Hello Garuda users.
My Headphone mic is not taking my voice or record i newly installed garuda in my laptop
Kernel: 6.2.2-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=5a63c524-7e47-40a2-ae1f-6736383dd138 rw [email protected]
resume=UUID=00794960-476b-4b1d-a040-1a0a24a24be4 loglevel=3
Desktop: KDE Plasma v: 5.27.2 tk: Qt v: 5.15.8 wm: kwin_wayland vt: 2
Type: Laptop System: Dell product: Vostro 15-3568 v: N/A
Mobo: Dell model: 0R2XKN v: A00 serial: <superuser required> UEFI: Dell
v: 3.6.0 date: 06/30/2020
ID-1: BAT0 charge: 7.8 Wh (39.2%) condition: 19.9/41.4 Wh (48.0%)
volts: 16.0 min: 14.8 model: SMP DELL VN3N047 type: Li-ion serial: <filter>
status: charging
Info: model: Intel Core i3-7020U bits: 64 type: MT MCP arch: Amber/Kaby Lake
note: check gen: core 7 level: v3 note: check built: 2017
process: Intel 14nm family: 6 model-id: 0x8E (142) stepping: 9
microcode: 0xF0
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 590 high: 600 min/max: 400/2300 scaling:
driver: intel_pstate governor: powersave cores: 1: 600 2: 600 3: 562 4: 600
bogomips: 18399
Device-1: Intel HD Graphics 620 vendor: Dell driver: i915 v: kernel
empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:5921
Display: wayland server: X.org v: 1.21.1.7 with: Xwayland v: 22.1.8
Monitor-1: eDP-1 res: 1366x768 size: N/A modes: N/A
API: OpenGL v: 4.6 Mesa 22.3.6 renderer: Mesa Intel HD Graphics 620 (KBL
GT2F) direct-render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_soc_avs bus-ID: 00:1f.3
Sound API: ALSA v: k6.2.2-zen2-1-zen running: yes
Device-1: Intel Wireless 3165 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:3165 class-ID: 0280
vendor: Dell driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
bus-ID: 1-8:3 chip-ID: 8087:0a2a class-ID: e001
Local Storage: total: 223.58 GiB used: 4.53 GiB (2.0%)
ID-1: /dev/sda maj-min: 8:0 model: SATA SSD size: 111.79 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 61.3 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 model: SATA SSD size: 111.79 GiB block-size:
ID-1: / raw-size: 103.36 GiB size: 103.36 GiB (100.00%)
used: 4.53 GiB (4.4%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
used: 624 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 103.36 GiB size: 103.36 GiB (100.00%)
ID-4: /var/log raw-size: 103.36 GiB size: 103.36 GiB (100.00%)
ID-5: /var/tmp raw-size: 103.36 GiB size: 103.36 GiB (100.00%)
ID-1: swap-1 type: zram size: 3.7 GiB used: 393.5 MiB (10.4%)
ID-2: swap-2 type: partition size: 8.13 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 57.0 C pch: 54.5 C mobo: 54.0 C
Fan Speeds (RPM): cpu: 0
Processes: 216 Uptime: 4m wakeups: 13630 Memory: 3.7 GiB
used: 2.44 GiB (65.9%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1161
libs: 309 tools: octopi,paru Shell: fish v: 3.6.0 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.25
Garuda (2.6.15-1):
System install date: 2023-03-12
Last full system update: 2023-03-12
Failed units: [email protected]:dell::kbd_backlight.service
