Having some kinda issue with my GPU after update
Hello,
After updating at some point, my GPU has become very displeased - or its fans have. I try and run a game, nothing too abnormal and my PC sounds like it is about to take flight. I open up fancontrol-gui and can see that the fans on my card are nearing, and in rare cases exceeding 3000 RPM. At first I figured it might be a hardware thing realised today that I could try a snapshot and see if I was getting anything similar. I boot in to one from the 21st of November and try the same thing, the fans’ speeds barely exceed 1000 RPM.
I figure this has to be something update-related, I’m just not sure what exactly would’ve been the cause exactly. I plan to go through each snapshot and try and see if I can figure out just when this all started, but any sorta advice to help with this would be greatly appreciated.
Kernel: 6.6.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=9cb34755-a24b-463c-9215-498d1e3ea350 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
Type: Desktop System: Micro-Star product: MS-7A34 v: 1.0
Mobo: Micro-Star model: B350 TOMAHAWK (MS-7A34) v: 1.0
serial: <superuser required> UEFI: American Megatrends v: 1.M0
date: 01/23/2019
Info: model: AMD Ryzen 5 1600 bits: 64 type: MT MCP arch: Zen level: v3
note: check built: 2017-19 process: GF 14nm family: 0x17 (23) model-id: 1
stepping: 1 microcode: 0x8001137
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 3398 high: 3400 min/max: 1550/3200 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3396 2: 3387
3: 3400 4: 3400 5: 3400 6: 3400 7: 3400 8: 3400 9: 3400 10: 3400 11: 3400
12: 3400 bogomips: 76799
vendor: Sapphire driver: amdgpu v: kernel arch: RDNA-1 code: Navi-1x
process: TSMC n7 (7nm) built: 2019-20 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: DP-2,HDMI-A-1 empty: DP-1,DP-3 bus-ID: 1d:00.0
chip-ID: 1002:731f class-ID: 0300
s-diag: 1055mm (41.54")
Monitor-1: DP-2 mapped: DisplayPort-1 pos: primary,right model: VG245
serial: <filter> built: 2017 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: left model: LG (GoldStar) W2442
serial: <filter> built: 2010 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
inactive: gbm,wayland
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 5700 XT (navi10 LLVM
16.0.6 DRM 3.54 6.6.4-zen1-1-zen) device-ID: 1002:731f memory: 7.81 GiB
unified: no
API: Vulkan v: 1.3.269 layers: 14 device: 0 type: discrete-gpu name: AMD
Radeon RX 5700 XT (RADV NAVI10) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:731f surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 1d:00.1 chip-ID: 1002:ab38
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
bus-ID: 1f:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: C-Media Blue Snowball driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-2.4:5
chip-ID: 0d8c:0005 class-ID: 0300 serial: <filter>
API: ALSA v: k6.6.4-zen1-1-zen status: kernel-api with: aoss
lanes: 1 port: f000 bus-ID: 19:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp25s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1:2
lmp-v: 6 status: discoverable: no pairing: no class-ID: 7c0104
Report-ID: ID: hci1 rfk-id: 1 state: down bt-service: enabled,running
rfk-block: hardware: no software: no address: <filter> bt-v: 4.1 lmp-v: 7
Local Storage: total: 5 TiB used: 3.59 TiB (71.8%)
model: WD30EZRZ-00GXCB0 size: 2.73 TiB block-size: physical: 4096 B
fw-rev: 0A80 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST3500418AS
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC38 scheme: GPT
model: WD10EZEX-08WN4A0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A02 scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 vendor: Crucial model: CT1000MX500SSD4
used: 838.74 GiB (90.1%) fs: btrfs dev: /dev/sdd2 maj-min: 8:50
used: 25.8 MiB (8.6%) fs: vfat dev: /dev/sdd1 maj-min: 8:49
ID-1: swap-1 type: zram size: 31.29 GiB used: 18 MiB (0.1%) priority: 100
System Temperatures: cpu: 54.8 C mobo: N/A gpu: amdgpu temp: 46.0 C
mem: 54.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 1594
Processes: 495 Uptime: 2m wakeups: 0 Memory: total: 32 GiB
available: 31.29 GiB used: 9.83 GiB (31.4%) Init: systemd v: 255
Packages: pm: pacman pkgs: 2447 libs: 615 tools: octopi,pamac,paru
Shell: fish v: 3.6.2 default: Bash v: 5.2.21 running-in: konsole
inxi: 3.3.31
Garuda (2.6.19-2):
System install date:     2022-05-10
Last full system update: 2023-12-07
Good idea @ snapshots. When you have found the last working snapshot, do a garuda-update and after that: post the output of
cat /var/log/pacman.log | grep 'year-month-day' | grep -E 'installed|upgraded|removed'
(replace year-month-day with the date of the update)
Ran it, output is as follows. Last update that functioned properly was from the 30th so there’s quite a bit to go through.
