Goverly showing GPU at 97% when idle at desktop?
I have been trying out and reading about the different tools that come with Garuda Gaming Ed.
I found the Run MangoHud but I launch it and it does nothing. So I found Goverlay and read up and learned about it. Now I have a basic understanding about it. MangoHud is now working in game.
But I noticed that when goverlay is on the desktop with nothing else open or running my GPU is running at 96, 97, 98 %.
Is this normal?
Or is something maxing out my GPU for some reason?
Is there a way to launch MangoHud and just have it on the desktop? Or can it only be run in games?
What I tried:
I launched Nvidia-settings from the GUI and it runs and works fine.
System Information
NVIDIA Driver Version:   550.78
NVML Version:   12.550.78
Graphics Processor:   NVIDIA GeForce RTX 4070 Ti SUPER
GPU UUID:   GPU-679c1203-a27a-bbf4-daa0-cc3aa9e51472
CUDA Cores:   8448
VBIOS Version:   95.03.45.40.4B
Total Dedicated Memory:   16376 MB
Used Dedicated Memory:    926 MB (6%)
Memory Interface:   256-bit
GPU Utilization:   96 %
Bus ID:   PCI:1:0:0
PCI Device ID:   0x2705
PCI Vendor ID:   0x10de
PCIe Generation:   Gen4
Maximum PCIe Link Width:  x16
But when I run nvidia-settings from the terminal, I get a bunch of fails.
λ nvidia-settings
(nvidia-settings:122583): GLib-GObject-CRITICAL **: 19:58:21.399: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
(nvidia-settings:122583): Gtk-CRITICAL **: 19:58:21.409: gtk_widget_set_sensitive: assertion 'GTK_IS_WIDGET (widget)' failed
(nvidia-settings:122583): GLib-GObject-CRITICAL **: 19:58:21.410: invalid (NULL) pointer instance
(nvidia-settings:122583): GLib-GObject-CRITICAL **: 19:58:21.410: g_signal_handlers_block_matched: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
(nvidia-settings:122583): Gtk-CRITICAL **: 19:58:21.410: gtk_toggle_button_get_active: assertion 'GTK_IS_TOGGLE_BUTTON (toggle_button)' failed
(nvidia-settings:122583): GLib-GObject-CRITICAL **: 19:58:21.410: g_signal_handlers_unblock_matched: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
(nvidia-settings:122583): Gtk-CRITICAL **: 19:58:21.410: gtk_widget_set_sensitive: assertion 'GTK_IS_WIDGET (widget)' failed
(nvidia-settings:122583): GLib-GObject-CRITICAL **: 19:58:21.411: invalid (NULL) pointer instance
(nvidia-settings:122583): GLib-GObject-CRITICAL **: 19:58:21.411: g_signal_handlers_block_matched: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
(nvidia-settings:122583): Gtk-CRITICAL **: 19:58:21.411: gtk_toggle_button_get_active: assertion 'GTK_IS_TOGGLE_BUTTON (toggle_button)' failed
(nvidia-settings:122583): GLib-GObject-CRITICAL **: 19:58:21.411: g_signal_handlers_unblock_matched: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
(nvidia-settings:122583): Gtk-CRITICAL **: 19:58:21.411: gtk_widget_set_sensitive: assertion 'GTK_IS_WIDGET (widget)' failed
(nvidia-settings:122583): GLib-GObject-CRITICAL **: 19:58:33.890: invalid (NULL) pointer instance
(nvidia-settings:122583): GLib-GObject-CRITICAL **: 19:58:33.890: g_signal_handlers_block_matched: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
(nvidia-settings:122583): Gtk-CRITICAL **: 19:58:33.890: gtk_toggle_button_get_active: assertion 'GTK_IS_TOGGLE_BUTTON (toggle_button)' failed
(nvidia-settings:122583): GLib-GObject-CRITICAL **: 19:58:33.890: g_signal_handlers_unblock_matched: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
(nvidia-settings:122583): Gtk-CRITICAL **: 19:58:33.890: gtk_widget_set_sensitive: assertion 'GTK_IS_WIDGET (widget)' failed
(nvidia-settings:122583): GLib-GObject-CRITICAL **: 19:58:34.890: invalid (NULL) pointer instance
(nvidia-settings:122583): GLib-GObject-CRITICAL **: 19:58:34.890: g_signal_handlers_block_matched: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
(nvidia-settings:122583): Gtk-CRITICAL **: 19:58:34.890: gtk_toggle_button_get_active: assertion 'GTK_IS_TOGGLE_BUTTON (toggle_button)' failed
