Hardware Acceleration not working
So, first minecraft and blender were laggy for some reason but wine/proton games were fine. So I looked around for why and saw llvmpipe being used for my Graphics Processor and OpenGL. So I started researching and found a small guide that I thought would’ve fixed it that involved editing “/etc/environment” by putting:
QT_QPA_PLATFORMTHEME="wayland;xcb"
GBM_BACKEND=nvidia-drm
__GLX_VENDOR_LIBRARY_NAME=nvidia
ENABLE_VKBASALT=1
LIBVA_DRIVER_NAME=nvidia
(on X11 honestly didn’t notice the wayland, tho switching to wayland did nothing)
but once rebooting, the desktop background became black and system monitor is saying Hardware Acceleration is off. It’s still recognizing my Nvidia GPU but not using it I guess? Even undoing and going back to any snapshot does not work and the problem persists. I’ve reinstalled dkms, nvidia-dkms, tried new kernals, completely uninstalling all GPU drivers and reinstalling but nothing.
I’ve been searching but I can’t find anything that works for me and I’m at a loss once again. Just hoping I didn’t brick my linux with this.
Thanks in advanced for the help.
Another thing I found out that may help troubleshoot, my steam games still function more or less normal with all this happening. Hope it helps.
Kernel: 6.6.39-1-lts arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=c9e5750d-6564-43d9-9812-a5c69f36d974 rw rootflags=subvol=@
nvme_load=YES loglevel=3 systemd.unified_cgroup_hierarchy=1 ibt=off
Desktop: KDE Plasma v: 6.1.2 tk: Qt v: N/A info: frameworks v: 6.3.0
Type: Desktop Mobo: ASUSTeK model: TUF GAMING X570-PLUS (WI-FI) v: Rev X.0x
BIOS: American Megatrends v: 4002 date: 06/15/2021
Device-1: gip0.0 model: Microsoft X-Box One pad serial: N/A
charge: 50% (should be ignored) rechargeable: yes status: not charging
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3621 high: 3800 min/max: 2200/4850 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3592 2: 3581
3: 3703 4: 3580 5: 3591 6: 3586 7: 3590 8: 3590 9: 3800 10: 3597 11: 3577
12: 3578 13: 3800 14: 3597 15: 3581 16: 3593 bogomips: 121420
Device-1: NVIDIA GA106 [GeForce RTX 3060] vendor: eVga.com. driver: nvidia
v: 555.58.02 alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current
(as of 2024-06; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 0a:00.0
chip-ID: 10de:2503 class-ID: 0300
Device-2: Valve 3D Camera driver: uvcvideo type: USB rev: 3.2
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-1.1:4 chip-ID: 28de:2400
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.1
compositor: kwin_x11 driver: X: loaded: N/A failed: nvidia gpu: nvidia
Screen-1: 0 s-res: 5120x1440 s-dpi: 107 s-size: 1216x342mm (47.87x13.46")
s-diag: 1263mm (49.73")
Monitor-1: DP-0 size-res: N/A modes: N/A
Monitor-2: DP-2 pos: right res: 2560x1440 dpi: 55
size: 1193x336mm (46.97x13.23") diag: 1239mm (48.8") modes: N/A
Monitor-3: DP-4 pos: primary,left res: 2560x1440 dpi: 55
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 1
drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: mesa v: 24.1.3-arch1.1
glx-v: 1.4 direct-render: yes renderer: llvmpipe (LLVM 18.1.8 256 bits)
device-ID: ffffffff:ffffffff memory: 122.76 GiB unified: yes
API: Vulkan v: 1.3.279 layers: 14 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 driver: nvidia v: 555.58.02
device-ID: 10de:2503 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.1.3-arch1.1 (LLVM
Device-1: NVIDIA GA106 High Definition Audio vendor: eVga.com.
bus-ID: 0a:00.1 chip-ID: 10de:228e class-ID: 0403
Device-3: Valve VR Radio driver: cdc_acm,hid-generic,usbhid type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1.3.2:11
chip-ID: 28de:2102 class-ID: 0a00 serial: <filter>
Device-4: Valve VR Radio & HMD Mic
lanes: 1 mode: 1.1 bus-ID: 1-1.3.3:13 chip-ID: 28de:2102 class-ID: 0102
Device-5: HP HyperX QuadCast S driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2.4:6
chip-ID: 03f0:0d8b class-ID: 0300 serial: <filter>
Device-6: Astro Gaming A50 driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:12
chip-ID: 9886:002c class-ID: 0300
API: ALSA v: k6.6.39-1-lts status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.1 status: active with: 1: pipewire-pulse
Device-1: Intel Wi-Fi 5 Wireless-AC 9x6x [Thunder Peak] driver: iwlwifi
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 05:00.0
vendor: ASUSTeK driver: r8168 v: 8.053.00-NAPI modules: r8169 pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 06:00.0 chip-ID: 10ec:8168
Info: services: NetworkManager, sshd, systemd-timesyncd
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-5:2
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.1
Local Storage: total: 16.83 TiB used: 2.55 TiB (15.1%)
model: WD BLACK SN770 2TB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 731100WD temp: 43.9 C scheme: MBR
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Samsung
fw-rev: 2B2QEXM7 temp: 49.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST14000DM001-2JC101
size: 12.73 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: DN01 scheme: GPT
model: WD2003FZEX-00SRLA0 size: 1.82 TiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 879.52 GiB (47.2%)
fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p1 maj-min: 259:2
ID-2: /home raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
used: 879.52 GiB (47.2%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p1
maj-min: 259:2
ID-3: /var/log raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
maj-min: 259:2
ID-4: /var/tmp raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
maj-min: 259:2
ID-1: swap-1 type: zram size: 125.71 GiB used: 84 MiB (0.1%) priority: 100
System Temperatures: cpu: 54.0 C mobo: N/A gpu: nvidia temp: 52 C
Memory: total: 128 GiB note: est. available: 125.71 GiB
used: 6.44 GiB (5.1%)
Processes: 436 Power: uptime: 7m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 50.24 GiB services: org_kde_powerdevil,
Packages: 2420 pm: pacman pkgs: 2411 libs: 609 tools: aura,
gnome-software, octopi, pamac, paru pm: flatpak pkgs: 9 Compilers:
clang: 18.1.8 gcc: 14.1.1 Shell: garuda-inxi default: fish v: 3.7.1
System install date:     2024-01-19
Last full system update: 2024-07-14
Failed units:            vmware.service
The problem has been fixed, something just appeared randomly in the taskbar (couldn’t catch the name) but it let me change a setting from “software” to “automatic” and now everythings back, graphics processor is still llvmpipe but I’ll figure that out another time.