[2023-12-11T13:57:29-0600] [ALPM] upgraded archlinux-keyring (20231130-1 -> 20231207-1)
[2023-12-11T13:58:20-0600] [ALPM] removed kgamma5 (5.27.9-1)
[2023-12-11T13:58:20-0600] [ALPM] upgraded util-linux-libs (2.39.2-2 -> 2.39.3-1)
[2023-12-11T13:58:20-0600] [ALPM] upgraded systemd-libs (254.6-2 -> 255-1)
[2023-12-11T13:58:20-0600] [ALPM] upgraded xdg-utils (1.2.0r17+g21fb316-1 -> 1.2.0r25+g0f49cf5-1)
[2023-12-11T13:58:20-0600] [ALPM] upgraded glib2 (2.78.1-1 -> 2.78.3-1)
[2023-12-11T13:58:20-0600] [ALPM] upgraded libxml2 (2.12.1-1 -> 2.12.2-1)
[2023-12-11T13:58:20-0600] [ALPM] upgraded curl (8.4.0-2 -> 8.5.0-1)
[2023-12-11T13:58:20-0600] [ALPM] upgraded hwdata (0.376-1 -> 0.377-1)
[2023-12-11T13:58:20-0600] [ALPM] upgraded util-linux (2.39.2-2 -> 2.39.3-1)
[2023-12-11T13:58:21-0600] [ALPM] upgraded systemd (254.6-2 -> 255-1)
[2023-12-11T13:58:22-0600] [ALPM] upgraded signon-kwallet-extension (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:22-0600] [ALPM] upgraded thin-provisioning-tools (1.0.7-1 -> 1.0.9-1)
[2023-12-11T13:58:22-0600] [ALPM] upgraded aom (3.7.1-1 -> 3.8.0-2)
[2023-12-11T13:58:22-0600] [ALPM] upgraded bluez-libs (5.70-1 -> 5.70-2)
[2023-12-11T13:58:22-0600] [ALPM] upgraded libnl (3.8.0-1 -> 3.9.0-1)
[2023-12-11T13:58:22-0600] [ALPM] upgraded ffmpeg (2:6.1-1 -> 2:6.1-2)
[2023-12-11T13:58:22-0600] [ALPM] upgraded kaccounts-integration (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:22-0600] [ALPM] upgraded libakonadi (23.08.3-2 -> 23.08.4-1)
[2023-12-11T13:58:22-0600] [ALPM] upgraded akonadi (23.08.3-2 -> 23.08.4-1)
[2023-12-11T13:58:22-0600] [ALPM] upgraded ksmtp (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:22-0600] [ALPM] upgraded libkgapi (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:22-0600] [ALPM] upgraded kmailtransport (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:22-0600] [ALPM] upgraded kpimtextedit (23.08.3-2 -> 23.08.4-1)
[2023-12-11T13:58:22-0600] [ALPM] upgraded kidentitymanagement (23.08.3-2 -> 23.08.4-1)
[2023-12-11T13:58:22-0600] [ALPM] upgraded kcalutils (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:22-0600] [ALPM] upgraded kmime (23.08.3-2 -> 23.08.4-1)
[2023-12-11T13:58:22-0600] [ALPM] upgraded grantleetheme (23.08.3-2 -> 23.08.4-1)
[2023-12-11T13:58:22-0600] [ALPM] upgraded zxing-cpp (2.1.0-1 -> 2.2.0-2)
[2023-12-11T13:58:22-0600] [ALPM] upgraded akonadi-contacts (23.08.3-2 -> 23.08.4-1)
[2023-12-11T13:58:22-0600] [ALPM] upgraded libkdepim (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:23-0600] [ALPM] upgraded kimap (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:23-0600] [ALPM] upgraded kldap (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:23-0600] [ALPM] upgraded akonadi-mime (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:23-0600] [ALPM] upgraded akonadi-search (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:23-0600] [ALPM] upgraded pimcommon (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:23-0600] [ALPM] upgraded libgravatar (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:23-0600] [ALPM] upgraded kmbox (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:23-0600] [ALPM] upgraded libkleo (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:23-0600] [ALPM] upgraded messagelib (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:23-0600] [ALPM] upgraded akonadi-calendar (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:23-0600] [ALPM] upgraded mailimporter (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:23-0600] [ALPM] upgraded mailcommon (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:23-0600] [ALPM] upgraded akonadi-import-wizard (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:23-0600] [ALPM] upgraded akonadi-notes (23.08.3-2 -> 23.08.4-1)
