ISO - "GARUDA_DR46NIZEDGAMING_HARPEAG"
Kernel: 5.15.13-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=17bd5743-8197-48ed-b4c0-d114373d7f80 rw [email protected]
resume=UUID=6ceb446c-b208-4e4a-b34e-8abea0557014 loglevel=3
Type: Desktop Mobo: ASRock model: X570M Pro4 serial: <superuser required>
BIOS: American Megatrends v: P3.40 date: 01/27/2021
Device-1: hidpp_battery_0 model: Logitech Craft Advanced Keyboard
status: Discharging
Device-2: hidpp_battery_1
model: Logitech Wireless Mobile Mouse MX Anywhere 2S serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: Discharging
Info: model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3626 high: 3980 min/max: 2200/4426 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3588 2: 3596
3: 3586 4: 3594 5: 3588 6: 3601 7: 3593 8: 3596 9: 3582 10: 3980 11: 3776
12: 3588 13: 3589 14: 3590 15: 3584 16: 3592 bogomips: 114977
Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: Gigabyte
driver: nvidia v: 495.46 alternate: nouveau,nvidia_drm bus-ID: 09:00.0
chip-ID: 10de:1c82 class-ID: 0300
loaded: nvidia unloaded: modesetting alternate: fbdev,nouveau,nv,vesa
Screen-1: 0 s-res: 1440x900 s-dpi: 89 s-size: 411x263mm (16.2x10.4")
s-diag: 488mm (19.2")
Monitor-1: HDMI-0 res: 1440x900 hz: 60 dpi: 90
size: 408x255mm (16.1x10.0") diag: 481mm (18.9")
OpenGL: renderer: NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2
v: 4.6.0 NVIDIA 495.46 direct render: Yes
Device-1: NVIDIA GP107GL High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 09:00.1 chip-ID: 10de:0fb9
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
driver: snd_hda_intel v: kernel bus-ID: 0b:00.4 chip-ID: 1022:1487
Sound Server-1: ALSA v: k5.15.13-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.43 running: yes
Device-1: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel
port: f000 bus-ID: 05:00.0 chip-ID: 8086:1539 class-ID: 0200
IF: enp5s0 state: up speed: 100 Mbps duplex: full mac: <filter>
IF-ID-1: nordlynx state: unknown speed: N/A duplex: N/A mac: N/A
Local Storage: total: 370.5 GiB used: 32.16 GiB (8.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Intel model: SSDSC2BW240A4
type: SSD serial: <filter> rev: DC12 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 type: USB model: USB DISK 3.0
size: 117.64 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: PMAP scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 type: USB model: General size: 29.3 GiB
block-size: physical: 512 B logical: 512 B type: N/A serial: <filter>
rev: 5.00 scheme: MBR
ID-1: / raw-size: 189.17 GiB size: 189.17 GiB (100.00%)
used: 32.16 GiB (17.0%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 189.17 GiB size: 189.17 GiB (100.00%)
ID-3: /var/log raw-size: 189.17 GiB size: 189.17 GiB (100.00%)
ID-4: /var/tmp raw-size: 189.17 GiB size: 189.17 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.27 GiB used: 2 MiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 34.4 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 44 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 38%
Processes: 353 Uptime: 59m wakeups: 126 Memory: 31.27 GiB
used: 3.72 GiB (11.9%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1881 lib: 537 Shell: fish
v: 3.3.1 default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.11
I recently installed Garuda Linux and ...
When I run my Garuda Linux “audio preferences” set to “line out” for speakers: online streaming videos (like those on YouTube and Amazon Prime) play fine – their audio is heard through my speakers.
However, when I switch over to “headphones” (in audio preferences), both online streaming videos and video files already on my PC (running through my media player) stop playing or continue playing with no sound. When on YouTube I’ll get this error message “Audio renderer error, please restart your computer” I have done that a few times and it doesn’t help.
- I checked the Arch forum and found someone suggesting to downgrade the kernel to fix the problem. I tried instead to upgrade it instead – but that had no effect. Does it mean that I stay stuck at a kernel version forever?
- I hear the audio coming through my headphones for a fraction of a second as I switch from “Line Out” to the “headphones” setting in my system preferences section.
- I’ve tried the system headphone test app and it sends audio to both the right and left channels of my headphones when it’s running that “Right Channel” / “Left Channel” test.
- I’ve set preferences on both my web browsers to accept sound from websites – no improvement
I tried reinstalling the following apps:
- pusleaudio-qt
- port audio
- lib32_portaudio
- lib32-faudio
- webrtc-audio-processing
….No effect on the outcome.
I tried also installing asla-audio and once I selected the right audio card, having a look at its mixer on the terminal – to see if any channels were turned off but only the ones that covered 5.1 & 7.1 Stereo were turned off.