(nvidia-settings:122583): GLib-GObject-CRITICAL **: 19:58:34.890: g_signal_handlers_unblock_matched: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
(nvidia-settings:122583): Gtk-CRITICAL **: 19:58:34.890: gtk_widget_set_sensitive: assertion 'GTK_IS_WIDGET (widget)' failed
(nvidia-settings:122583): GLib-GObject-CRITICAL **: 19:58:35.890: invalid (NULL) pointer instance
(nvidia-settings:122583): GLib-GObject-CRITICAL **: 19:58:35.890: g_signal_handlers_block_matched: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
(nvidia-settings:122583): Gtk-CRITICAL **: 19:58:35.890: gtk_toggle_button_get_active: assertion 'GTK_IS_TOGGLE_BUTTON (toggle_button)' failed
(nvidia-settings:122583): GLib-GObject-CRITICAL **: 19:58:35.890: g_signal_handlers_unblock_matched: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
(nvidia-settings:122583): GLib-GObject-CRITICAL **: 19:58:35.891: invalid (NULL) pointer instance
(nvidia-settings:122583): GLib-GObject-CRITICAL **: 19:58:35.891: g_signal_handlers_block_matched: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
(nvidia-settings:122583): Gtk-CRITICAL **: 19:58:35.891: gtk_toggle_button_get_active: assertion 'GTK_IS_TOGGLE_BUTTON (toggle_button)' failed
(nvidia-settings:122583): GLib-GObject-CRITICAL **: 19:58:35.891: g_signal_handlers_unblock_matched: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
(nvidia-settings:122583): Gtk-CRITICAL **: 19:58:35.891: gtk_widget_set_sensitive: assertion 'GTK_IS_WIDGET (widget)' failed
(nvidia-settings:122583): GLib-GObject-CRITICAL **: 19:58:36.891: invalid (NULL) pointer instance
(nvidia-settings:122583): GLib-GObject-CRITICAL **: 19:58:36.891: g_signal_handlers_block_matched: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
(nvidia-settings:122583): Gtk-CRITICAL **: 19:58:36.891: gtk_toggle_button_get_active: assertion 'GTK_IS_TOGGLE_BUTTON (toggle_button)' failed
(nvidia-settings:122583): GLib-GObject-CRITICAL **: 19:58:36.891: g_signal_handlers_unblock_matched: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
(nvidia-settings:122583): Gtk-CRITICAL **: 19:58:36.891: gtk_widget_set_sensitive: assertion 'GTK_IS_WIDGET (widget)' failed
The apt still runs despite that and works and shows the GUI on screen
But If I try and run GreenWithEnvy I get:
NV-CONTROL X extenstion not found.
I found the archwiki article for that error but fix is for optimus-manager and integrated laptops. So that’s no help.
I searched our forum and haven’t found any thing to fix greenwithenvy either.
Am I missing something or doing it wrong?
So Now I’m kinda stuck on what to do next.
```text
  Kernel: 6.9.1-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1 clocksource: tsc
    root=UUID=0a5c0957-2fe3-479a-bccd-84608d5b2bd4 rw rootflags=subvol=@ quiet loglevel=3 ibt=off
  Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.2.0 wm: kwin_wayland vt: 1
  Type: Desktop System: CORSAIR product: CORSAIR VENGEANCE i7500 v: H01
  Mobo: Micro-Star model: PRO Z790-P WIFI (MS-7E06) v: 2.0 serial: <superuser required>
    part-nu: CS-9050095-NA uuid: <superuser required> UEFI: American Megatrends LLC. v: A.C2
    date: 02/19/2024
  Info: model: Intel Core i7-14700KF bits: 64 type: MST AMCP arch: Raptor Lake gen: core 14
    level: v3 note: check built: 2022+ process: Intel 7 (10nm) family: 6 model-id: 0xB7 (183)
    stepping: 1 microcode: 0x123
  Topology: cpus: 1x cores: 20 mt: 8 tpc: 2 st: 12 threads: 28 smt: enabled cache: L1: 1.8 MiB
    desc: d-12x32 KiB, 8x48 KiB; i-8x32 KiB, 12x64 KiB L2: 28 MiB desc: 8x2 MiB, 3x4 MiB L3: 33 MiB
    desc: 1x33 MiB
  Speed (MHz): avg: 3515 high: 5500 min/max: 800/5500:5600:4300 scaling: driver: intel_pstate
    governor: powersave cores: 1: 5500 2: 5058 3: 5460 4: 800 5: 5500 6: 800 7: 5500 8: 800 9: 5500
    10: 800 11: 5072 12: 5500 13: 5500 14: 800 15: 5500 16: 800 17: 4202 18: 4199 19: 4167 20: 800