[2023-12-11T13:58:23-0600] [ALPM] upgraded ark (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:23-0600] [ALPM] upgraded baloo-widgets (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:23-0600] [ALPM] upgraded openxr (1.0.30-1 -> 1.0.32-1)
[2023-12-11T13:58:23-0600] [ALPM] upgraded python-typing_extensions (4.8.0-1 -> 4.9.0-1)
[2023-12-11T13:58:24-0600] [ALPM] upgraded python-platformdirs (4.0.0-1 -> 4.1.0-1)
[2023-12-11T13:58:24-0600] [ALPM] upgraded python-setuptools (1:68.2.1-1 -> 1:69.0.0-1)
[2023-12-11T13:58:24-0600] [ALPM] upgraded pybind11 (2.11.1-1 -> 2.11.1-2)
[2023-12-11T13:58:24-0600] [ALPM] upgraded shiboken6 (6.6.0-4 -> 6.6.1-1)
[2023-12-11T13:58:24-0600] [ALPM] upgraded pyside6 (6.6.0-4 -> 6.6.1-1)
[2023-12-11T13:58:27-0600] [ALPM] upgraded blender (17:4.0.1-7 -> 17:4.0.2-2)
[2023-12-11T13:58:27-0600] [ALPM] upgraded bluez (5.70-1 -> 5.70-2)
[2023-12-11T13:58:27-0600] [ALPM] upgraded bluedevil (1:5.27.9-1 -> 1:5.27.10-1)
[2023-12-11T13:58:27-0600] [ALPM] upgraded qpdf (11.6.3-1 -> 11.6.4-1)
[2023-12-11T13:58:27-0600] [ALPM] upgraded bluez-cups (5.70-1 -> 5.70-2)
[2023-12-11T13:58:27-0600] [ALPM] upgraded bluez-hid2hci (5.70-1 -> 5.70-2)
[2023-12-11T13:58:27-0600] [ALPM] upgraded bluez-plugins (5.70-1 -> 5.70-2)
[2023-12-11T13:58:27-0600] [ALPM] upgraded bluez-utils (5.70-1 -> 5.70-2)
[2023-12-11T13:58:28-0600] [ALPM] upgraded libkdegames (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:28-0600] [ALPM] upgraded bomber (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:28-0600] [ALPM] upgraded bovo (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:28-0600] [ALPM] upgraded kdecoration (5.27.9-1 -> 5.27.10-1)
[2023-12-11T13:58:28-0600] [ALPM] upgraded breeze (5.27.9-1 -> 5.27.10-1)
[2023-12-11T13:58:28-0600] [ALPM] upgraded breeze-gtk (5.27.9-1 -> 5.27.10-1)
[2023-12-11T13:58:28-0600] [ALPM] upgraded calendarsupport (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:29-0600] [ALPM] upgraded candy-icons-git (r1098.9b0cedc-1 -> r1105.ada73e9-1)
[2023-12-11T13:58:29-0600] [ALPM] upgraded cmake (3.27.9-1 -> 3.28.0-1)
[2023-12-11T13:58:29-0600] [ALPM] upgraded kirigami-addons5 (0.11.0-6 -> 0.11.0-7)
[2023-12-11T13:58:29-0600] [ALPM] upgraded colord-kde (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:30-0600] [ALPM] upgraded containerd (1.7.10-1 -> 1.7.11-1)
[2023-12-11T13:58:30-0600] [ALPM] upgraded libkexiv2 (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:30-0600] [ALPM] upgraded kio-extras (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:30-0600] [ALPM] upgraded dolphin (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:30-0600] [ALPM] upgraded dolphin-plugins (23.08.3-2 -> 23.08.4-1)
[2023-12-11T13:58:30-0600] [ALPM] upgraded dotnet-host (8.0.0.sdk100-2 -> 8.0.0.sdk100-3)
[2023-12-11T13:58:31-0600] [ALPM] upgraded dotnet-runtime (8.0.0.sdk100-2 -> 8.0.0.sdk100-3)
[2023-12-11T13:58:31-0600] [ALPM] upgraded drkonqi (5.27.9-2 -> 5.27.10-1)
