Ok, not funny. Are you able to reboot the machine and from the GRUB menu select a SNAPSHOT, boot from it and restore data from the Garuda Assistant?
That'll get you back in a "running" system hopefully long enough to try troubleshooting or change settings. You probably should not lose log files doing this cuz they are stored in a different subvolume than the one you would restore from, but since I work with my own snapshot implementation I'd need someone who knows better Garuda Assistant to say if I'm right or not.
I tried restoring from a few snapshots and got Timed out waiting for device /dev/ipts/15.
Running garuda-update gives the following (and no resolution of the bug)
Script started on 2022-03-08 20:28:47+01:00 [TERM="linux" TTY="/dev/tty5" COLUMNS="273" LINES="91"]
[benoitseron@benoit-surfacepro7 ~]$ garuda-update
[sudo] password for benoitseron:
core is up to date
extra is up to date
community 15.7 KiB 59.0 B/s --:-- [c o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o ] 0%
chaotic-aur community 159.7 KiB 226 KiB/s 00:26 [--Co o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o ] 2%
community 191.7 KiB 185 KiB/s 00:32 [---C o o o o o o o o o o o o o o o o o o o o o o o chaotic-aur community 463.7 KiB 572 KiB/s 00:09 [-------C o o o o o o o o o o o o o o o o o o o o o o chaotic-aur community 575.7 KiB 565 KiB/s 00:09 [---------C o o o o o o o o o o o o o o o o o o o o o chaotic-aur community 655.7 KiB 499 KiB/s 00:11 [----------C o o o o o o o o o o o o o o o o o o o o o chaotic-aur community 767.7 KiB 517 KiB/s 00:10 [------------C o o o o o o o o o o o o o o o o o o o o chaotic-aur community 911.7 KiB 582 KiB/s 00:09 [--------------Co o o o o o o o o o o o o o o o o o o o chaotic-aur community 1039.7 KiB 586 KiB/s 00:08 [----------------C o o o o o o o o o o o o o o o o o o o chaotic-aur community 1183.7 KiB 628 KiB/s 00:07 [-------------------C o o o o o o o o o o o o o o o o o o chaotic-aur community 1407.7 KiB 771 KiB/s 00:06 [----------------------C o o o o o o o o o o o o o o o o o chaotic-aur community 1551.7 KiB 749 KiB/s 00:06 [-------------------------C o o o o o o o o o o o o o o o o chaotic-aur 1551.7 KiB 768 KiB/s 00:00 [--------------------------------------------------------------------------- chaotic-aur community 1807.7 KiB 926 KiB/s 00:04 [-----------------------------Co o o o o o o o o o o o o o o community 2.1 MiB 1201 KiB/s 00:03 [----------------------------------c o o o o o o o o o o o o o community 2.4 MiB 1211 KiB/s 00:03 [---------------------------------------C o o o o o o o o o o o community 2.7 MiB 1388 KiB/s 00:02 [---------------------------------------------c o o o o o o o o o community 3.0 MiB 1392 KiB/s 00:02 [---------------------------------------------------C o o o o o o o community 3.4 MiB 1456 KiB/s 00:01 [--------------------------------------------------------co o o o o o community 3.7 MiB 1494 KiB/s 00:01 [--------------------------------------------------------------Co o o o community 4.0 MiB 1600 KiB/s 00:01 [--------------------------------------------------------------------co o community 4.4 MiB 1657 KiB/s 00:01 [-------------------------------------------------------------------------C community 4.7 MiB 1556 KiB/s 00:00 [--------------------------------------------------------------------------- community 4.9 MiB 1426 KiB/s 00:00 [--------------------------------------------------------------------------- community 5.2 MiB 1395 KiB/s 00:00 [--------------------------------------------------------------------------- community 5.4 MiB 1330 KiB/s 00:00 [--------------------------------------------------------------------------- community 5.7 MiB 1402 KiB/s 00:00 [--------------------------------------------------------------------------- community 6.0 MiB 1359 KiB/s 00:00 [--------------------------------------------------------------------------- community 6.0 MiB 1032 KiB/s 00:06 [------------------------------------------------------------------------------------------------------] 100%
--> Refreshing mirrorlists using reflector, please be patient..
