Ok i will do it tomorrow when i reach home
Btw once again congrats on becoming a leader
Ok so i updated it and restarted the system but the issue is still there
Now i plan to rollback with snapshot but the working snapshot with no issue is from 7th Aug(which i took manually) the others are not visible what would you recommend?
Iām only responding to the information in the text, I donāt watch the video (I boycott Google, Microsoft and the like).
Itās possible that itās a hardware problem, itās possible that it was the update described and it is possible that it has a completely different cause. And the little information that comes from you isnāt really enough to narrow down the problem (I donāt mean that in a bad way, donāt get me wrong).
If you want to have a running system again quickly, BACKUP all your stuff, download the latest ISO-Build and make a fresh install.
If you want more Trobleshooting, we need more information and your cooperation:
- As i say, i donāt see the video. Maybe you can upload this to another source? If not, what exactly is the grafical problem? Is this only on Games or on other applications too?
- Your invisible? snapshots: post the output from āsudo snapper listā
- Load a snapshot before 10.11.2023 and check via terminal/pacman or octopi if āgaruda-video-linux-config-2:1.1.4-4, intel-compute-runtime-23.30.26918.9-1, xf86-video -intel-1:2.99.917+923+gb74b67f0-1ā is installed. Is this installed, remove it, reboot your system and run āgaruda-updateā. If this not installed, then you can rule out that as the cause for now.
Use performance
I change the headline for the crawlers
The issue is still there on performance mode unfortunately.
Though i think it has to do with the update as in a working snapshot which i took manually this issue is not there though that snapshot is a bit old from 7/Aug
- This issue is present in File manager, Brave browser, games. The few things it doesnāt affect is firefox, firedragon, libreoffice apps, terminal, snapper, btrfs assistant.
- The snapshots are not exactly invisible i mean only some snapshots are saved right so the one just before this issue arrived is not there and a working snapshot which I manually is from Aug[The only one that doesnāt have this issue]. (i checked it on btrfs assistant and snapper)
3)As i said No snapshots from 10th Nov
Thought now i am thinking on going back to the snapshot from Aug
I already thought that, from the description it doesnāt fit with a frozen graphics stack and I think it has nothing to do with the update.
Try a live session. Do the same problems arise?
EDIT: Another thought: Do you have the problem consistently or only in battery mode (w/o power conection)?
This looks more like a driver problem. I took a closer look at your inxi again.
You have an Iris Xe Graphic, but the i915 driver is specifically for older iGPUs? Can anyone say anything about this?
driver: X: loaded: N/A unloaded: modesetting
failed: intel
Load the old snapshot from 7. August and compare the garuda-inxi
with the current one.
~ ā¦i love talking to myself ~
Have you tried a live session? Have you compared the garuda-inxi from the working snapshot with the current garuda-inxi (kernel parameters, graphics, display)?
btw: The i915 kernel driver is the right one for the Iris Xe Graphic. The problem is that X11 doesnāt load the driver.
Boot your Garuda normally (not the working snapshot) with the graphics problems and check the output of:
pacman -Qs intel
If you see intel-graphics-compiler intel-compute-runtime xf86-video-intel
, remove this.
Open /etc/X11/xorg.conf.d/20-intel.conf
with an editor and check this entry:
Section āDevicesā
Identifier āIntel Graphicsā
Driver āmodesettingā
EndSection
What is the parameter at Driver
(modesetting? intel? or is it empty?)
~ so Iām out of here⦠~
āSoundsā like you may be stuck hereā¦
https://wiki.archlinux.org/title/Microcode
ā¦and need to enable intel-ucode
then.
But I could be wrong. I run Arch+KDE and neither GNOME nor Arch get along very well, not since about 2018 in my experience. I used to run GNOME, I used to love GNOME. But not since about 2018. sniffle
Maybe, maybe not. Was it due to the update in question, did a tool/application/dependency mess something up, or did something go wrong while experimenting with a production system? Only the thread creator knows that (Iāll throw in Xorg.0.log
for troubleshooting, I forgot that in a hurry in the previous post). Without more information itās a puzzle game.
Me too @Arch+KDE, and Iām not a Gnome expert. But I donāt think itās a Gnome problem.
~ now Iām really out ~
Everything is a GNOME problem. Even GNOME is a GNOME problem.
Until KDE 6 breaks everything, then GNOME might be just fine.
for 2 it says the following:
Display: server: X.Org v: 21.1.8 with: Xwayland v: 23.1.2
compositor: gnome-shell driver: X: loaded: modesetting
alternate: fbdev,intel,vesa dri: iris gpu: i915 display-ID: :1 screens: 1
i think it looks different and sorry for replying late i was quite busy irl.