[2023-12-11T13:58:31-0600] [ALPM] upgraded dwarfs (0.7.2-1.1 -> 0.7.3-1)
[2023-12-11T13:58:31-0600] [ALPM] upgraded elisa (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:31-0600] [ALPM] upgraded eza (0.16.2-1 -> 0.16.3-1)
[2023-12-11T13:58:31-0600] [ALPM] upgraded ffmpegthumbs (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:31-0600] [ALPM] upgraded filelight (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:32-0600] [ALPM] upgraded fish (3.6.1-1 -> 3.6.4-1)
[2023-12-11T13:58:32-0600] [ALPM] upgraded gamescope (3.13.16-1 -> 3.13.17-1)
[2023-12-11T13:58:34-0600] [ALPM] upgraded go (2:1.21.4-1 -> 2:1.21.5-1)
[2023-12-11T13:58:34-0600] [ALPM] upgraded goverlay-git (0.9.1.r88.g0e0a78f-1 -> 0.9.1.r115.g3af65f0-1)
[2023-12-11T13:58:35-0600] [ALPM] upgraded granatier (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:35-0600] [ALPM] upgraded libkdcraw5 (23.08.3-3 -> 23.08.4-1)
[2023-12-11T13:58:35-0600] [ALPM] upgraded gwenview (23.08.3-2 -> 23.08.4-1)
[2023-12-11T13:58:35-0600] [ALPM] upgraded ipp-usb (0.9.23-1 -> 0.9.24-1)
[2023-12-11T13:58:35-0600] [ALPM] upgraded jamesdsp (2.6.1-1.1 -> 2.7.0-1)
[2023-12-11T13:58:35-0600] [ALPM] upgraded joycond-git (v0.1.0.r53.gcdec328-1 -> v0.1.0.r54.g9d1f509-1)
[2023-12-11T13:58:35-0600] [ALPM] upgraded kaccounts-providers (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:35-0600] [ALPM] upgraded kactivitymanagerd (5.27.9-1 -> 5.27.10-1)
[2023-12-11T13:58:35-0600] [ALPM] upgraded libkmahjongg (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:35-0600] [ALPM] upgraded kajongg (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:35-0600] [ALPM] upgraded kamera (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:35-0600] [ALPM] upgraded kamoso (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:35-0600] [ALPM] upgraded kapman (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:36-0600] [ALPM] upgraded kate (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:36-0600] [ALPM] upgraded katomic (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:36-0600] [ALPM] upgraded kblackbox (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:36-0600] [ALPM] upgraded kblocks (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:36-0600] [ALPM] upgraded kbounce (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:36-0600] [ALPM] upgraded kbreakout (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:36-0600] [ALPM] upgraded kcalc (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:36-0600] [ALPM] upgraded kcron (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:36-0600] [ALPM] upgraded kde-cli-tools (5.27.9-1 -> 5.27.10-1)
[2023-12-11T13:58:36-0600] [ALPM] upgraded kde-gtk-config (5.27.9-1 -> 5.27.10-1)
[2023-12-11T13:58:36-0600] [ALPM] upgraded kdeconnect (23.08.3-2 -> 23.08.4-1)
[2023-12-11T13:58:36-0600] [ALPM] upgraded kdegraphics-mobipocket (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:36-0600] [ALPM] upgraded kdegraphics-thumbnailers (23.08.3-2 -> 23.08.4-1)
[2023-12-11T13:58:37-0600] [ALPM] upgraded kdenetwork-filesharing (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:37-0600] [ALPM] upgraded kdepim-runtime (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:37-0600] [ALPM] upgraded libksysguard (5.27.9-1 -> 5.27.10-1)