    21: 3905 22: 3809 23: 4200 24: 4224 25: 4220 26: 800 27: 800 28: 4208 bogomips: 191385
  Device-1: NVIDIA AD103 [GeForce RTX 4070 Ti SUPER] vendor: Gigabyte driver: nvidia v: 550.78
    alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current (as of 2024-04) arch: Lovelace
    code: AD1xx process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
    active: none off: DP-1,HDMI-A-1 empty: DP-2,DP-3 bus-ID: 01:00.0 chip-ID: 10de:2705
  Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.0 compositor: kwin_wayland
    driver: X: loaded: nvidia unloaded: modesetting alternate: fbdev,nouveau,nv,vesa gpu: nvidia
    d-rect: 3840x1080 display-ID: 0
  Monitor-1: DP-1 pos: primary,left res: 1920x1080 size: N/A modes: N/A
  Monitor-2: HDMI-A-1 pos: right res: 1920x1080 size: N/A modes: N/A
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2 drv: swrast gbm:
    drv: nvidia surfaceless: drv: nvidia wayland: drv: nvidia x11: drv: zink inactive: device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.78 glx-v: 1.4 direct-render: yes
    renderer: NVIDIA GeForce RTX 4070 Ti SUPER/PCIe/SSE2 memory: 15.62 GiB display-ID: :1.0
  API: Vulkan v: 1.3.279 layers: 11 device: 0 type: discrete-gpu name: NVIDIA GeForce RTX 4070
    Ti SUPER driver: nvidia v: 550.78 device-ID: 10de:2705 surfaces: xcb,xlib,wayland
  Device-1: Intel Raptor Lake High Definition Audio vendor: Micro-Star MSI driver: snd_hda_intel
    v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:7a50
  Device-2: NVIDIA vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:22bb class-ID: 0403
  API: ALSA v: k6.9.1-zen1-2-zen status: kernel-api with: aoss type: oss-emulator tools: N/A
  Server-1: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse status: active
  Device-1: Intel Raptor Lake-S PCH CNVi WiFi driver: iwlwifi v: kernel bus-ID: 00:14.3
    chip-ID: 8086:7a70 class-ID: 0280
  Device-2: Intel Ethernet I225-V vendor: Micro-Star MSI driver: igc v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 port: N/A bus-ID: 04:00.0 chip-ID: 8086:15f3 class-ID: 0200
  Info: services: NetworkManager, systemd-timesy
ncd, wpa_supplicant
  Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1
    mode: 1.1 bus-ID: 1-14:6 chip-ID: 8087:0033 class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.3 lmp-v: 12 status:
  Local Storage: total: 931.51 GiB used: 154.39 GiB (16.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Corsair model: MP600 CORE XT size: 931.51 GiB
    fw-rev: ELFMC1.0 temp: 42.9 C scheme: GPT
  ID-1: / raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 154.39 GiB (16.6%) fs: btrfs
  ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 584 KiB (0.2%) fs: vfat
  ID-3: /home raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 154.39 GiB (16.6%) fs: btrfs
  ID-4: /var/log raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 154.39 GiB (16.6%)
  ID-5: /var/tmp raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 154.39 GiB (16.6%)
  ID-1: swap-1 type: zram size: 31.19 GiB used: 256 KiB (0.0%) priority: 100 comp: zstd
    avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 28 dev: /dev/zram0
  System Temperatures: cpu: 40.0 C mobo: N/A
  Memory: total: 32 GiB available: 31.19 GiB used: 4.89 GiB (15.7%)
  Processes: 491 Power: uptime: 4h 19m states: freeze,mem,disk suspend: deep avail: s2idle
    wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 12.44 GiB
    services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd v: 255
  Packages: pm: pacman pkgs: 1806 libs: 531 tools: paru Compilers: clang: 17.0.6 gcc: 14.1.1
    Client: shell wrapper v: 5.2.26-release inxi: 3.3.34
  System install date:     2024-05-25
  Last full system update: 2024-05-29
OK, Did some diggin and found nvtop.
Now this is a cool app.
So now I figured out goverlay is actually maxing out my GPU.
I can actually see the GPU usage in nvtop. So panic over.
