Grub does not detect partitions
Hello today when I tried to do a dual-boot windows and garuda encountered a problem. I started grub and encountered the following error: error: unknown file system Entering rescue mode... Grub Rescue> LS (HD0) Here's the problem because grub only detects my Windows drive, it doesn't detect any partitions or anything like that. If necessary, below I send config grub
    insmod font
    insmod keylayouts
    insmod part_msdos
    insmod part_gpt
        export loaded
        export koptsok
        export disable_gfxterm
        export bootarch
        export firmware
        export firmware_found
        export from
        export fromiso
        export bootlang
        export keyboard
        export timezone
        export hwclock
        export def_bootlang
        export def_keyboard
        export def_timezone
        export menu_color_normal
        export menu_color_highlight
        export pager
        function menu_help {
        check_help
        grub_help
        function check_help {
        if [ -z "${koptsok}" ]; then
        echo $"WARNING: nothing set"
        echo $" System will use defaults"
        echo " American English <> utc clock <> us "$"keyboard <> free drivers"
        echo ""
        fi
        function kopts_help {
        echo $"Example boot command line arguments:"
        echo $" Setup"
        echo " lang=_ keytable= tz=/"
        echo " hostname= username="
        echo $" Kernel"
        echo " blacklist="
        echo $" Video"
        echo " .modeset=0"
        echo " radeon.modeset=0 nouveau.modeset=0 i915.modeset=0"
        echo " video=VGA-1:1920x1080e DVI-0:800x600"
        echo ""
        function grub_help {
        echo $"To use the menu:"
        echo $" press up or down to move between items"
        echo $" press enter or right to select the item"
        echo $" press e to edit the current item"
        echo $" press c to go to the grub command line"
        echo ""
        echo $"Simply edit the first line of most menus to control them"
        echo $"Select or edit the blank line to enter command line arguments"
        echo ""
        function menu_reload {
        configfile /boot/grub/grub.cfg
        function menu_continue {
        echo -n $"Press Enter to continue"
        read mcont
        function prompt {
        echo -n "> "
        function is_efi {
        if [ "${grub_platform}" = "efi" ]; then
        return 0
        fi
        return 1
        function efi_detect {
        if is_efi ; then
        submenu --class=find.efi --hotkey=f "Detect EFI bootloaders" {
        efi_found=false
                for efi in (*,gpt*)/efi/*/*.efi (*,gpt*)/efi/*/*/*.efi (*,gpt*)/*.efi (*,gpt*)/*/*.efi ; do
                    regexp --set=1:efi_device '^\((.*)\)/' "${efi}"
                    if [ -e "${efi}" ]; then
                        efi_found=true
                        menuentry --class=efi "${efi}" "${efi_device}" {
                            root="${2}"
                            chainloader "${1}"
                    fi
                done
                if [ "${efi_found}" != true ]; then
                    menuentry --hotkey=q --class=find.none "No EFI files detected." {menu_reload}
                else
                    menuentry --hotkey=q --class=cancel "Cancel" {menu_reload}
                fi
        fi
        function memtest_detect {
        if ! is_efi; then
        if [ -f /boot/memtest ]; then
        menuentry --class=memtest --hotkey=m "memtest" {linux16 /boot/$1}
        fi
        fi
        function lang_setup {
        source /boot/grub/locales/${1}
        menu_reload
        function lang_menu {
        menuentry --class=lang.${ll} "lang=${ll}" "${ll}" {lang_setup "${2}"}
        function show_timezones {
        submenu --class=tz --hotkey=t "tz=${def_timezone}" {# set the timezone above with the editor
        if [ -n "$1" ];then
        if [ "$1" = "tz=${def_timezone}" ]; then
        default=0
        menuentry --class=cancel --hotkey=q "Cancel (${def_timezone})" {menu_reload}
        for tt in Africa America Asia Atlantic Australia Etc Europe Pacific; do
        submenu --class=tz.${tt} "${tt}" {
        source "/boot/grub/tz/${1}"
        done
        else
        regexp -s newtz '^tz=(.*)' "$1"
        if [ -z "$newtz" ]; then
        def_timezone="$1"
        else
        def_timezone="$newtz"
        fi
        timezone="tz=$def_timezone"
        menu_reload
        fi
        fi
        function show_keymaps {
        submenu --class=kbd --hotkey=k "keytable=${def_keyboard}" {# set the timezone above with the editor
        if [ -n "$1" ]; then
        if [ "$1" = "keytable=${def_keyboard}" ]; then
        default=0
        menuentry --class=cancel --hotkey=q "Cancel (${def_keyboard})" {menu_reload}
        source /boot/grub/locales/keyboards
        else
        regexp -s newkey '^keytable=(.*)' "$1"
        if [ -z "$newkey" ]; then
        def_keyboard="$1"
        else
        def_keyboard="$newkey"
        fi
        keyboard="keytable=$def_keyboard"