The loaded looks different i believe
the kernel paramters are bit different it shows boot image snapshot obviously as i am using it but just in case it is need i will provide the entire output
Kernel: 6.4.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
parameters: BOOT_IMAGE=/@/.snapshots/166/snapshot/boot/vmlinuz-linux-zen
root=UUID=692a1f37-ca4d-418e-843a-1b020bd28d17 quiet quiet
rootflags=defaults,noatime,compress=zstd,discard=async,ssd,subvol=@/.snapshots/166/snapshot
Desktop: GNOME v: 44.3 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 44.1
Type: Laptop System: HP product: HP Laptop 15s-fq5xxx v: N/A
Mobo: HP model: 8A20 v: 20.22 serial: <filter> UEFI: AMI v: F.19
date: 07/03/2023
ID-1: BAT0 charge: 35.0 Wh (100.0%) condition: 35.0/41.0 Wh (85.3%)
volts: 12.6 min: 11.3 model: HP Primary type: Li-ion serial: <filter>
status: full cycles: 37
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse serial: <filter>
charge: 5% (should be ignored) rechargeable: yes status: discharging
Info: model: 12th Gen Intel Core i5-1235U socket: U3E1 bits: 64
type: MST AMCP arch: Alder Lake level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 4
microcode: 0x42C
Topology: cpus: 1x cores: 10 mt: 2 tpc: 2 st: 8 threads: 12 smt: enabled
cache: L1: 928 KiB desc: d-8x32 KiB, 2x48 KiB; i-2x32 KiB, 8x64 KiB
L2: 6.5 MiB desc: 2x1.2 MiB, 2x2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 810 high: 2197 min/max: 400/4400:3300
base/boost: 3960/4400 scaling: driver: intel_pstate governor: powersave
volts: 1.1 V ext-clock: 100 MHz cores: 1: 400 2: 425 3: 400 4: 1263 5: 522
6: 2197 7: 1197 8: 959 9: 476 10: 759 11: 456 12: 670 bogomips: 59904
Device-1: Intel Alder Lake-UP3 GT2 [Iris Xe Graphics]
vendor: Hewlett-Packard driver: i915 v: kernel arch: Gen-12.2
process: Intel 10nm built: 2021-22+ ports: active: eDP-1 empty: DP-1,
DP-2, DP-3, DP-4, HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:46a8
Device-2: Cheng Uei Precision Industry (Foxlink) HP True Vision HD Camera
driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 1-3:3 chip-ID: 05c8:0b05 class-ID: 0e02 serial: <filter>
Monitor-1: eDP-1 model: ChiMei InnoLux 0x153b built: 2020 res: 1920x1080
ratio: 16:9 modes: 1920x1080
missing.
vendor: Hewlett-Packard driver: sof-audio-pci-intel-tgl
chip-ID: 8086:51c8 class-ID: 0401
API: ALSA v: k6.4.7-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.76 status: n/a (root, process) with:
vendor: Hewlett-Packard driver: N/A modules: rtw88_8822ce pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:c822
IF-ID-1: enp0s20f0u2 state: unknown speed: -1 duplex: half mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:4 chip-ID: 0bda:b00c
Local Storage: total: 476.94 GiB used: 157.21 GiB (33.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN530
SDBPNPZ-512G-1006 size: 476.94 GiB block-size: physical: 512 B
fw-rev: HPS2 temp: 36.9 C scheme: GPT
ID-1: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 92.6 MiB (36.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-2: /home raw-size: 238.05 GiB size: 238.05 GiB (100.00%)
used: 157.12 GiB (66.0%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p5
maj-min: 259:5
ID-3: /var/log raw-size: 238.05 GiB size: 238.05 GiB (100.00%)
maj-min: 259:5
ID-4: /var/tmp raw-size: 238.05 GiB size: 238.05 GiB (100.00%)
maj-min: 259:5
ID-1: swap-1 type: zram size: 7.44 GiB used: 691.8 MiB (9.1%)
System Temperatures: cpu: 63.0 C mobo: N/A
Processes: 314 Uptime: 7m wakeups: 13209 Memory: total: 8 GiB note: est.
available: 7.44 GiB used: 2.67 GiB (36.0%) igpu: 60 MiB Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1542 libs: 439 tools: pamac,paru
Shell: garuda-inxi (sudo) default: Bash v: 5.1.16 running-in: gnome-terminal
inxi: 3.3.28
System install date: 2022-11-09
Last full system update: 2023-08-01
Windows dual boot: Yes
will do asap and tell you
I think it might have to do with update as i was not experimenting with anything
i will upload the xorg log too in a while
I just checked /etc/X11/xorg.conf.d/20-intel.conf
does not exist the only files there are 00-keyboard.conf
and 30-touchpad.conf
the log file Xorg.1.log
(do note I opened this file and not the file having old in its name) i cant post it here as the charc limit is present do i need to look for something in particular?
the file location was ~/.local/share/xorg/Xorg.0.log.
This part is for @Bro
it said to edit boot config file so i opened the boot config file in /boot/grub
and opened the grub.cfg file it says to not edit it and that is is made automatically by grub.d
and default/grub
that is why i did not edit it. Am i talking about the correct file?
Please do not post here in the forum like in chat forums like Telegram.
As long as no one has responded to your post you can edit your post.