[2022-03-08 20:29:14] WARNING: failed to rate http(s) download (https://archmirror.it/repos/community/os/x86_64/community.db): HTTP Error 403: Forbidden
[2022-03-08 20:29:20] WARNING: failed to rate http(s) download (https://mirror.cyberbits.asia/archlinux/community/os/x86_64/community.db): Download timed out after 5 second(s).
################# Arch Linux mirrorlist generated by Reflector #################
# With: reflector --latest 5 --age 2 --fastest 5 --protocol https --sort rate --save /etc/pacman.d/mirrorlist
# When: 2022-03-08 19:29:25 UTC
# From: https://archlinux.org/mirrors/status/json/
# Retrieved: 2022-03-08 19:29:05 UTC
# Last Check: 2022-03-08 19:21:35 UTC
Server = https://mirror.telepoint.bg/archlinux/$repo/os/$arch
Server = https://mirror.archlinux.no/$repo/os/$arch
Server = https://mirror.luzea.de/archlinux/$repo/os/$arch
Server = https://archmirror.it/repos/$repo/os/$arch
Server = https://mirror.cyberbits.asia/archlinux/$repo/os/$arch
core 15.7 KiB 46.0 B/s 44:35 [-----------Co o o o o o o o o o o o o o o o o o o o o o o o o o o o o o ] 11%
chaotic-aur
multilib 15.7 KiB 46.0 B/s 51 community core 136.0 KiB 324 KiB/s 00 extra 15.7 KiB 45.0 B/s --:-- [-C o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o ] 1%----------------------------------------------- community 191.7 KiB 281 KiB/s 00:21 [---c o o o o o o o o o o o o o o o o o o o o o o o linux-surface 6.6 KiB 19.0 B/s 00 extra 191.7 KiB 288 KiB/s 00:04 [------------C o o o o o o o o o o o o o o o o o o o o o o o o o o o o o ] 12%----------------------------------------------- community 495.7 KiB 691 KiB/s 00:08 [--------co o o o o o o o o o o o o o o o o o o o o o extra 495.7 KiB 698 KiB/s 00:01 [--------------------------------Co o o o o o o o o o o o o o community 735.7 KiB 836 KiB/s 00:06 [-----------co o o o o o o o o o o o o o o o o o o o o extra 655.7 KiB 730 KiB/s 00:01 [------------------------------------------c o o o o o o o o o o community 975.7 KiB 954 KiB/s 00:05 [---------------C o o o o o o o o o o o o o o o o o o o extra 847.7 KiB 803 KiB/s 00:00 [-------------------------------------------------------C o o o o o o community 1167.7 KiB 950 KiB/s 00:05 [------------------c o o o o o o o o o o o o o o o o o o extra 1103.7 KiB 958 KiB/s 00:00 [------------------------------------------------------------------------C community 1359.7 KiB 953 KiB/s 00:05 [---------------------c o o o o o o o o o o o o o o o o o extra 1327.7 KiB 1008 KiB/s 00:00 [--------------------------------------------------------------------------- community 1567.7 KiB 982 KiB/s 00:04 [-------------------------C o o o o o o o o o o o o o o o o extra 1546.4 KiB 813 KiB/s 00:02 [--------------------------------------------------------------------------- community 1775.7 KiB 1001 KiB/s 00:04 [----------------------------C o o o o o o o o o o o o o o o chaotic-aur community 1999.7 KiB 1041 KiB/s 00:04 [--------------------------------Co o o o o o o o o o o o o o chaotic-aur community 2.2 MiB 1088 KiB/s 00:03 [------------------------------------C o o o o o o o o o o o o chaotic-aur community 2.4 MiB 1072 KiB/s 00:03 [---------------------------------------C o o o o o o o o o o o chaotic-aur 1583.7 KiB 1132 KiB/s 00:00 [--------------------------------------------------------------------------- chaotic-aur community 2.7 MiB 1168 KiB/s 00:02 [-------------------------------------------C o o o o o o o o o o community 2.9 MiB 1149 KiB/s 00:02 [-----------------------------------------------co o o o o o o o o community 3.2 MiB 1196 KiB/s 00:02 [-----------------------------------------------------Co o o o o o o community 3.4 MiB 1112 KiB/s 00:02 [---------------------------------------------------------c o o o o o community 3.7 MiB 1158 KiB/s 00:02 [-------------------------------------------------------------C o o o o community 3.9 MiB 1029 KiB/s 00:02 [----------------------------------------------------------------c o o o community 4.0 MiB 970 KiB/s 00:02 [--------------------------------------------------------------------Co o community 4.3 MiB 1019 KiB/s 00:01 [------------------------------------------------------------------------c community 4.6 MiB 1081 KiB/s 00:01 [--------------------------------------------------------------------------- community 4.8 MiB 1167 KiB/s 00:01 [--------------------------------------------------------------------------- community 5.1 MiB 1273 KiB/s 00:00 [--------------------------------------------------------------------------- community 5.4 MiB 1312 KiB/s 00:00 [--------------------------------------------------------------------------- community 5.7 MiB 1379 KiB/s 00:00 [--------------------------------------------------------------------------- community 6.0 MiB 1421 KiB/s 00:00 [--------------------------------------------------------------------------- community 6.0 MiB 1092 KiB/s 00:06 [---------------------------------------------------------------------------spawn pacman -Su-----------] 100%
resolving dependencies...
