HD3 AudioEngine Speaker Issue
Hi Team
Issue:
Audioengine HD3 speakers appear fine but suddenly only working intermittently. If I turn them off and back on it appears to work for a few seconds and then stops. I can see the speakers are receiving output but no sound.
I have headphones connected via USB that work without issue.
I tried an update.
I tried uninstalling pipewire and reinstalling.
Thanks for your help.
Kernel: 6.6.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=d255ab07-4fa5-418e-ab51-6a40c046051d rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
Type: Desktop Mobo: ASUSTeK model: PRIME Z370-A v: Rev X.0x
serial: <superuser required> UEFI-[Legacy]: American Megatrends v: 0430
date: 11/01/2017
Device-2: hidpp_battery_1 model: Logitech MX Keys Wireless Keyboard
Info: model: Intel Core i3-8100 bits: 64 type: MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xB (11) microcode: 0xF4
desc: 1x6 MiB
Speed (MHz): avg: 2900 high: 3601 min/max: 800/3600 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 3600 3: 3601
4: 3601 bogomips: 28800
Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M] vendor: Gigabyte
active: DP-1,DP-2 empty: HDMI-A-1,HDMI-A-2 bus-ID: 03:00.0
chip-ID: 1002:73ff class-ID: 0300
Screen-1: 0 s-res: 4000x2560 s-dpi: 96 s-size: 1058x677mm (41.65x26.65")
s-diag: 1256mm (49.45")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,left
model: Dell S2722DGM serial: <filter> built: 2021 res: 2560x1440 dpi: 109
gamma: 1.2 size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9
modes: max: 2560x1440 min: 720x400
Monitor-2: DP-2 mapped: DisplayPort-1 pos: right model: Dell S2722DGM
serial: <filter> built: 2021 res: 1440x2560 dpi: 109 gamma: 1.2
size: 336x597mm (13.23x23.5") diag: 685mm (27") ratio: 16:9 modes:
inactive: gbm,wayland
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6600 XT (navi23 LLVM
16.0.6 DRM 3.54 6.6.4-zen1-1-zen) device-ID: 1002:73ff memory: 7.81 GiB
unified: no
API: Vulkan v: 1.3.269 layers: 13 device: 0 type: discrete-gpu name: AMD
Radeon RX 6600 XT (RADV NAVI23) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:73ff surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
Device-3: Corsair VOID Wireless Gaming Dongle
lanes: 1 mode: 1.1 bus-ID: 1-10:5 chip-ID: 1b1c:1b23 class-ID: 0300
Device-4: Cambridge Silicon Radio Audioengine HD3
lanes: 1 mode: 1.1 bus-ID: 1-6.1:4 chip-ID: 0a12:4097 class-ID: 0300
API: ALSA v: k6.6.4-zen1-1-zen status: kernel-api with: aoss
Device-2: Broadcom BCM4360 802.11ac Wireless Network Adapter
vendor: ASUSTeK driver: wl v: kernel modules: bcma pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 07:00.0 chip-ID: 14e4:43a0 class-ID: 0280
IF: wlp7s0 state: up mac: <filter>
Local Storage: total: 1.46 TiB used: 128.64 GiB (8.6%)
fw-rev: 4B2QEXM7 temp: 35.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 250GB
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 840 EVO 120GB
tech: SSD serial: <filter> fw-rev: BB6Q scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Transcend model: TS240GSSD220S
tech: SSD serial: <filter> fw-rev: 71.1 scheme: MBR
ID-1: / raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
used: 128.64 GiB (57.5%) fs: btrfs dev: /dev/sdc1 maj-min: 8:33
ID-2: /home raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
ID-3: /var/log raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
ID-4: /var/tmp raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.68 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 39.0 C mobo: N/A gpu: amdgpu temp: 57.0 C
mem: 62.0 C
Processes: 234 Uptime: 6m wakeups: 0 Memory: total: 8 GiB
available: 7.68 GiB used: 3.3 GiB (42.9%) Init: systemd v: 255
default: graphical tool: systemctl Compilers: gcc: 13.2.1 Packages: 1786
pm: pacman pkgs: 1775 libs: 517 tools: octopi,paru pm: flatpak pkgs: 11
Shell: fish v: 3.6.2 default: Bash v: 5.2.21 running-in: konsole
inxi: 3.3.31
Garuda (2.6.19-2):
System install date:     2023-07-10
Last full system update: 2023-12-09
Are the speakers also connected with USB or Bluetooth?
They are connected via USB.
There are a few older articles about this issue relating to sample rate with pulseaudio.
I was looking at the troubleshooting section here: PipeWire - ArchWiki
╰─󰈺 cat /proc/asound/card0/stream0
File: /proc/asound/card0/stream0
QTIL Audioengine HD3 at usb-0000:06:00.0-2.1, full speed : USB Audio
Playback:
Status: Stop
Interface 1
Altset 1
Format: S16_LE
Channels: 2
Endpoint: 0x03 (3 OUT) (NONE)
Rates: 48000, 44100, 32000, 22050, 16000, 8000
Bits: 16
Channel map: FL FR
The sample rates appear ok but note that the status is “Stopped”. Is this normal?
  1. Uninstalled Pipewire.
  2. Installed PulseAudio.
  3. Sound works! Yay. But only system sounds, no applications.
  4. Started getting some other odd errors unrelated to sound. Lead me to think unstable build.
  5. Reinstalled fresh. Sound works. Yay!
  6. Update and reboot. Sound no longer works. Sigh.
garuda-inxi post refresh and upgrade audio section.
