Gpu graphics acceleration
So I’ve searched and searched online but found nothing useful. The issue is other than games GPU acceleration doesn’t seem to work. Chrome and VM Workstation pro specifically. I’ve searched for solutions for each application but haven’t found a solution. I’m not at a loss for what to troubleshoot. It doesn’t appear to be application specific. For Chrome I’ve tried changing GPU renderer, vulkan, opengl, etc. For vmware the option to use my GPU shows up but then I get into the VM then I open a ttrpg website that is not very demanding and it claims I don’t have GPU acceleration on. I’m at a complete loss on what to troubleshoot.
Kernel: 6.6.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=435716c2-fab0-48db-a396-d7cd68ec4368 rw rootflags=subvol=@
resume=UUID=291ca7d0-2be9-4ea8-ae6a-b2e2b7e10d4d loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
Type: Desktop System: NZXT product: X570 AORUS MASTER v: -CF
Mobo: Gigabyte model: X570 AORUS MASTER v: x.x
serial: <superuser required> BIOS: American Megatrends v: F32
date: 01/18/2021
ID-1: hidpp_battery_4 charge: 43% condition: N/A volts: 3.8 min: N/A
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K270
Info: model: AMD Ryzen 9 5950X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 0 microcode: 0xA201009
Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB desc: 16x512 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3647 high: 4550 min/max: 2200/5083 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3617 2: 4550
3: 3627 4: 3638 5: 4284 6: 3640 7: 3565 8: 3628 9: 3640 10: 3640 11: 4550
12: 3640 13: 3640 14: 3640 15: 3640 16: 2200 17: 3639 18: 4532 19: 3639
20: 2879 21: 3768 22: 3639 23: 3258 24: 3640 25: 2200 26: 3640 27: 4550
28: 3640 29: 3640 30: 3640 31: 3640 32: 3640 bogomips: 217606
Device-1: NVIDIA GA102 [GeForce RTX 3080 Ti] driver: nvidia v: 545.29.06
2023-10; EOL~2026-12-xx) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
built: 2020-2023 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
off: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 0a:00.0 chip-ID: 10de:2208
Screen-1: 0 s-res: 1920x1080 s-dpi: 101 s-size: 483x272mm (19.02x10.71")
s-diag: 554mm (21.82")
Monitor-1: HDMI-A-1 mapped: HDMI-0 note: disabled
model: ViewSonic VA2256 Series serial: <filter> built: 2022 res: 1920x1080
hz: 60 dpi: 102 gamma: 1.2 size: 476x268mm (18.74x10.55")
diag: 546mm (21.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
inactive: wayland,device-1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3080 Ti/PCIe/SSE2
memory: 11.72 GiB
API: Vulkan v: 1.3.269 layers: 7 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3080 Ti driver: nvidia v: 545.29.06 device-ID: 10de:2208
surfaces: xcb,xlib
Device-1: NVIDIA GA102 High Definition Audio driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0a:00.1 chip-ID: 10de:1aef
Device-3: Audio-Technica AT2020USB+
lanes: 1 mode: 1.1 bus-ID: 3-6.3:5 chip-ID: 0909:001c class-ID: 0300
API: ALSA v: k6.6.4-zen1-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse
speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
Device-2: Intel I211 Gigabit Network vendor: Gigabyte driver: igb
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 05:00.0
Device-3: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: d000 bus-ID: 06:00.0
IF-ID-3: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-5:2 chip-ID: 8087:0029
Report: btmgmt ID: hci1 rfk-id: 1 state: down bt-service: enabled,running
Device-2: ASUSTek ASUS USB-BT500 driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-3:2 chip-ID: 0b05:190e
Report: ID: hci0 rfk-id: 0 state: down bt-service: enabled,running
Supported mdraid levels: raid6 raid5 raid4
Device-1: md0 maj-min: 9:0 type: mdraid level: raid-6 status: active
Info: report: 4/4 UUUU blocks: 7813772288 chunk-size: 512k
super-blocks: 1.2 algorithm: 2
Components: Online:
0: sdb maj-min: 8:16 size: 3.64 TiB
1: sdc maj-min: 8:32 size: 3.64 TiB
2: sdd maj-min: 8:48 size: 3.64 TiB
3: sde maj-min: 8:64 size: 3.64 TiB
Local Storage: total: raw: 16.37 TiB usable: 9.1 TiB used: 1.75 TiB (19.2%)
model: WDS100T2B0C-00PXH0 size: 931.51 GiB block-size: physical: 512 B
fw-rev: 211210WD temp: 66.8 C scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
model: WD40EFAX-68JH4N1 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
tech: HDD rpm: 5400 serial: <filter>
ID-5: /dev/sdd maj-min: 8:48 vendor: Western Digital
ID-6: /dev/sde maj-min: 8:64 vendor: Seagate model: ST4000NE001-3CR101
size: 3.64 TiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: HDD rpm: 7200
ID-1: / raw-size: 897.09 GiB size: 897.09 GiB (100.00%)
used: 794.97 GiB (88.6%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-2: /home raw-size: 897.09 GiB size: 897.09 GiB (100.00%)
ID-3: /var/log raw-size: 897.09 GiB size: 897.09 GiB (100.00%)
ID-4: /var/tmp raw-size: 897.09 GiB size: 897.09 GiB (100.00%)
ID-1: swap-1 type: partition size: 34.42 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 125.74 GiB used: 12.94 GiB (10.3%)
priority: 100 comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 32
System Temperatures: cpu: 78.5 C mobo: 58.0 C gpu: nvidia temp: 86 C
Fan Speeds (rpm): fan-1: 1227 fan-2: 0 fan-3: 0 gpu: nvidia fan: 60%
Power: 12v: N/A 5v: N/A 3.3v: 3.36 vbat: 3.27
Processes: 723 Uptime: 4d 1h 52m wakeups: 0 Memory: total: 128 GiB
note: est. available: 125.74 GiB used: 29.15 GiB (23.2%) Init: systemd
v: 254 default: graphical tool: systemctl Compilers: gcc: 13.2.1
clang: 16.0.6 Packages: 1731 pm: pacman pkgs: 1679 libs: 476
tools: octopi,paru,trizen,yay pm: flatpak pkgs: 52 Shell: fish v: 3.6.2
default: Bash v: 5.2.21 running-in: konsole inxi: 3.3.31
Garuda (2.6.19-2):
System install date:     2022-09-08
Last full system update: 2023-12-07
Failed units:            barrierapp.service connectiscsi.service mdmonitor.service vmware.service
