Headset and internal audio disappeared from Hardware > Audio settings
THIS TOPIC CAN BE DELETED, I FOUND THE ISSUE I’M DUMB
Headset and internal audio disappeared from here:
It seems the Audio tab is not dumb proof. Everything was working fine, out of curiosity I tested clicking on Profile and switching the headset “Output Stereo Analogic” to “Input”; suddenly it disappeared completely from the list and I do not know how to reset it. Now I can’t hear anything from my system. I tried reinstalling pipewire but didn’t work.
╰─λ garuda-inxi
Kernel: 6.6.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=1841fbdb-0a5a-497a-86d3-67c2ef2f6c76 rw rootflags=subvol=@
quiet rd.udev.log_priority=3 vt.global_cursor_default=0
systemd.unified_cgroup_hierarchy=1 loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
Type: Laptop System: Avell High Performance product: A65 MOB v: Standard
Mobo: Avell High Performance model: Avell A65 MOB v: Standard
serial: <superuser required> UEFI: American Megatrends LLC. v: N.1.07AVE00
date: 07/23/2021
ID-1: BAT0 charge: 77.5 Wh (100.0%) condition: 77.5/93.5 Wh (82.9%)
volts: 12.2 min: 11.4 model: standard type: Li-ion serial: <filter>
status: full
ID-2: hidpp_battery_0 charge: 76% condition: N/A volts: 4.0 min: N/A
model: Logitech G703 LIGHTSPEED Wireless Gaming Mouse w/ HERO type: N/A
Info: model: 11th Gen Intel Core i7-11800H bits: 64 type: MT MCP
microcode: 0x4E
L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 1740 high: 4500 min/max: 800/4600 scaling:
driver: intel_pstate governor: performance cores: 1: 2457 2: 800 3: 4476
4: 799 5: 3094 6: 800 7: 800 8: 800 9: 800 10: 3727 11: 4500 12: 906
13: 800 14: 1112 15: 800 16: 1179 bogomips: 73728
Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Tongfang Hongkong
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: eDP-1 empty: DP-1 bus-ID: 00:02.0 chip-ID: 8086:9a60
Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q]
vendor: Tongfang Hongkong driver: nvidia v: 545.29.06
2023-10; EOL~2026-12-xx) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
built: 2020-2023 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s ports: active: none off: HDMI-A-1 empty: DP-2,DP-3,eDP-2
bus-ID: 01:00.0 chip-ID: 10de:2520 class-ID: 0300
Device-3: Chicony Integrated IR Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-13:10 chip-ID: 04f2:b71a
Device-4: Logitech Brio 500
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-5:8 chip-ID: 046d:0943
gpu: i915,nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 5120x1440 s-dpi: 96 s-size: 1354x381mm (53.31x15.00")
s-diag: 1407mm (55.38")
Monitor-1: HDMI-A-1 mapped: HDMI-1-0 note: disabled pos: primary,bottom-r
model: LG (GoldStar) 25UM58G serial: <filter> built: 2015 res: 2560x1080
dpi: 96 gamma: 1.2 size: 677x290mm (26.65x11.42") diag: 730mm (28.8")
modes: max: 2560x1080 min: 640x480
Monitor-2: eDP-1 pos: top-left model: BOE Display 0x0974 built: 2021
res: 2560x1440 hz: 165 dpi: 189 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: 2560x1440
drv: nvidia device: 1 drv: iris device: 3 drv: swrast surfaceless:
drv: nvidia x11: drv: iris inactive: gbm,wayland,device-2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (TGL GT1)
device-ID: 8086:9a60 memory: 61.08 GiB unified: yes
API: Vulkan v: 1.3.269 layers: 8 device: 0 type: integrated-gpu name: Intel
UHD Graphics (TGL GT1) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:9a60 surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 Laptop GPU driver: nvidia v: 545.29.06
device-ID: 10de:2520 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
Device-1: Intel Tiger Lake-H HD Audio vendor: Tongfang Hongkong
bus-ID: 00:1f.3 chip-ID: 8086:43c8 class-ID: 0403
Device-2: NVIDIA GA106 High Definition Audio vendor: Tongfang Hongkong
Device-3: Fifine Microphone driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1.2:7
chip-ID: 3142:5060 class-ID: 0300
API: ALSA v: k6.6.6-zen1-1-zen status: kernel-api with: aoss
Device-2: Realtek RTL8125 2.5GbE vendor: Tongfang Hongkong driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 2e:00.0
IF: enp46s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-2: br-cc173ea2f690 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-3: docker0 state: down mac: <filter>
IF-ID-4: veth026e913 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-5: veth0b35697 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-6: veth1f461b6 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-7: veth4de0bfd state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-8: veth6396c25 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-9: veth83907d0 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-10: veth95f4c6f state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-11: vethc88157b state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-12: vethe5d8f68 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-13: vethefbb2ae state: up speed: 10000 Mbps duplex: full
mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-14:11 chip-ID: 8087:0026
Local Storage: total: 3.73 TiB used: 604.95 GiB (15.9%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: A-Data model: SX8200PNP
lanes: 4 tech: SSD serial: <filter> fw-rev: 42B9T6TB temp: 39.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: A-Data model: SX8200PNP
lanes: 4 tech: SSD serial: <filter> fw-rev: 42B9T6TB temp: 37.9 C
ID-1: / raw-size: 1.86 TiB size: 1.86 TiB (100.00%) used: 604.95 GiB (31.7%)
fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:3
used: 563 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:2
ID-3: /home raw-size: 1.86 TiB size: 1.86 TiB (100.00%)
used: 604.95 GiB (31.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:3
ID-4: /var/log raw-size: 1.86 TiB size: 1.86 TiB (100.00%)
ID-5: /var/tmp raw-size: 1.86 TiB size: 1.86 TiB (100.00%)
ID-1: swap-1 type: zram size: 62.54 GiB used: 38.8 MiB (0.1%)
System Temperatures: cpu: 60.0 C mobo: N/A
Processes: 485 Uptime: 17m wakeups: 0 Memory: total: 64 GiB note: est.
available: 62.54 GiB used: 13.02 GiB (20.8%) Init: systemd v: 255
default: graphical tool: systemctl Compilers: gcc: 13.2.1 alt: 12
clang: 16.0.6 Packages: pm: dpkg pkgs: 0 pm: pacman pkgs: 2368 libs: 541
tools: pamac,paru Shell: fish v: 3.6.4 running-in: konsole inxi: 3.3.31
Garuda (2.6.19-2):
System install date:     2021-09-13
Last full system update: 2023-12-12 ↻
Relevant software:       timeshift NetworkManager mkinitcpio nvidia-dkms
Failed units:            anbox-container-manager.service systemd-networkd-wait-online.service
Glad to hear you resolved the issue!
We typically do not delete solved topics, so people searching in the forum with an issue can find solutions to try for themselves.
What ended up being the issue? Maybe it will help someone else in the future, to check for the same problem on their setup.