Device-3: Cambridge Silicon Radio Audioengine HD3
lanes: 1 mode: 1.1 bus-ID: 1-6.1:6 chip-ID: 0a12:4097 class-ID: 0300
API: ALSA v: k6.6.6-zen1-1-zen status: kernel-api with: aoss
Any ideas gratefully received!
Can you post release date of the .iso you are installing from?
So I can get the package list from the website.
I guess it has to be one of the updated packages then.
Hopefully, comparing current versions with those from the functioning first install we’ll find a clue.
ISO: garuda-dr460nized-gaming-linux-zen-231029.iso
I did another update and sound working after restarting pipewire.service. I almost fell off my chair. The only other change is I turned off the bluetooth to test. I use the bluetooth for MacBook when working.
One thought was that maybe the DAC is “sleeping” thinking its going through bluetooth?
I have enabled bluetooth and have sound through the PC and the MacBook still. I’ll try a reboot and see if it stays consistent.
I do still wonder if there is a package update that has shifted behaviour as you say, as this has been my existing setup without issue for some time. I actually moved from Fedora many months ago as it had this issue. Someone suggested Garuda and everything just worked.
Is there any further diagnostic information I can provide?
Update:
Sound has remained consistent through updates and reboots and while using bluetooth through the MacBook.
So although I dont understand why, the solution was to reinstall fresh and update.
Nope. Working fine for a few days.
Played steam games last night. Woke up this morning no sound. Sadness ensues.
Some different information in the journalctl. I am not using pulseaudio. Default audio components with pipewire.
Dec 17 11:32:42 desktop kernel: usb 1-6: new full-speed USB device number 7 using xhci_hcd
Dec 17 11:32:42 desktop kernel: usb 1-6: New USB device found, idVendor=0a12, idProduct=4010, bcdDevice=15.49
Dec 17 11:32:42 desktop kernel: usb 1-6: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Dec 17 11:32:42 desktop kernel: hub 1-6:1.0: USB hub found
Dec 17 11:32:42 desktop kernel: hub 1-6:1.0: 4 ports detected
Dec 17 11:32:42 desktop kernel: usb 1-6.1: new full-speed USB device number 8 using xhci_hcd
Dec 17 11:32:42 desktop kernel: usb 1-6.1: New USB device found, idVendor=0a12, idProduct=4097, bcdDevice=14.86
Dec 17 11:32:42 desktop kernel: usb 1-6.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Dec 17 11:32:42 desktop kernel: usb 1-6.1: Product: Audioengine HD3
Dec 17 11:32:42 desktop kernel: usb 1-6.1: Manufacturer: QTIL
Dec 17 11:32:42 desktop kernel: usb 1-6.1: SerialNumber: ABCDEF0123456789
Dec 17 11:32:42 desktop kernel: hid-generic 0003:0A12:4097.0008: hiddev97,hidraw3: USB HID v1.11 Device [QTIL Audioengine HD3] on usb-0000:00>
Dec 17 11:32:42 desktop mtp-probe[8407]: checking bus 1, device 8: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6.1"
Dec 17 11:32:42 desktop mtp-probe[8407]: bus: 1, device: 8 was not an MTP device
Dec 17 11:32:42 desktop mtp-probe[8414]: checking bus 1, device 8: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6.1"
Dec 17 11:32:42 desktop mtp-probe[8414]: bus: 1, device: 8 was not an MTP device
Dec 17 11:32:43 desktop plasmashell[2540]: org.kde.plasma.pulseaudio: No object for name "@DEFAULT_SINK@"
Dec 17 11:32:43 desktop plasmashell[2540]: org.kde.plasma.pulseaudio: No object for name "@DEFAULT_SOURCE@"
Dec 17 11:32:43 desktop plasmashell[2540]: org.kde.plasma.pulseaudio: No object for name "alsa_output.usb-QTIL_Audioengine_HD3_ABCDEF01234567>
Dec 17 11:32:43 desktop systemsettings[6065]: org.kde.plasma.pulseaudio: No object for name "@DEFAULT_SINK@"
Dec 17 11:32:43 desktop systemsettings[6065]: org.kde.plasma.pulseaudio: No object for name "@DEFAULT_SOURCE@"
Dec 17 11:32:43 desktop systemsettings[6065]: org.kde.plasma.pulseaudio: No object for name "alsa_output.usb-QTIL_Audioengine_HD3_ABCDEF01234>
Dec 17 11:32:43 desktop systemsettings[6065]: file:///usr/share/kpackage/kcms/kcm_pulseaudio/contents/ui/CardListItem.qml:16: TypeError: Cann>
Dec 17 11:32:49 desktop irqbalance[557]:
Dec 17 11:32:59 desktop irqbalance[557]:
Dec 17 11:33:02 desktop sudo[8870]:     wolf : a password is required ; TTY=pts/0 ; PWD=/home/wolf ; USER=root ; COMMAND=/usr/bin/true
Dec 17 11:33:09 desktop irqbalance[557]:
and this:
╰─λ journalctl -b 0 -xe | grep pipewire
Dec 17 11:31:21 desktop pipewire[2662]: spa.alsa: front:2p: snd_pcm_drop: No such device
Dec 17 11:31:21 desktop pipewire[2662]: spa.alsa: front:2p: close failed: No such device
Dec 17 11:31:30 desktop wireplumber[2666]: disconnected from pipewire
