I don't know why, but one day I booted my laptop and instead of seeing the grub menu my laptop got stuck and opened BIOS menu. After trying some options I've discovered the problem might lie in the Grub (I had got old Ubuntu Grub and Windows boot normally).
I digged out my pendrive with Garuda Live and tried to find some solution. After looking a little on this forum I made the following steps:
- chroot-ed into my current installation on the disk
- ran
sudo grub-install
andsudo update-grub
Nothing has reported any errors, so I rebooted my laptop and, to my delight, I saw Garuda's Grub menu and been able to start my system
However, there is one little problem. I may be a bit too grumpy, but in the past days the Grub menu started in less that one second, while now it is five or more seconds. It made me thinking I might not fixed the issue completely, so I made the above steps again on the current system (except chroot-ing of course ).
And I came back to the broken state . It became even worse, because now my BIOS got so confused, it got reset to the factory defaults (which made MS Windows the only option to boot
). Fortunately, I tried to do again the fix and I'm back in the working state (although still with long to start Grub).
After that I saw here on the forum other people complaining about the Grub. Also I had an system update (garuda-update
) a few minutes ago which downgraded the Grub. Well, good news is it didn't broke anything, but on the other side it didn't fixed anything too (5 seconds of boot...)
Is it possible that whatever the previous Grub update has done is permanent?
Kernel: 5.19.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=6a135e81-5d37-4390-8a10-a9eef293c0d9 rw rootflags=subvol=@
Desktop: Cinnamon v: 5.4.9 tk: GTK v: 3.24.34 wm: Mutter vt: 7
dm: LightDM v: 1.32.0 Distro: Garuda Linux base: Arch Linux
Type: Laptop System: Acer product: Aspire A515-54G v: V1.24
Mobo: CML model: Doc_WC v: V1.24 serial: <superuser required>
UEFI: Insyde v: 1.24 date: 07/07/2021
ID-1: BAT1 charge: 39.1 Wh (100.0%) condition: 39.1/48.9 Wh (79.8%)
volts: 16.1 min: 15.2 model: LGC AC14B8K type: Li-ion serial: <filter>
status: full
Info: model: Intel Core i5-10210U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check gen: core 10 built: 2018
process: Intel 14nm family: 6 model-id: 0x8E (142) stepping: 0xC (12)
microcode: 0xF0
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 1450 high: 2100 min/max: 400/4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 2100
4: 2100 5: 800 6: 800 7: 2100 8: 2100 bogomips: 33599
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Acer Incorporated
ALI driver: i915 v: kernel arch: Gen-9.5 process: Intel 14nm
built: 2016-20 ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 0000:00:02.0
Device-2: NVIDIA GP108M [GeForce MX250] vendor: Acer Incorporated ALI
driver: nouveau v: kernel non-free: 515.xx+ status: current (as of 2022-07)
arch: Pascal code: GP10x process: TSMC 16nm built: 2016-21
bus-ID: 0000:02:00.0 chip-ID: 10de:1d13 class-ID: 0302
Device-3: Quanta HD User Facing type: USB driver: uvcvideo bus-ID: 1-5:3
chip-ID: 0408:a061 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.4 driver: X: loaded: intel,nouveau
unloaded: modesetting alternate: fbdev,nv,vesa gpu: i915 display-ID: :0
Monitor-1: eDP-1 mapped: eDP1 model: AU Optronics 0x61ed built: 2018
res: 1920x1080 hz: 60 dpi: 143 gamma: 1.2 size: 340x190mm (13.39x7.48")
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Acer Incorporated ALI
alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 0000:00:1f.3
chip-ID: 8086:02c8 class-ID: 0403
Sound Server-1: ALSA v: k5.19.5-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 0000:00:14.3 chip-ID: 8086:02f0 class-ID: 0280
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 3000
bus-ID: 0000:03:00.0 chip-ID: 10ec:8168 class-ID: 0200
driver: intel_nvme_remap v: N/A port: 5060 bus-ID: 0000:00:17.0
chip-ID: 8086:282a rev: class-ID: 0104
Local Storage: total: 953.87 GiB used: 118.48 GiB (12.4%)
size: 953.87 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> rev: 002C temp: 29.9 C scheme: GPT
ID-1: / raw-size: 476.38 GiB size: 476.38 GiB (100.00%) used: 118.43 GiB
(24.9%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 54.7 MiB
(56.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 476.38 GiB size: 476.38 GiB (100.00%) used: 118.43
GiB (24.9%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
ID-4: /var/log raw-size: 476.38 GiB size: 476.38 GiB (100.00%) used: 118.43
ID-5: /var/tmp raw-size: 476.38 GiB size: 476.38 GiB (100.00%) used: 118.43
ID-1: swap-1 type: zram size: 7.59 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 44.0 C pch: 46.0 C mobo: N/A gpu: nouveau
temp: 41.0 C
Processes: 270 Uptime: 43m wakeups: 1 Memory: 7.59 GiB used: 3.12 GiB
(41.1%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: apt: 0 pacman: 1881 lib: 476
Shell: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.20
Garuda (2.6.6-1):
System install date: 2021-12-22
Last full system update: 2022-08-31