[2023-12-11T13:58:37-0600] [ALPM] upgraded ksystemstats (5.27.9-1 -> 5.27.10-1)
[2023-12-11T13:58:37-0600] [ALPM] upgraded milou (5.27.9-1 -> 5.27.10-1)
[2023-12-11T13:58:37-0600] [ALPM] upgraded layer-shell-qt (5.27.9-1 -> 5.27.10-1)
[2023-12-11T13:58:37-0600] [ALPM] upgraded libkscreen (5.27.9-1 -> 5.27.10-1)
[2023-12-11T13:58:37-0600] [ALPM] upgraded kscreenlocker (5.27.9-1 -> 5.27.10-1)
[2023-12-11T13:58:38-0600] [ALPM] upgraded kwin (5.27.9-1 -> 5.27.10-1)
[2023-12-11T13:58:38-0600] [ALPM] upgraded plasma-integration (5.27.9-1 -> 5.27.10-1)
[2023-12-11T13:58:38-0600] [ALPM] upgraded kpipewire (5.27.9-1 -> 5.27.10-1)
[2023-12-11T13:58:38-0600] [ALPM] upgraded kio-fuse (5.0.1-2 -> 5.1.0-1)
[2023-12-11T13:58:38-0600] [ALPM] upgraded oxygen-sounds (5.27.9-1 -> 5.27.10-1)
[2023-12-11T13:58:39-0600] [ALPM] upgraded plasma-workspace (5.27.9.1-3 -> 5.27.10-1)
[2023-12-11T13:58:40-0600] [ALPM] upgraded kdeplasma-addons (5.27.9-1 -> 5.27.10-1)
[2023-12-11T13:58:40-0600] [ALPM] upgraded kdf (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:40-0600] [ALPM] upgraded kdialog (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:40-0600] [ALPM] upgraded kdiamond (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:40-0600] [ALPM] upgraded keditbookmarks (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:40-0600] [ALPM] upgraded kfind (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:40-0600] [ALPM] upgraded kfourinline (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:40-0600] [ALPM] upgraded systemsettings (5.27.9-1 -> 5.27.10-1)
[2023-12-11T13:58:40-0600] [ALPM] installed kgamma (5.27.10-2)
[2023-12-11T13:58:40-0600] [ALPM] upgraded kget (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:40-0600] [ALPM] upgraded kgoldrunner (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:40-0600] [ALPM] upgraded khelpcenter (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:40-0600] [ALPM] upgraded khotkeys (5.27.9-1 -> 5.27.10-1)
[2023-12-11T13:58:41-0600] [ALPM] upgraded kigo (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:41-0600] [ALPM] upgraded killbots (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:41-0600] [ALPM] upgraded libdecor (0.2.1-1 -> 0.2.1-2)
[2023-12-11T13:58:41-0600] [ALPM] upgraded kinfocenter (5.27.9-1 -> 5.27.10-1)
[2023-12-11T13:58:41-0600] [ALPM] upgraded kio-gdrive (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:41-0600] [ALPM] upgraded kiriki (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:41-0600] [ALPM] upgraded kjumpingcube (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:41-0600] [ALPM] upgraded kleopatra (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:41-0600] [ALPM] upgraded klickety (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:41-0600] [ALPM] upgraded klines (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:41-0600] [ALPM] upgraded kmahjongg (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:41-0600] [ALPM] upgraded kmail-account-wizard (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:41-0600] [ALPM] upgraded mbox-importer (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:41-0600] [ALPM] upgraded pim-data-exporter (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:41-0600] [ALPM] upgraded libksieve (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:42-0600] [ALPM] upgraded pim-sieve-editor (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:42-0600] [ALPM] upgraded kontactinterface (23.08.3-2 -> 23.08.4-1)
