Some GUI effects stopped working like the Taskbars background turning to solid black, and the hot bar also turning black, The alt+tab animations stopped working and now is just a box with the names of the tabs, I didn't do any updates before this.
inxi -Fxxxa
System: Host: Hakai Kernel: 5.11.11-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=1c66e6c9-d4c5-4043-a709-e6ee2d6bd028 rw
Desktop: KDE Plasma 5.21.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM Distro: Garuda Linux
Machine: Type: Laptop System: Sony product: SVF1531GSAB v: C10J5E30 serial: Chassis: type: 10
serial:
Mobo: Sony model: VAIO serial: UEFI-[Legacy]: Insyde v: R1100DB date: 01/26/2016
CPU: Info: Dual Core model: Intel Core i7-4500U bits: 64 type: MT MCP arch: Haswell family: 6 model-id: 45 (69)
stepping: 1 microcode: 26 cache: L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 19156
Speed: 1796 MHz min/max: 800/3000 MHz Core speeds (MHz): 1: 1796 2: 2490 3: 1796 4: 1798
Graphics: Device-1: Intel Haswell-ULT Integrated Graphics vendor: Sony driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:0a16 class-ID: 0300
Device-2: NVIDIA GK208M [GeForce GT 740M] vendor: Sony driver: nouveau v: kernel bus-ID: 04:00.0 chip-ID: 10de:1292
class-ID: 0302
Device-3: Chicony Front Camera type: USB driver: uvcvideo bus-ID: 2-5:3 chip-ID: 04f2:b3aa class-ID: 0e02
serial: 0001
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: intel,nouveau unloaded: modesetting
alternate: fbdev,nv,vesa display-ID: :0 screens: 1
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4400 (HSW GT2) v: 4.5 Mesa 21.0.1 compat-v: 3.0 direct render: Yes
Audio: Device-1: Intel Haswell-ULT HD Audio vendor: Sony driver: snd_hda_intel v: kernel bus-ID: 00:03.0
chip-ID: 8086:0a0c class-ID: 0403
Device-2: Intel 8 Series HD Audio vendor: Sony driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9c20
Sound Server-1: ALSA v: k5.11.11-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.24 running: no
Network: Device-1: Broadcom BCM43142 802.11b/g/n vendor: Foxconn driver: wl v: kernel port: 5040 bus-ID: 02:00.0
chip-ID: 14e4:4365 class-ID: 0280
IF: wlp2s0 state: up mac: 0c:84:dc:fd:05:e9
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Sony driver: r8169 v: kernel port: 4000
bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp3s0 state: down mac: 78:84:3c:3b:a9:8e
Bluetooth: Device-1: Foxconn / Hon Hai BCM43142A0 type: USB driver: btusb v: 0.8 bus-ID: 2-4:2 chip-ID: 0489:e062
class-ID: fe01 serial: 0C84DCFD05EA
Report: ID: hci0 state: up address: 0C:84:DC:FD:05:EA
Drives: Local Storage: total: 465.76 GiB used: 25.59 GiB (5.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST9500325ASG size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s rotation: 5400 rpm serial: 5VEWSP5H rev: APM1 scheme: MBR
Partition: ID-1: / raw-size: 465.76 GiB size: 465.76 GiB (100.00%) used: 25.59 GiB (5.5%) fs: btrfs dev: /dev/sda1
maj-min: 8:1
ID-2: /home raw-size: 465.76 GiB size: 465.76 GiB (100.00%) used: 25.59 GiB (5.5%) fs: btrfs dev: /dev/sda1
maj-min: 8:1
ID-3: /var/log raw-size: 465.76 GiB size: 465.76 GiB (100.00%) used: 25.59 GiB (5.5%) fs: btrfs dev: /dev/sda1
maj-min: 8:1
ID-4: /var/tmp raw-size: 465.76 GiB size: 465.76 GiB (100.00%) used: 25.59 GiB (5.5%) fs: btrfs dev: /dev/sda1
maj-min: 8:1
ID-1: swap-1 type: zram size: 2.9 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-2: swap-2 type: zram size: 2.9 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-3: swap-3 type: zram size: 2.9 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-4: swap-4 type: zram size: 2.9 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
Sensors: System Temperatures: cpu: 45.0 C mobo: N/A gpu: nouveau temp: 41.0 C
Info: Processes: 209 Uptime: 19m wakeups: 1 Memory: 11.59 GiB used: 3.05 GiB (26.3%) Init: systemd v: 248 tool: systemctl
Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1428 lib: 359 Shell: fish v: 3.2.1 running-in: konsole
inxi: 3.3.03
Not sure if it's a bug or not.
