I recently installed Garuda linux loved it. But i am facing just one issue that is with my Headphone. I am dual booting Garuda with Windows 11 and in windows all my headphones works fine.
Laptop's internal Speaker works fine.And as soon as i connect my headphone it goes "Speaker(unplugged)" that's good even my headphone is detected in Audio Settings but ,when the TEST audio plays or any other media there's no output from Headphone.
i tried alsamixer the settings are fine i guess (iHeadphone : Unmuted).
Even when i play any media the Visualzer in Audio Adjuster from tray HIGHLIGHTS but theres no sound comming from headphone.
as soon as i unplug it.Internal speakers starts playing.
heres my inxi -Faz
Kernel: 5.15.11-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=f1a8c758-fe82-429e-bd49-29e513fcf933 rw [email protected]
Type: Laptop System: ASUSTeK product: Strix 15 GL503GE v: 1.0
Mobo: ASUSTeK model: GL503GE v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: GL503GE.318 date: 06/19/2020
ID-1: BAT1 charge: 15.8 Wh (32.0%) condition: 49.3/64.4 Wh (76.5%)
volts: 4.5 min: 15.2 model: ASUS A32-K55 type: Li-ion serial: N/A
status: Discharging
Info: model: Intel Core i5-8300H bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEA
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 3979 high: 4003 min/max: 800/4000 scaling:
driver: intel_pstate governor: powersave cores: 1: 4001 2: 4001 3: 4003
4: 4000 5: 3834 6: 3997 7: 4000 8: 4001 bogomips: 36799
Type: l1tf
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: ASUSTeK
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] vendor: ASUSTeK
driver: nvidia v: 495.46 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1c8c class-ID: 0302
Device-3: Holitech USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-7:3 chip-ID: 2fee:1014 class-ID: 0e02 serial: <filter>
loaded: modesetting,nvidia display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 120 dpi: 142
size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
Sound Server-1: ALSA v: k5.15.11-zen1-1-zen running: yes
Sound Server-5: PipeWire v: 0.3.42 running: yes
vendor: ASUSTeK driver: r8169 v: kernel port: 3000 bus-ID: 03:00.0
driver: btusb v: 0.8 bus-ID: 1-14:5 chip-ID: 8087:0aaa class-ID: e001
address: <filter>
Local Storage: total: 1.14 TiB used: 117.74 GiB (10.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston
model: RBUSNS8154P3256GJ size: 238.47 GiB block-size: physical: 512 B
rev: E8FK11.C temp: 34.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LX015-1U7172
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: SDM1
ID-1: / raw-size: 112.51 GiB size: 112.51 GiB (100.00%)
used: 13.45 GiB (12.0%) fs: btrfs dev: /dev/sda5 maj-min: 8:5
used: 28.1 MiB (11.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 112.51 GiB size: 112.51 GiB (100.00%)
ID-4: /var/log raw-size: 112.51 GiB size: 112.51 GiB (100.00%)
ID-5: /var/tmp raw-size: 112.51 GiB size: 112.51 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.62 GiB used: 5 MiB (0.1%) priority: 100
System Temperatures: cpu: 57.0 C pch: 56.0 C mobo: 27.8 C
Fan Speeds (RPM): cpu: 0
Processes: 286 Uptime: 56m wakeups: 21 Memory: 7.62 GiB
used: 4.38 GiB (57.5%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1561 lib: 374 Shell: fish
v: 3.3.1 default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.11