        menu_reload
        fi
        fi
        function show_languages {
        submenu --hotkey=l --class=lang "lang=${def_bootlang}" {# set the timezone above with the editor
        if [ "$1" = "lang=${def_bootlang}" ]; then
        default=0
        menuentry --class=lang.${def_bootlang} "lang=${def_bootlang}" {menu_reload}
        menuentry --class=lang.cs "Čeština" {lang_setup "cs_CZ"}
        menuentry --class=lang.da "Dansk" {lang_setup "da_DK"}
        submenu --class=lang.de "Deutsch" {
        for ll in de_DE de_AT de_BE de_CH de_LI de_LU; do
        lang_menu ${ll}
        done
        submenu --class=lang.el "Ελληνικά" {
        for ll in el_GR el_CY; do
        lang_menu ${ll}
        done
        submenu --class=lang.en "English" {
        for ll in en_US en_AG en_AU en_BW en_CA en_DK en_GB en_HK en_IE en_IN en_NG en_NZ en_PH en_SG en_ZA en_ZW; do
        lang_menu ${ll}
        done
        submenu --class=lang.es "Español" {
        for ll in es_ES es_AR es_BO es_CL es_CO es_CR es_DO es_EC es_GT es_HN es_MX es_NI es_PA es_PE es_PR es_PY es_SV es_US es_UY es_VE; do
        lang_menu ${ll}
        done
        submenu --class=lang.fr "Français" {
        for ll in fr_FR fr_BE fr_CA fr_CH fr_LU fr_NC; do
        lang_menu ${ll}
        done
        menuentry --class=lang.he "עִבְרִית" {lang_setup "he_IL"}
        submenu --class=lang.it "Italiano" {
        for ll in it_IT it_CH; do
        lang_menu ${ll}
        done
        menuentry --class=lang.ja "日本語" {lang_setup "ja_JP"}
        submenu --class=lang.nl "Nederlands" {
        for ll in nl_NL nl_AW nl_BE; do
        lang_menu ${ll}
        done
        menuentry --class=lang.pl "Polski" {lang_setup "pl_PL"}
        submenu --class=lang.pt "Português" {
        for ll in pt_BR pt_PT; do
        lang_menu ${ll}
        done
        menuentry --class=lang.ro "Română" {lang_setup "ro_RO"}
        submenu --class=lang.ru "Русский" {
        for ll in ru_RU ru_UA;do
        lang_menu ${ll}
        done
        submenu --class=lang.zh "中文" {
        for ll in zh_CN zh_TW; do
        lang_menu ${ll}
        done
        else
        regexp -s newlang '^lang=(.*)' "$1"
        if [ -z "$newlang" ]; then
        def_bootlang="$1"
        else
        def_bootlang="$newlang"
        fi
        bootlang="lang=$def_bootlang"
        if [ -f /boot/grub/locales/${def_bootlang} ]; then
        source /boot/grub/locales/${def_bootlang}
        fi
        menu_reload
        fi
        fi
        function boot_menu {
        if [ "${hwclock}" = "utc=yes" ]; then
        class="utc"
        title="utc"
        clockset=""
        elif [ "${timezone}${bootlang}" = "" ]; then
        class="unset"
        title="utc"
        clockset=""
        else
        title="${def_timezone}"
        class="tz.${def_timezone}"
        clockset="utc=yes"
        fi
        min2d="$MINUTE"
        if regexp '(^.$)' "$min2d"; then
        min2d="0${min2d}"
        fi
        hour2d="$HOUR"
        if regexp '(^.$)' "$hour2d"; then
        hour2d="0${hour2d}"
        fi
        menuentry --class=tz.$class --hotkey=u "$hour2d:$min2d $title" "$clockset" {
        hwclock="$2"
        menu_reload
        show_timezones
        show_keymaps
        show_languages
        default=5
        function boot_defaults {
        source /boot/grub/defaults.cfg
        function grub_reboot {
        menuentry " " {true}
        menuentry --class=reboot "Reboot!" {reboot}
        function grub_bios_installed {
        if ! is_efi; then
        menuentry "" {true}
        menuentry --class=garuda "Installed BIOS-System on $installed" {exit}
        fi
        function grub_efi_installed {
        if is_efi; then
        menu "" {true}
        menu --class=garuda "Installed EFI-System on $installed" {exit}
        fi
        function check {
        cliname="$1"
        varname="$2"
        if [ "${optname}" != "${cliname}" ]; then
        return 1
        fi
        if [ -z "$varname" ]; then
        varname="${cliname}"
        fi
        if [ -z "${optval}" ]; then
        eval ${varname}="${cliname}"
        else
        eval ${varname}="${cliname}=${optval}"
        if [ "${optname}" = "lang" ]; then
        lang_setup ${optval}
        elif [ "${optname}" = "keytable" ]; then
        def_keyboard="${optval}"
        elif [ "${optname}" = "tz" ]; then
        def_timezone="${optval}"
        fi
        fi
        return 0
        function checkinput {
        newinput="$1"
        newoutput=""
        for newcli in ${newinput} ; do
        optname=""
        optval=""
        optdone=""
        regexp -s optname '^(.+)=.$' "${newcli}"
        if [ -z "${optname}" ]; then
        optname="${newcli}"
        else
        regexp -s optval '^.+=(.)$' "${newcli}"
        fi
        for tocheck in "lang bootlang" "keytable keyboard" "tz timezone" "utc hwclock"; do
        if check $tocheck ; then
        optdone="Y"
        break
        fi
        done
        if [ -z "${optdone}" ]; then
        if [ -z "${newoutput}" ]; then
        newoutput="${newcli}"
