Hello Garuda users.
I am having problems with gnome settings. Power setting won't save. The problem happens only in the power section.
Unfortunately i can't upload the video of the problem because Im a new user
Kernel: 5.19.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=3b81bac4-4a01-4e5b-8c3f-43ebb8a34184 rw [email protected]
resume=UUID=0b6ee7dc-aa5a-4dc4-b885-8f9f0d032da9 loglevel=3
Desktop: GNOME v: 42.5 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 42.0
Type: Desktop Mobo: ASRock model: H310CM-HDV serial: <superuser required>
UEFI-[Legacy]: American Megatrends v: P4.20 date: 05/14/2019
Info: model: Intel Core i5-9400F bits: 64 type: MCP arch: Coffee Lake
gen: core 9 level: v3 built: 2018 process: Intel 14nm family: 6
desc: 1x9 MiB
Speed (MHz): avg: 3999 high: 4001 min/max: 800/4100 scaling:
driver: intel_pstate governor: powersave cores: 1: 3997 2: 4000 3: 4001
4: 3998 5: 4000 6: 4000 bogomips: 34798
disabled
Type: mmio_stale_data mitigation: Clear CPU buffers; SMT disabled
PBRSB-eIBRS: Not affected
Device-1: NVIDIA TU106 [GeForce RTX 2060 Rev. A] driver: nvidia v: 515.76
alternate: nouveau,nvidia_drm non-free: 515.xx+ status: current (as of
2022-08) arch: Turing code: TUxxx process: TSMC 12nm built: 2018-22 pcie:
gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1f08
compositor: gnome-shell driver: X: loaded: nvidia gpu: nvidia
display-ID: :1 screens: 1
Screen-1: 0 s-res: 3360x1080 s-dpi: 96 s-size: 889x286mm (35.00x11.26")
s-diag: 934mm (36.77")
Monitor-1: DP-0 pos: primary,top-right res: 1920x1080 dpi: 94
size: 521x293mm (20.51x11.54") diag: 598mm (23.53") modes: N/A
Monitor-2: HDMI-0 pos: bottom-l res: 1440x900 hz: 60 dpi: 90
size: 408x255mm (16.06x10.04") diag: 481mm (18.94") modes: N/A
OpenGL: renderer: NVIDIA GeForce RTX 2060/PCIe/SSE2 v: 4.6.0 NVIDIA
515.76 direct render: Yes
Device-1: Intel 200 Series PCH HD Audio vendor: ASRock
driver: snd_hda_intel v: kernel bus-ID: 1-4:3 chip-ID: 1532:0528
bus-ID: 00:1f.3 chip-ID: 8086:a2f0 class-ID: 0300 class-ID: 0403
Device-2: NVIDIA TU106 High Definition Audio driver: snd_hda_intel
chip-ID: 10de:10f9 class-ID: 0403
Device-3: Razer USA BlackShark V2 Pro type: USB
Sound Server-1: ALSA v: k5.19.12-zen1-1-zen running: yes
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
Local Storage: total: 2.27 TiB used: 1.3 TiB (57.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37480G
type: SSD serial: <filter> rev: K1B3 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Gigabyte model: GP-GSTFS31512GNTD-V
type: SSD serial: <filter> rev: 00Z8 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: A-Data model: HC660
size: 931.51 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 9203 scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: Western Digital
model: WD5000BEVT-16ZAT0 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B type: HDD rpm: 5400 serial: <filter> rev: 1.75 scheme: MBR
ID-1: / raw-size: 459.82 GiB size: 459.82 GiB (100.00%) used: 33.51 GiB
(7.3%) fs: btrfs dev: /dev/sdb1 maj-min: 8:17
ID-2: /home raw-size: 459.82 GiB size: 459.82 GiB (100.00%) used: 33.51
GiB (7.3%) fs: btrfs dev: /dev/sdb1 maj-min: 8:17
ID-3: /var/log raw-size: 459.82 GiB size: 459.82 GiB (100.00%) used: 33.51
ID-4: /var/tmp raw-size: 459.82 GiB size: 459.82 GiB (100.00%) used: 33.51
ID-1: swap-1 type: zram size: 15.56 GiB used: 4.2 MiB (0.0%)
ID-2: swap-2 type: partition size: 17.12 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sdb2 maj-min: 8:18
System Temperatures: cpu: 47.0 C mobo: N/A gpu: nvidia temp: 45 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 40%
Processes: 278 Uptime: 1h 2m wakeups: 2509 Memory: 15.56 GiB used: 4.39 GiB
(28.2%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: 1595 pm: pacman pkgs: 1588 libs: 430
tools: gnome-software,pamac,paru pm: flatpak pkgs: 7 Shell: fish v: 3.5.1
default: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.21
Garuda (2.6.8-1):
System install date: 2022-09-21
Last full system update: 2022-09-30