[2023-12-11T13:58:42-0600] [ALPM] upgraded ktnef (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:42-0600] [ALPM] upgraded kmail (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:42-0600] [ALPM] upgraded kmenuedit (5.27.9-1 -> 5.27.10-1)
[2023-12-11T13:58:42-0600] [ALPM] upgraded kmines (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:42-0600] [ALPM] upgraded knavalbattle (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:42-0600] [ALPM] upgraded knetwalk (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:42-0600] [ALPM] upgraded knights (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:42-0600] [ALPM] upgraded kolf (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:42-0600] [ALPM] upgraded kollision (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:42-0600] [ALPM] upgraded libkomparediff2 (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:42-0600] [ALPM] upgraded kompare (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:42-0600] [ALPM] upgraded konquest (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:42-0600] [ALPM] upgraded konsole (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:43-0600] [ALPM] upgraded kpat (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:43-0600] [ALPM] upgraded kpmcore (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:43-0600] [ALPM] upgraded krdc (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:43-0600] [ALPM] upgraded kreversi (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:43-0600] [ALPM] upgraded krfb (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:43-0600] [ALPM] upgraded ksanecore (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:43-0600] [ALPM] upgraded kscreen (5.27.9-1 -> 5.27.10-1)
[2023-12-11T13:58:43-0600] [ALPM] upgraded kshisen (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:43-0600] [ALPM] upgraded ksirk (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:43-0600] [ALPM] upgraded ksnakeduel (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:43-0600] [ALPM] upgraded kspaceduel (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:43-0600] [ALPM] upgraded ksquares (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:43-0600] [ALPM] upgraded ksshaskpass (5.27.9-1 -> 5.27.10-1)
[2023-12-11T13:58:43-0600] [ALPM] upgraded ksudoku (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:43-0600] [ALPM] upgraded ksystemlog (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:43-0600] [ALPM] upgraded kteatime (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:43-0600] [ALPM] upgraded libktorrent (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:44-0600] [ALPM] upgraded ktorrent (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:44-0600] [ALPM] upgraded ktuberling (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:44-0600] [ALPM] upgraded kubrick (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:44-0600] [ALPM] upgraded kwallet-pam (5.27.9-1 -> 5.27.10-1)
[2023-12-11T13:58:44-0600] [ALPM] upgraded kwalletmanager (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:44-0600] [ALPM] upgraded kwayland-integration (5.27.9-1 -> 5.27.10-1)
[2023-12-11T13:58:44-0600] [ALPM] upgraded kwrited (5.27.9-1 -> 5.27.10-1)
