Same as above. It didn't happen in Ubuntu. So I am inclined to believe there is some kind of a privacy setting that's stopping it from remembering my account.
Can you provide your inxi -Fxz
within ~~~ before and after
In addition to the inxi information, can you share how you installed minecraft?
That's twice now.
Third time you turn into a pumpkin!!!
There is absolutely 0 information of the setup, We aren't astrologists we won't dream of it. You need to help us to help you.
Moving to your issue
There isn't, it's not the fault of the garuda dev team. I own both tlauncher and premium not an issue.
Placeholder for magic ball on vacation pic which I don't have
System: Kernel: 5.13.9-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: KDE Plasma 5.22.4
Machine: Type: Desktop System: Hewlett-Packard product: P6-2358IN v: N/A serial:
Mobo: Foxconn model: 2ABF v: 3.10 serial: UEFI: AMI v: 8.08 date: 09/14/2012
CPU: Info: Dual Core model: Intel Core i3-2130 bits: 64 type: MT MCP arch: Sandy Bridge rev: 7
cache: L2: 3 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 27138
Speed: 2637 MHz min/max: 1600/3400 MHz Core speeds (MHz): 1: 2637 2: 2053 3: 1770 4: 3073
Graphics: Device-1: NVIDIA GK208B [GeForce GT 710] vendor: Gigabyte driver: nvidia v: 470.57.02
bus-ID: 01:00.0
Device-2: GEMBIRD Generic UVC 1.00 camera [AppoTech AX2311] type: USB driver: uvcvideo
bus-ID: 1-1.2:3
Display: x11 server: X.Org 1.20.13 driver: loaded: nvidia resolution: 1366x768~60Hz
OpenGL: renderer: N/A v: N/A direct render: N/A
Audio: Device-1: Intel 6 Series/C200 Series Family High Definition Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Device-2: NVIDIA GK208 HDMI/DP Audio vendor: Gigabyte driver: snd_hda_intel v: kernel
bus-ID: 01:00.1
Sound Server-1: ALSA v: k5.13.9-zen1-1-zen running: yes
Network: Device-1: Ralink RT5390R 802.11bgn PCIe Wireless Network Adapter vendor: Hewlett-Packard
driver: rt2800pci v: 2.3.0 port: e000 bus-ID: 03:00.0
IF: wlp3s0 state: down mac:
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard
driver: r8169 v: kernel port: d000 bus-ID: 04:00.0
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac:
IF-ID-1: anbox0 state: down mac:
Drives: Local Storage: total: 465.76 GiB used: 37.43 GiB (8.0%)
ID-1: /dev/sda vendor: Seagate model: ST500DM002-1BD142 size: 465.76 GiB
Partition: ID-1: / size: 465.5 GiB used: 37.43 GiB (8.0%) fs: btrfs dev: /dev/sda2
ID-2: /boot/efi size: 256 MiB used: 562 KiB (0.2%) fs: vfat dev: /dev/sda1
ID-3: /home size: 465.5 GiB used: 37.43 GiB (8.0%) fs: btrfs dev: /dev/sda2
ID-4: /var/log size: 465.5 GiB used: 37.43 GiB (8.0%) fs: btrfs dev: /dev/sda2
ID-5: /var/tmp size: 465.5 GiB used: 37.43 GiB (8.0%) fs: btrfs dev: /dev/sda2
Swap: ID-1: swap-1 type: zram size: 7.72 GiB used: 29 MiB (0.4%) dev: /dev/zram0
Sensors: System Temperatures: cpu: 58.0 C mobo: 27.8 C gpu: nvidia temp: 50 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 37%
Info: Processes: 240 Uptime: 3h 24m Memory: 7.72 GiB used: 3.2 GiB (41.5%) Init: systemd Compilers:
gcc: 11.1.0 Packages: 1640 Shell: fish v: 3.3.1 inxi: 3.3.06
I replied. I didnt think anyone would see this question. That happens to me on Stack Overflow a lot
I installed Minecraft using the Add/Remove Software app? Idk what its called.
Here ya go also
cache: L2: 3 MiB
bus-ID: 01:00.0
bus-ID: 1-1.2:3
Display: x11 server: [X.Org](http://x.org/) 1.20.13 driver: loaded: nvidia resolution: 1366x768~60Hz
bus-ID: 01:00.1
This is not a chatting app, Please keep multiple messages into instead of reply to every single thing in a different message, makes it hard to read.
Which version of minecraft are you running? Which launcher
Ok. Im new here so I didnt know. I'll keep that in mind. Also, it is the regular minecraft launcher from The Add/Remove Software app if that's what it's called. Oh and also the version doesnt matter cause its the problem of the launcher itself and not the game but, anyway. I run 1.8.9.