@SGS
Hast recht. Ist notiert und ich werd mich daran halten (iss auch arg unübersichtlich geworden - iss meine Schuld). Aber dein vorschnelles ändern des Titels trägt auch nicht grad dazu bei, das hier Leute mitlesen die helfen könnten.
@Bro
Iāve been reading here since the garuda forum exist. I like your humor btw.
@Private0im
Go slowly and step by step. Use https://bin.garudalinux.org/
for the Xorg.0.log
and post the generated link here.
Nun ja, Titel ohne Hinweis auf das Problem sind weder für Suchmaschinen noch für Forenhelfer hilfreich.
The Xorg log file. btw I checked the live USB of the new on garudas website and it works properlyI did not update the live boot if I should try that do tell me) Also in case you didnt read in the old post the the 20-intel.conf
does not wxist
I quickly skimmed through your Xorg.0.log
, relevant points are:
- āintelā (GPU driver) is loaded. WTF? It shouldnāt actually be installed at all, so it should fail and automatically load āmodesettingā as a fallback. I already noticed this in your
inxi
(failed: intel
) - āmodesettingā is loaded and unloaded again without an error message (which is plausible if āintelā is loaded first without errors and āmodesettingā only serves as a fallback).
- Hardware acceleration is disabled (plausible without loaded GPU drivers). This explains the graphics problems with applications that use it.
Post the output from
pacman -Qs intel
and
pacman -Qs mesa-utils
@SGS
Das war etwas UnverstƤndnis meinerseits UND ein Hinweis
pacman -Qs intel output:
local/intel-compute-runtime 23.30.26918.9-1
Intel(R) Graphics Compute Runtime for oneAPI Level Zero and OpenCL(TM) Driver
local/intel-gmmlib 22.3.12-1
Intel Graphics Memory Management Library
local/intel-graphics-compiler 1:1.0.14828.8-1
Intel Graphics Compiler for OpenCL
local/intel-media-driver 23.3.5-1
Intel Media Driver for VAAPI ā Broadwell+ iGPUs
local/intel-oneapi-common 2023.2.0-1
Intel's oneAPI common variables and licensing
local/intel-oneapi-compiler-dpcpp-cpp-runtime-libs 2023.2.0-1
Intel oneAPI Data Parallel C++ compiler: Minimal runtime libraries
local/intel-oneapi-compiler-shared-runtime-libs 2023.2.0-1
Intel oneAPI compiler runtime libraries: Minimal compiler libraries
local/intel-oneapi-tbb 2021.10.0-3
Intel oneAPI Threading Building Blocks
local/intel-ucode 20231114-1
Microcode update files for Intel CPUs
local/lib32-libva-intel-driver 2.4.1-1
VA-API implementation for Intel G45 and HD Graphics family (32-bit)
local/lib32-vulkan-intel 1:23.2.1-2
Intel's Vulkan mesa driver (32-bit)
local/libmfx 23.2.2-2
Intel Media SDK dispatcher library
local/libva-intel-driver 2.4.1-2
local/libva-utils 2.20.0-1
Intel VA-API Media Applications and Scripts for libva
local/onetbb 2021.10.0-1
High level abstract threading library (oneAPI Threading Building Blocks)
local/openimagedenoise 1.4.3-1
Intel(R) Open Image Denoise library
local/openpgl 0.5.0-5
Intel Open Path Guiding Library
local/vulkan-intel 1:23.2.1-2
local/whois 5.5.20-1
Intelligent WHOIS client
local/xf86-video-intel 1:2.99.917+923+gb74b67f0-1 (xorg-drivers)
X.org Intel i810/i830/i915/945G/G965+ video drivers
pacman -Qs mesa-utils has no output
but since pacman -Qs mesa has out I will post it:
[š“] Ć pacman -Qs mesa
local/glu 9.0.3-1
Mesa OpenGL utility library
local/lib32-glu 9.0.3-1
Mesa OpenGL utility library (32 bits)
local/lib32-libva-mesa-driver 1:23.2.1-2
VA-API drivers (32-bit)
local/lib32-mesa 1:23.2.1-2
An open-source implementation of the OpenGL specification (32-bit)
local/lib32-mesa-demos 9.0.0-1
Mesa demos (32-bit)
local/lib32-mesa-vdpau 1:23.2.1-2
VDPAU drivers (32-bit)
local/lib32-vulkan-mesa-layers 1:23.2.1-2
Mesa's Vulkan layers (32-bit)
local/lib32-vulkan-radeon 1:23.2.1-2
Radeon's Vulkan mesa driver (32-bit)
local/libva-mesa-driver 1:23.2.1-2
VA-API drivers
local/mesa 1:23.2.1-2
local/mesa-demos 9.0.0-3
Mesa demos
local/mesa-vdpau 1:23.2.1-2
VDPAU drivers
local/vulkan-mesa-layers 1:23.2.1-2
local/vulkan-radeon 1:23.2.1-2
also can someone change the title please, atleast make the title Graphical issues on GNOME DE on most apps
It looks like you did not try this suggestion from 4 days ago.
sudo pacman -R intel-graphics-compiler intel-compute-runtime xf86-video-intel