[2023-12-11T13:58:44-0600] [ALPM] upgraded lib32-curl (8.4.0-2 -> 8.5.0-1)
[2023-12-11T13:58:44-0600] [ALPM] upgraded lib32-util-linux (2.39.2-1 -> 2.39.3-1)
[2023-12-11T13:58:44-0600] [ALPM] upgraded lib32-glib2 (2.78.1-1 -> 2.78.3-1)
[2023-12-11T13:58:44-0600] [ALPM] upgraded lib32-libcurl-compat (8.4.0-2 -> 8.5.0-1)
[2023-12-11T13:58:44-0600] [ALPM] upgraded lib32-libcurl-gnutls (8.4.0-2 -> 8.5.0-1)
[2023-12-11T13:58:44-0600] [ALPM] upgraded lib32-libnl (3.8.0-1 -> 3.9.0-1)
[2023-12-11T13:58:44-0600] [ALPM] upgraded lib32-libxml2 (2.12.1-1 -> 2.12.2-1)
[2023-12-11T13:58:44-0600] [ALPM] upgraded lib32-systemd (254.6-1 -> 255-1)
[2023-12-11T13:58:44-0600] [ALPM] upgraded libcurl-compat (8.4.0-2 -> 8.5.0-1)
[2023-12-11T13:58:44-0600] [ALPM] upgraded libcurl-gnutls (8.4.0-2 -> 8.5.0-1)
[2023-12-11T13:58:44-0600] [ALPM] upgraded libksane (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:45-0600] [ALPM] upgraded libnbd (1.18.1-2 -> 1.18.1-3)
[2023-12-11T13:58:45-0600] [ALPM] upgraded libpamac-aur (11.6.2-2 -> 11.6.3-0)
[2023-12-11T13:58:45-0600] [ALPM] upgraded libpdfium-nojs (5993.r1.6e55da0c45-1 -> 6099.r0.a3895af47f-1)
[2023-12-11T13:58:48-0600] [ALPM] upgraded libreoffice-fresh (7.6.3-3 -> 7.6.4-1)
[2023-12-11T13:58:51-0600] [ALPM] upgraded linux-zen (6.6.4.zen1-1 -> 6.6.6.zen1-1)
[2023-12-11T13:58:56-0600] [ALPM] upgraded linux-zen-headers (6.6.4.zen1-1 -> 6.6.6.zen1-1)
[2023-12-11T13:58:56-0600] [ALPM] upgraded lskat (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:56-0600] [ALPM] upgraded luajit (2.1.1700008891-1 -> 2.1.1702233742-1)
[2023-12-11T13:58:57-0600] [ALPM] upgraded nicotine-plus-git (3.3.0.dev6.r10173.b821131b0-1 -> 3.3.0.dev6.r10178.81928a8cc-1)
[2023-12-11T13:58:57-0600] [ALPM] upgraded npm (10.2.4-1 -> 10.2.5-1)
[2023-12-11T13:58:57-0600] [ALPM] upgraded nvm (0.39.5-1 -> 0.39.7-1)
[2023-12-11T13:58:58-0600] [ALPM] upgraded okular (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:58-0600] [ALPM] upgraded ostree (2023.7-1 -> 2023.8-1)
[2023-12-11T13:58:58-0600] [ALPM] upgraded palapeli (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:58-0600] [ALPM] upgraded pamac-aur (11.6.0-4 -> 11.7.0-2)
[2023-12-11T13:58:58-0600] [ALPM] upgraded partitionmanager (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:58-0600] [ALPM] upgraded picmi (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:58:58-0600] [ALPM] upgraded pkgconf (2.0.3-1 -> 2.1.0-2)
[2023-12-11T13:58:58-0600] [ALPM] upgraded plasma-browser-integration (5.27.9-1 -> 5.27.10-1)
[2023-12-11T13:58:58-0600] [ALPM] upgraded polkit-kde-agent (5.27.9-1 -> 5.27.10-1)
[2023-12-11T13:58:58-0600] [ALPM] upgraded powerdevil (5.27.9-2 -> 5.27.10-1)
[2023-12-11T13:58:59-0600] [ALPM] upgraded plasma-desktop (5.27.9-1 -> 5.27.10-1)
[2023-12-11T13:58:59-0600] [ALPM] upgraded plasma-disks (5.27.9-1 -> 5.27.10-1)
[2023-12-11T13:58:59-0600] [ALPM] upgraded plasma-firewall (5.27.9-1 -> 5.27.10-1)
[2023-12-11T13:58:59-0600] [ALPM] upgraded plasma-nm (5.27.9-1 -> 5.27.10-1)
[2023-12-11T13:58:59-0600] [ALPM] upgraded plasma-pa (5.27.9-2 -> 5.27.10-1)
[2023-12-11T13:58:59-0600] [ALPM] upgraded plasma-systemmonitor (5.27.9-1 -> 5.27.10-1)
[2023-12-11T13:58:59-0600] [ALPM] upgraded plasma-thunderbolt (5.27.9-1 -> 5.27.10-1)
[2023-12-11T13:58:59-0600] [ALPM] upgraded plasma-vault (5.27.9-1 -> 5.27.10-1)