Packages (1) python-pycryptodomex-3.12.0-1
Total Download Size: 1.32 MiB
Total Installed Size: 6.16 MiB
Net Upgrade Size: 0.24 MiB
:: Retrieving packages...
python-pycryptodomex-3.12.0-1-x86_64 15.7 KiB 37.0 B/s --:-- [-C o o o o o o o o o o o o o o o o o o o o o o o o python-pycryptodomex-3.12.0-1-x86_64 223.7 KiB 342 KiB/s 00:03 [----------------c o o o o o o o o o o o o o o o o o o o python-pycryptodomex-3.12.0-1-x86_64 543.7 KiB 733 KiB/s 00:01 [----------------------------------------C o o o o o o o o o o o python-pycryptodomex-3.12.0-1-x86_64 911.7 KiB 1102 KiB/s 00:00 [--------------------------------------------------------------------co o python-pycryptodomex-3.12.0-1-x86_64 1354.7 KiB 1473 KiB/s 00:00 [--------------------------------------------------------------------------- python-pycryptodomex-3.12.0-1-x86_64 1354.7 KiB 1245 KiB/s 00:01 [---------------------------------------------------------------------------(0/1) checking keys in keyring [c o o o o o o o o o o o o o o o o o o o o o o o o (1/1) checking keys in keyring [------------------------------------------------------------------------------------------------------] 100%
(0/1) checking package integrity [c o o o o o o o o o o o o o o o o o o o o o o o o (1/1) checking package integrity [------------------------------------------------------------------------------------------------------] 100%
(0/1) loading package files [c o o o o o o o o o o o o o o o o o o o o o o o o (1/1) loading package files [------------------------------------------------------------------------------------------------------] 100%
(0/1) checking for file conflicts [c o o o o o o o o o o o o o o o o o o o o o o o o (1/1) checking for file conflicts [------------------------------------------------------------------------------------------------------] 100%
(0/1) checking available disk space [c o o o o o o o o o o o o o o o o o o o o o o o o (1/1) checking available disk space [------------------------------------------------------------------------------------------------------] 100%
==> root: 67
(1/1) upgrading python-pycryptodomex [c o o o o o o o o o o o o o o o o o o o o o o o o (1/1) upgrading python-pycryptodomex [------------------------------------------------------------------------------------------------------] 100%
(1/6) Arming ConditionNeedsUpdate...
(2/6) Foreign/AUR package notification
libwacom-surface 1.12-1
(3/6) Orphaned package notification...
apparmor 3.0.4-1
celt 0.11.3-4
elfutils 0.186-5
kwayland 5.91.0-1
libcroco 0.6.13-2
libmms 0.6.4-3
libofa 0.9.3-9
meson 0.61.2-1
nohang 0.2.0-1
python-pytest 7.0.1-1
python-toml 0.10.2-7
tepl 6.00.0-3
zita-alsa-pcmi 0.4.0-1
zita-resampler 1.8.0-1
(4/6) Checking for .pacnew and .pacsave files...