        else
        newoutput="${newoutput} ${newcli}"
        fi
        fi
        done
        function new2cli {
        newinput="$1"
        if [ -n "$newinput" ]; then
        checkinput "$newinput"
        if [ -n "${newoutput}" ]; then
        newinput="${newoutput}"
        if [ -n "$clinput" ]; then
        clinput="$clinput $newinput"
        else
        clinput="$newinput"
        fi
        export clinput
        fi
        fi
        function getargs {
        args=""
        for a in [email protected]; do
        if [ -n "${a}" ]; then
        args="${args} ${a}"
        fi
        done
        function bootcheck {
        getargs
        pager=1
        insmod regexp
        insmod datehook
        if ! is_efi; then
        insmod part_gpt
        fi
        if is_efi; then
        insmod efi_gop
        insmod efi_uga
        fi
        if [ -z "${loaded}" ]; then
        iscd=""
        auto=""
        regexp -s iscd '^(cd)' "${root}"
        if [ "${iscd}" != "cd" -a -e (cd) ]; then
        probe -s cdp -u cd
        probe -s hdp -u $root
        if [ -n "$cdp" -a "$cdp" = "$hdp" ]; then
        iscd="cd"
        fi
        fi
        if [ "${root}" != "hd96" -a "${iscd}" != "cd" ]; then
        auto="${auto}"
        fi
        source /boot/grub/variable.cfg
        loaded=true
        if keystatus --shift; then
            disable_gfxterm=true
        fi
        if [ "${disable_gfxterm}" != "true" ]; then
            if loadfont /boot/grub/unicode.pf2 ; then
                if [ -z "$gfxmode" ] ; then
                    gfxmode=1024x768,auto # 1280x1024,1024x768,800x600,640x480 possible value
                    gfxpayload=keep
                fi
                if keystatus --ctrl; then
                    gfxok=""
                    pager=0
                    while [ -z "$gfxok" ]; do
                        echo "gfxmode=$gfxmode"
                        echo "Input new mode or Enter to confirm"
                        prompt
                        read gfxmodein
                        if [ -n "$gfxmodein" ]; then
                            gfxmode="$gfxmodein"
                            echo ""
                        else
                            gfxok="true"
                        fi
                    done
                fi
                insmod all_video
                insmod gfxterm
                if terminal_output --append gfxterm; then
                    terminal_output --remove console
                else
                fi
            else
            fi
        fi
        if [ "${disable_gfxterm}" != "true"  -a -f "${grub_theme}" ]; then
            insmod gfxmenu
            themedir=""
            regexp -s themedir '^(.*)/.*$' "${grub_theme}"
            for themefont in $themedir/*.pf2 $themedir/f/*.pf2; do
                if [ -f "${themefont}" ]; then
                    loadfont "${themefont}"
                fi
            done
            for imagetype in jpg jpeg png tga; do
                for themeimage in ${themedir}/*.${imagetype}; do
                    if [ -f "${themeimage}" ]; then
                        if [ "${imagetype}" = "jpg" ]; then
                            insmod jpeg
                        else
                            insmod $imagetype
                        fi
                    fi
                done
            done
            theme=${grub_theme}
            export theme
        fi
        menu_color_normal=cyan/blue
        menu_color_highlight=white/blue
        if [ -n "${iso_path}" ]; then
            auto="img_dev=/dev/disk/by-uuid/${rootuuid} img_loop=${iso_path}"
        fi
        export auto
        fi
        boot_defaults
        for kopt in "${clinput}" "${bootlang}" "${keyboard}" "${timezone}" "${hwclock}" "${auto}"; do
        if [ -n "${kopt}" ]; then
        kopts="${kopts} ${kopt}"
        fi
        done
        if [ -n "${bootlang}${keyboard}${timezone}" ]; then
        koptsok="true"
        fi
        boot_menu
        source /boot/grub/kernels.cfg
        menuentry --class=edit "$clinput" {
        clinput="[email protected]"
        else
        unset clinput
        fi
        menu_reload
        fi
        menuentry --class=type --hotkey=tab "" {# set arguments above with the editor
        getargs [email protected]
        pager=0
        if [ -z "$args" ]; then
        check_help
        kopts_help
        echo $"Input command line options, press Enter to continue"
        prompt
        read newinput
        else
        newinput="$args"
        fi
        new2cli "$newinput"
        pager=1
        menu_reload
        menuentry --hotkey=h --class=help "help" {
        pager=0
        menu_help
        menu_continue
        pager=1
        efi_detect
        memtest_detect
        search --no-floppy --file /etc/issue --set installed
        grub_bios_installed
        grub_efi_installed
        grub_reboot
            Blockquote
Close
Welcome to the forum
can you provide your
as per the forum template
Oops, i forgot about it , i will send it in a moment
