1p2
maj-min: 259:2
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%) used: 560 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw size: 476.64 GiB size: 476.64 GiB (100.00%) used: 12.28 GiB (2.6%) fs: btrfs dev: /dev/nvme0n1p2
maj-min: 259:2
ID-4: /var/log raw size: 476.64 GiB size: 476.64 GiB (100.00%) used: 12.28 GiB (2.6%) fs: btrfs dev: /dev/nvme0n1p2
maj-min: 259:2
ID-5: /var/tmp raw size: 476.64 GiB size: 476.64 GiB (100.00%) used: 12.28 GiB (2.6%) fs: btrfs dev: /dev/nvme0n1p2
maj-min: 259:2
ID-1: swap-1 type: zram size: 962.3 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-2: swap-2 type: zram size: 962.3 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-3: swap-3 type: zram size: 962.3 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-4: swap-4 type: zram size: 962.3 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
ID-5: swap-5 type: zram size: 962.3 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram4
ID-6: swap-6 type: zram size: 962.3 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram5
ID-7: swap-7 type: zram size: 962.3 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram6
ID-8: swap-8 type: zram size: 962.3 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram7
Sensors: System Temperatures: cpu: 50.0 C mobo: N/A
Info: Processes: 270 Uptime: 1h 36m wakeups: 3 Memory: 7.52 GiB used: 3.07 GiB (40.9%) Init: systemd v: 247 Compilers:
gcc: 10.2.0 Packages: pacman: 1274 lib: 291 Shell: fish v: 3.1.2 running in: konsole inxi: 3.2.02
utopia:
NVIDIA GP108M
Laptop with the same hardware and the same heating issue over here:
Made a fresh install with latest kde multimedia and and my system is having more fan noise and a much more heating . i have nvidia gefore mx150 and my driver is 460.32.03. the heating is of a level that , when the system boots it starts with 43 to 45 degree and keep on rising and the fan noise is just too much irritating.
Likely the same underlying issue of performance-oriented configuration drawing more power and therefore creating heat.
How much heat, exactly? Can you quantify temperatures, e.g. by using the sensors
command?
utopia
26 January 2021 01:54
8
iwlwifi_1-virtual-0
Adapter: Virtual device
temp1: +41.0°C
pch_cannonlake-virtual-0
temp1: +53.0°C
BAT0-acpi-0
Adapter: ACPI interface
in0: 11.28 V
curr1: 1.02 A
coretemp-isa-0000
Adapter: ISA adapter
Package id 0: +56.0°C (high = +100.0°C, crit = +100.0°C)
Core 0: +56.0°C (high = +100.0°C, crit = +100.0°C)
Core 1: +51.0°C (high = +100.0°C, crit = +100.0°C)
Core 2: +52.0°C (high = +100.0°C, crit = +100.0°C)
Core 3: +53.0°C (high = +100.0°C, crit = +100.0°C)
nvme-pci-0200
Adapter: PCI adapter
Composite: +41.9°C (low = -273.1°C, high = +80.8°C)
(crit = +81.8°C)
Sensor 1: +41.9°C (low = -273.1°C, high = +65261.8°C)
Sensor 2: +56.9°C (low = -273.1°C, high = +65261.8°C)
acpitz-acpi-0
temp1: +27.8°C
utopia:
temp1: +53.0°C
This does not seem very hot… ?