[2023-12-11T13:58:59-0600] [ALPM] upgraded plasma-wayland-session (5.27.9.1-3 -> 5.27.10-1)
[2023-12-11T13:59:00-0600] [ALPM] upgraded plasma-workspace-wallpapers (5.27.9-1 -> 5.27.10-1)
[2023-12-11T13:59:00-0600] [ALPM] upgraded podofo (0.10.2-1 -> 0.10.3-1)
[2023-12-11T13:59:00-0600] [ALPM] upgraded postgresql-libs (15.4-2 -> 16.1-1)
[2023-12-11T13:59:00-0600] [ALPM] upgraded print-manager (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:59:00-0600] [ALPM] upgraded python-feedparser (6.0.10-3 -> 6.0.11-1)
[2023-12-11T13:59:01-0600] [ALPM] upgraded python-pygments (2.16.1-1 -> 2.17.2-1)
[2023-12-11T13:59:01-0600] [ALPM] upgraded retroarch-autoconfig-udev-git (r2207.18b4579-1 -> r2208.a57f148-1)
[2023-12-11T13:59:03-0600] [ALPM] upgraded rust (1:1.74.0-1 -> 1:1.74.1-1)
[2023-12-11T13:59:03-0600] [ALPM] upgraded scrcpy (2.2-1 -> 2.3.1-1)
[2023-12-11T13:59:03-0600] [ALPM] upgraded sddm-kcm (5.27.9-1 -> 5.27.10-1)
[2023-12-11T13:59:03-0600] [ALPM] upgraded sdl2_image (2.6.3-1 -> 2.8.0-1)
[2023-12-11T13:59:03-0600] [ALPM] upgraded seabios (1.16.2-2 -> 1.16.3-1)
[2023-12-11T13:59:04-0600] [ALPM] upgraded signal-desktop (6.40.0-1 -> 6.41.0-1)
[2023-12-11T13:59:04-0600] [ALPM] upgraded skanlite (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:59:04-0600] [ALPM] upgraded snapper (0.10.6-1 -> 0.10.7-1)
[2023-12-11T13:59:04-0600] [ALPM] upgraded spectacle (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:59:05-0600] [ALPM] upgraded spotify (1:1.2.25.1011-1 -> 1:1.2.26.1187-1)
[2023-12-11T13:59:05-0600] [ALPM] upgraded systemd-sysvcompat (254.6-2 -> 255-1)
[2023-12-11T13:59:05-0600] [ALPM] upgraded ugrep (4.3.4-1 -> 4.3.6-1)
[2023-12-11T13:59:05-0600] [ALPM] upgraded xdg-desktop-portal-kde (5.27.9-1 -> 5.27.10-1)
[2023-12-11T13:59:06-0600] [ALPM] upgraded yakuake (23.08.3-1 -> 23.08.4-1)
[2023-12-11T13:59:07-0600] [ALPM] upgraded yarn (1.22.19-1 -> 1.22.21-1)
You only have this problem in games, right?
Are the GPU temperatures higher than before the update or is it just the fans that are the problem?
You have Steam/Proton/Wine installed, correct? Does this only happen with these games (that run via the wrapper) or also with the native KDE games?
The pacman.log looks unremarkable, with a few exceptions only standard packages and KDE stuff.
What happens with the new 6.6.6-zen1-1-zen, have you tested that?
Yes, likely because anything else I do doesn’t put much stress on my GPU.
Temps seem to be about the same, according to fancontrol-gui, so I assume it’s just the fans.
I do, and it seems to be both games that have native Linux builds and ones running via Proton. I haven’t given much of the KDE specific games a go I’ll admit though.
I’ve not tested the new one, as I’ve been running on the aforementioned snapshot for the sake of not putting my GPU through this more than necessary. I will try and update later today once I am home and will report back once I have.
I am on the latest version of the zen kernel now and it seems the fans have returned to their normal function. I am running an AMD Raedon RTX 5700XT, if I recall correctly the drivers for AMD GPUs are integrated into the kernel so perhaps there was something up with one included that was fixed with an update. Either way, as the problem is gone I am going to mark this as solved.
A bug in the kernel module was my main suspicion :slight_smile:
