Hi, so I've switched the global theme from the default Sweetified Plasma to Breeze, and although the overall theme has been applied, I have graphical errors in both the System Settings and Launcher.
Possibly there are some configs overwriting Breeze, just tried to replicate (happens only when applying global theme, not if setting Breeze manually). What is interesting though is that Sweet menu buttons stayed for some apps even though Breeze was set
Im not interested in debugging this edition is meant to be used with Breeze, if you want to have stock look Id suggest either
resetting dotfiles to stock (delete all kind of KDE *rc files in ~/.config) or
removing garuda-dr460nized-settings and creating a new user account. This way you will have vanilla KDE look & settings
Hi, i want also a vanilla KDE look & settings, where i can choose the brezze dark theme and the settings for GTK Look, but i doesn't find a package "garuda-dr460nized-settings"!
