And this time be sure to setup your snapshots to perform system recoveries with.
now i had to install garuda linux again ??
ok i will do that
Before reinstalling give a chance to the suggestion given by @PerfMonk
@SGS said that even i fixed the boot issue maybe something else is broken
and i didn't understand the solution that u r taking about
It was simply
btrfs check --init-extent-tree
Tried that also
So quick question
I guess i need 500 mb hidden partition right?? for bios recovery and bios stuff
Garuda use 260 MB its enough for 4 DE's
I actually don't have that partition in the first place even for windows so i have to do one or two or stay with not doing anything?
Another thing
After installing garuda
Windows doesn't appear in grub in booting why?
Try
sudo update-grub
Post output as text, please.
Didn't make any thing still win 10 doesn't show in grub menu
Post output from
efibootmgr
please.
Post also
Efi variables is not supported on my system
Didn't work sorry
This would help
A few hints from the Arch wiki.
According to
https://wiki.archlinux.org/title/GRUB#Detecting_other_operating_systems
you should mount the partitions from which the other systems boot before running the update-grub -> os-prober.
To be honest, this was necessary for me only for other linux distro's, never for Windows, but you can try. For a quick and dirty test, you could simply mount the windows partition opening it from the file manager (if it works, you can mount it automatically e.g. with an entry in the fstab).
https://wiki.archlinux.org/title/GRUB#Windows_installed_in_UEFI/GPT_mode
or
https://wiki.archlinux.org/title/GRUB#Windows_installed_in_BIOS/MBR_mode
Here there are some hints to do it manually in /boot/grub/grub.cfg instead of relying on update-grub.
I think this is definitely not applicable in our case, but maybe could be used in the /etc/grub.d/40_custom.
In addition to the second hint for the manual entry in /etc/grub.d/40_custom:
https://wiki.debian.org/DualBoot/Windows10
which I think is applicable if windows was installed in Legacy mode, and Garuda then in UEFI mode.