.pac* files found:
/etc/nsswitch.conf.pacnew
/etc/locale.gen.pacnew
/etc/default/grub.pacnew
/etc/default/grub-btrfs/config.pacnew
Please check and merge
(5/6) Performing snapper post snapshots for the following configurations...
==> root: 68
(6/6) Syncing all file systems...
Parsing man pages and writing completions to /home/benoitseron/.local/share/fish/generated_completions/
3455 / 3455 : zramctl.8.gz
Checking for plugin updates
Uninstalling aspell
Downloading "aspell" (1.3.0) from "https://github.com/priner/micro-aspell-plugin/archive/v1.3.0.zip"
One or more plugins installed.
System updated! đ§
Update notices:
The default faillock limit was automatically changed to 10 (from 3)
[benoitseron@benoit-surfacepro7 ~]$ exit
exit
Script done on 2022-03-08 20:30:09+01:00 [COMMAND_EXIT_CODE="0"]
I can at least boot from an Ubuntu live stick, I will try with a garuda one.
Did this happen without any warning during a normal problem free session, or did it happen during the boot/reboot process.
What changes had you made prior to this happening?
If it happened during a boot/reboot, was this possibly your first reboot since doing your last update?
We will need some logs to have any real idea what happened here. I am only currently on my cell, so I canât give very specific instructions. Read some posts on the forum regarding termbin usage:
As long as your network connection is working in a TTY you can upload your logs to the forum. If you have no internet connection, then you would need to chroot into your installed system to post logs.
Have a read on termbin and see if you can upload some logs.
I believe I ran some updates (trying to get python working?). I can make a picture of the snapshot menu if helpful otherwise I donât know to export this as text.
Most likely.
Thanks a lot for taking the time to answer even on your cellphone, here is the result of your commands : https://termbin.com/2abis
Looking at this with my very untrained eye, I wish to give you the following precisions:
my dual boot with windows works (as flawlessly as windows can lol)
sometimes my laptop powers up all by itself, with zero chance of the power up button being pushed (which is not only annoying because sometimes I find myself with an empty battery and no way of charging it, and dangerous because it could burn in the backpack)
If I can add yet another element, it is not that bad if I have to reinstall Garuda, but my friend who installed it said it would be a bit technical to do without messing up with the dual boot (which I have to keep for work.)
This will seem off topic but bear with me you'll see where I'm going.
Why are you dual-booting Windows?
Are you gaming in Windows?
Reason I ask is cuz if it's not really required but you just require "Windows working", then you can have only Garuda installed and you virtualize Windows (with Virtualbox or VirtManager, the 2 most common I believe) within Garuda.
This solution has proven ideal for me. With 3D acceleration enabled in VirtualBox (there's a bug on that with VirtManager) it's as fast as running it on physical machine, if not more cuz it boots faster.
What I'm saying is if you want to reinstall Garuda and start clean, which could fix the issue of your OP, but hesitate to go fwd cuz you think you'll mess up the dual-boot, well then just think about my suggestion, maybe it applies to you as it does to me.
This normally means a GNOME extension has crashed or is crashing GNOME Shell. You can move/remove extensions from under $HOME/.local/share/gnome-shell/extensions/ so they are âdisabledâ and then try logging in again.
One option would be for this friend to help you fix the problem - your friend has installed a distribution that needs regular maintenance (because itâs a rolling release and so things regularly change) so unless youâre looking to learn how Linux works then a different distribution would be more appropriate.
I (believe I) need windows to access windows apps that I am, rarely, required to use for classes I may have to teach (being a PhD student) such as teams.
I bought this laptop specifically to have the touchscreen and be able to write with the pen in OneNote. I believe the touchscreen is not working in garuda right?
Taking notes with the pen is something I really need, also to make didactic talks online.
Iâm not gonna be gaming, the laptop simply isnât suited for that as itâs very weak (even just for normal use) but itâs the only CPU model I could buy with the university. I have a big desktop where I can all my other stuff but this is the computer I use at the office.
This is something I could do but before deleting windows I need a 100 percent certainty that this solution will work for the above stated needs.
He tried but couldnât help. He chose this distribution because it had a newer kernel that had the hardware compatibility to fix my previous problem (with PopOs, unable to connect to most networks). For myself I am willing to learn of course, and loved garuda so far. But the learning curve may be a bit steep for me a priori.
