Hi, Everybody! Happy belated Ho-Ho.
I've done some searching on the forums, and found nothing related to the problem I encountered. Hopefully this is already on the forum using some terms I missed, or this is an easy fix I'm overlooking. Heck, maybe even a problem isolated to just me, and the current position of the planets, I don't know...
Before going into my problem, I have attached the output of inxi with the appropriate flags, as the automated message requested when I began writing this. I've attached the output below:
Kernel: 5.10.88-2-lts x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=d6730878-9f75-4983-b000-e35a0eb2cb1b rw [email protected]
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
vt: 7 dm: LightDM 1.30.0 Distro: Garuda Linux base: Arch Linux
Type: Desktop Mobo: Micro-Star model: B450 TOMAHAWK MAX (MS-7C02) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: 3.B0
date: 05/12/2021
Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201009
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 4158 high: 4175 min/max: N/A cores: 1: 4171 2: 4162
3: 4172 4: 4172 5: 3970 6: 4150 7: 4172 8: 4175 9: 4175 10: 4175 11: 4175
12: 4173 13: 4175 14: 4172 15: 4164 16: 4158 17: 4174 18: 4175 19: 4172
20: 4140 21: 4146 22: 4166 23: 4153 24: 4173 bogomips: 200417
IBRS_FW, STIBP: always-on, RSB filling
Device-1: NVIDIA GA106 [GeForce RTX 3060] vendor: ASUSTeK driver: nvidia
v: 495.46 alternate: nouveau,nvidia_drm bus-ID: 26:00.0
chip-ID: 10de:2503 class-ID: 0300
Display: x11 server: X.Org 1.21.1.2 compositor: xfwm4 v: 4.16.1 driver:
loaded: nvidia unloaded: modesetting alternate: fbdev,nouveau,nv,vesa
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 5760x1080 s-dpi: 96 s-size: 1524x286mm (60.0x11.3")
s-diag: 1551mm (61")
Monitor-1: DP-0 res: 1920x1080 dpi: 82 size: 597x336mm (23.5x13.2")
diag: 685mm (27")
Monitor-2: DP-2 res: 1920x1080 dpi: 82 size: 597x336mm (23.5x13.2")
diag: 685mm (27")
Monitor-3: DP-4 res: 1920x1080 dpi: 82 size: 597x336mm (23.5x13.2")
diag: 685mm (27")
Device-1: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 26:00.1 chip-ID: 10de:228e class-ID: 0403
driver: snd_hda_intel v: kernel bus-ID: 28:00.4 chip-ID: 1022:1487
Device-3: SteelSeries ApS SteelSeries Arctis 7 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-3:3 chip-ID: 1038:12ad
Sound Server-1: ALSA v: k5.10.88-2-lts running: yes
Sound Server-5: PipeWire v: 0.3.42 running: yes
vendor: Micro-Star MSI driver: r8169 v: kernel port: d000 bus-ID: 22:00.0
Local Storage: total: 1.85 TiB used: 17.77 GiB (0.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNVS2000GB
size: 1.82 TiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: S8442101
temp: 36.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: A-Data
model: USB Flash Drive size: 28.91 GiB block-size: physical: 512 B
logical: 512 B type: SSD serial: <filter> rev: 1100 scheme: MBR
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
used: 17.77 GiB (1.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 62.79 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 37.2 C mobo: N/A gpu: nvidia temp: 40 C
Processes: 455 Uptime: 3h 17m wakeups: 0 Memory: 62.79 GiB
used: 6.33 GiB (10.1%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1465 lib: 354 Shell: Bash
v: 5.1.12 running-in: xfce4-terminal inxi: 3.3.11
Hopefully the above formats correctly. I've not had to use this forum before, and I don't get a preview of what it will look like before posting.
I decided a fresh installation was in order, and encountered a problem with the latest XFCE4 version of Garuda. Specifically, the problem is with the custom built tools that come with it, such as garuda-gamer, and garuda-assistant. After performing post-install setup, Any Garuda tool that calls Alacritty to perform its task will silently fail that task with no output to the terminal, and no logs written to dmesg when called. Those tools will continue as if no error occurred.
After multiple attempts, I've managed to reliably reproduce the problem by performing the following steps:
From a live environment, install Garuda Harpy-Eagle 211129, XFCE edition, fresh onto a local disk
After installation, boot into the freshly installed environment. Perform login with your main account, not guest.
After XFCE4 loads, I will be automatically prompted to perform post-install setup using the setup assistant. Alternatively, I will receive a warning in the icon tray instructing them to perform the post-install setup, or else the OS will be unstable/unusable.
When the post-install setup is started, I'm asked if I wish to update the distribution. If I say yes, Alacritty will launch and perform a full system update.
After the full system update, the additional software questions will occur as normal, but when it is time to pull the packages through pacman, Alacritty will not launch, and the Setup Assistant will close as if it had performed the task successfully, even though it clearly didn't.
Any Garuda tool, such as garuda-assistant, or garuda-gamer, which call Alacritty to perform a task will silently fail to launch it, but will continue as if it was successful. Effectively making those tools useless. The only observable output is that the applicable Garuda tool window will sometimes "blink".
For example, let's say, after step 4, I went to remove the guest account using Garuda Assistant. When I uncheck that option in the Settings tab, and hit apply, the Garuda Assistant window will simply blink, rather than launch Alacritty to uninstall the required package to disable Guest User functionality. If I go back to Garuda Assistant, and check, the setting for the guest account will have never changed.
If I say no on step 4, or perform any task with the Garuda tools that launches a terminal on or before step 4, Alacritty will still launch and perform the tasks the Garuda tools have delegated. This will still be the case until after step 4, or an update is performed manually.
I have also tried KDE Dragonized edition, and I can confirm that this does NOT occur on that version.
I have tried the following for troubleshooting, all have had no success:
Made an alias between Alacritty, and xfce4-terminal.
Installed the git version of all impacted Garuda tools from the Garuda repos
Installed a different version of Alacritty
Installing Garuda tools from the package cache (I had a hunch that wouldn't work, to be honest)
Since I'm rather new to this distribution (6-ish months of use), I'm not going to opine on what the root cause would be. I'll leave that to the experts out there.
I have managed to reproduce this around 3 times now with 3 fresh installations on the same PC. Since I had to get that computer fully running again, I finished the rest of my setup by hand, rather than through the Garuda issued tools. This machine can still be used for testing, and fixing those tools, but if a fresh install is needed from me, I will have to do it in a VM for you.
While it's more of an inconvenience for me, this will be a major show-stopper for new users. Especially so, since Garuda is advertised as being friendly to new users, and emphasizes heavily that new users must follow the provided instructions. Problem is, in this case, following those instructions breaks the tools Garuda provides to administer key parts of this distribution. What makes this worse is that when following the instructions as provided, basic software such as a package manager will not install, which would leave a new user stuck right after installation.
I have been getting by with a few workarounds, with limited success:
Calling some of the Garuda tools with sudo or doas causes Alacritty to launch successfully, and perform the task it was delegated. So installing some pieces of software, or changing system settings is still possible. Not all options and tools work with this workaround. In addition, some of the settings and tools Garuda provides must be run as the user in question, rather than root.
If the commands that the Garuda tool was going to execute are already known beforehand, they can simply be called from any terminal instance, and run successfully. This also has limited success because only the developers of that tool, or people with extensive experience with Garuda would know what those commands are that the tools run. This leaves new users hosed, as they'd have no visibility into what those commands are.
Hopefully this is enough information for everybody. Please let me know if you need me to try anything on my end, or need more information.
