Hardware configuration opens up settings, garuda settings never opens
Hi everyone,
I am trying to install new drivers with the hardware configuration menu, however when I try to open it it will only open the system settings.
trying to get to it from garuda settings manager is also not working. As the settings manager is just not opening.
What am I doing wrong?
Full output of my garuda-inxi
Kernel: 6.6.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=bc0be5f8-d708-4a3c-94de-eb2756e14569 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_wayland vt: 1
Type: Desktop Mobo: Micro-Star model: MAG B660M MORTAR WIFI DDR4 (MS-7D42)
v: 1.0 serial: <superuser required> UEFI: American Megatrends LLC. v: 1.C0
date: 05/19/2023
Info: model: 12th Gen Intel Core i5-12400F bits: 64 type: MT MCP
microcode: 0x32
L1: 480 KiB desc: d-6x48 KiB; i-6x32 KiB L2: 7.5 MiB desc: 6x1.2 MiB
L3: 18 MiB desc: 1x18 MiB
Speed (MHz): avg: 4000 min/max: 800/4400 scaling: driver: intel_pstate
governor: powersave cores: 1: 4000 2: 4000 3: 4000 4: 4000 5: 4000 6: 4000
7: 4000 8: 4000 9: 4000 10: 4000 11: 4000 12: 4000 bogomips: 59904
Device-1: NVIDIA AD106 [GeForce RTX 4060 Ti 16GB] vendor: Gigabyte
driver: N/A alternate: nouveau non-free: 545.xx+
status: current (as of 2023-10) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 8
bus-ID: 01:00.0 chip-ID: 10de:2805 class-ID: 0300
alternate: fbdev,nv,vesa gpu: N/A display-ID: 0
Monitor-1: Unknown-1 res: 1920x1080 size: N/A modes: N/A
API: EGL v: 1.5 platforms: device: 0 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: swrast wayland: drv: swrast x11: drv: swrast
API: OpenGL v: 4.5 vendor: mesa v: 23.3.2-arch1.2 glx-v: 1.4
direct-render: yes renderer: llvmpipe (LLVM 16.0.6 256 bits)
device-ID: ffffffff:ffffffff memory: 30.47 GiB unified: yes
display-ID: :1.0
API: Vulkan v: 1.3.274 layers: 7 device: 0 type: cpu name: llvmpipe (LLVM
16.0.6 256 bits) driver: mesa llvmpipe v: 23.3.2-arch1.2 (LLVM 16.0.6)
Device-1: Intel Alder Lake-S HD Audio vendor: Micro-Star MSI
bus-ID: 00:1f.3 chip-ID: 8086:7ad0 class-ID: 0403
Device-2: NVIDIA vendor: Gigabyte driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 8 bus-ID: 01:00.1 chip-ID: 10de:22bd
API: ALSA v: k6.6.9-zen1-1-zen status: kernel-api tools: N/A
Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 4000 bus-ID: 04:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:7 chip-ID: 8087:0026
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.2
lmp-v: 11 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 931.51 GiB used: 84.14 GiB (9.0%)
model: WD BLACK SN750 SE 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 711250WD temp: 39.9 C scheme: GPT
used: 84.14 GiB (9.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 31.2 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 46.0 C mobo: N/A
Processes: 312 Uptime: 4m wakeups: 0 Memory: total: 32 GiB
available: 31.2 GiB used: 3.74 GiB (12.0%) Init: systemd v: 255
pm: pacman pkgs: 1364 libs: 425 tools: octopi,paru Shell: fish v: 3.7.0
Garuda (2.6.22-1):
System install date:     2023-12-22
Last full system update: 2024-01-04
Starting garuda-settings-manager from a terminal says
garuda-settings-manager: error while loading shared libraries: libicuuc.so.73: cannot open shared object file: No such file or directory
fixed by reinstalling it with sudo pacman -S garuda-settings-manager and now it works
I think this is consequence of the “local is newer than” thing: when reinstalling, pacman warned downgrading package garuda-settings-manager (1.0.2-5 => 1.0.2-3)
If there are also other problematic ones, try reinstalling them too, especially if you saw the “local is newer” when upgrading.
At Garuda devs: would it be a good idea to handle this case in garuda-update?
