Hi,
I don't have the option to share home folders in Nautilus.
No sharing folder CM at all.
Any advice on how to get it working?
Also, can't see Windows 11 or another linux machine in network.
Thanks a lot,
AJ
Hi,
Thanks a lot,
AJ
Welcome
Hello Garuda users.
Refusing to post the output of the required "garuda-inxi" on a help request will likely result in you not receiving any help from the Garuda team. A failure to provide your system specs may also result in your thread being closed without notice, (as without this information providing assistance is often next to impossible).
Before opening a new help request, please search the Arch and Garuda Wiki's, and read any relevant sections related to your issue. Also, thoroughly search any error messages in the forum's search engine and on the web. For in depth information on how to search for answers to Linux issues effectively read the tips on the Garuda Wiki:
Kernel: 5.18.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=096ecad1-d578-4f0e-b5fe-897dfc965bbe rw rootflags=subvol=@
loglevel=3 ibt=off
Desktop: GNOME v: 42.2 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 42.0
Mobo: ASUSTeK model: ROG STRIX B550-F GAMING (WI-FI) v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2604
date: 02/25/2022
Info: model: AMD Ryzen 7 3800XT bits: 64 type: MT MCP arch: Zen 2 gen: 3
built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 4149 high: 4222 min/max: 2200/4723 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4180 2: 4220
3: 4170 4: 4193 5: 4201 6: 4173 7: 4200 8: 4198 9: 4222 10: 4210 11: 4200
12: 3628 13: 4202 14: 3972 15: 4200 16: 4222 bogomips: 124807
mitigation: Retpolines, IBPB: conditional, STIBP: conditional, RSB filling
Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] vendor: Gigabyte
driver: nvidia v: 515.48.07 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Ampere process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 2 speed: 5 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 08:00.0 chip-ID: 10de:2504 class-ID: 0300
Device-2: Logitech BRIO Ultra HD Webcam type: USB
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo bus-ID: 4-1:2
chip-ID: 046d:085e class-ID: 0300 serial: <filter>
compositor: gnome-shell driver: X: loaded: nvidia unloaded: modesetting
alternate: fbdev,nouveau,nv,vesa gpu: nvidia display-ID: :1 screens: 1
Screen-1: 0 s-res: 7680x2160 s-dpi: 96 s-size: 2032x572mm (80.00x22.52")
s-diag: 2111mm (83.11")
Monitor-1: DP-0 pos: right res: 3840x2160 hz: 60 dpi: 161
size: 607x345mm (23.9x13.58") diag: 698mm (27.49") modes: N/A
Monitor-2: DP-2 pos: primary,left res: 3840x2160 hz: 60 dpi: 140
size: 697x392mm (27.44x15.43") diag: 800mm (31.48") modes: N/A
OpenGL: renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2
v: 4.6.0 NVIDIA 515.48.07 direct render: Yes
Device-1: NVIDIA vendor: Gigabyte driver: snd_hda_intel
bus-ID: 3-2.3.2.2.3:84 v: kernel pcie: chip-ID: 0951:16df class-ID: 0300
gen: 4 serial: <filter> speed: 16 GT/s lanes: 16 bus-ID: 08:00.1
bus-ID: 0a:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Kingston HyperX QuadCast type: USB
Device-4: Logitech BRIO Ultra HD Webcam type: USB
Sound Server-1: ALSA v: k5.18.3-zen1-1-zen running: yes
speed: 5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 8086:2723 class-ID: 0280
bus-ID: 1-5:4 chip-ID: 8087:0029 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 1 state: down
address: <filter>
Local Storage: total: 42.99 TiB used: 7.37 TiB (17.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Sabrent model: Rocket 4.0 2TB
lanes: 4 type: SSD serial: <filter> rev: RKT401.3 temp: 39.9 C
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Intel model: SSDPEKNW020T8
lanes: 4 type: SSD serial: <filter> rev: 004C temp: 31.9 C scheme: GPT
model: WDS100T2B0A-00SM50 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 00WD
ID-4: /dev/sdb maj-min: 8:16 vendor: Toshiba model: HDWD110
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: A8R0
ID-5: /dev/sdc maj-min: 8:32 type: USB vendor: Western Digital
model: WD40NMZM-59Y94S1 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B type: HDD rpm: 5400 serial: <filter> rev: 2003 scheme: GPT
ID-6: /dev/sdd maj-min: 8:48 type: USB vendor: Kingston
model: SHSX100960G size: 894.25 GiB block-size: physical: 4096 B
logical: 512 B type: SSD serial: <filter> scheme: GPT
ID-7: /dev/sde maj-min: 8:64 type: USB vendor: Samsung
model: Portable SSD T5 size: 931.51 GiB block-size: physical: 512 B
ID-8: /dev/sdf maj-min: 8:80 type: USB vendor: Seagate
model: Expansion Desk size: 2.73 TiB block-size: physical: 4096 B
logical: 512 B type: N/A serial: <filter> rev: 0911 scheme: GPT
ID-9: /dev/sdg maj-min: 8:96 type: USB vendor: Crucial
model: CT250MX500SSD1 size: 232.89 GiB block-size: physical: 512 B
ID-10: /dev/sdh maj-min: 8:112 type: USB vendor: Western Digital
model: WD Game Drive size: 1.82 TiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: 4000 scheme: GPT
ID-11: /dev/sdi maj-min: 8:128 type: USB vendor: Western Digital
ID-12: /dev/sdj maj-min: 8:144 type: USB vendor: Seagate
model: ST3000DM001-1ER166 size: 2.73 TiB block-size: physical: 4096 B
logical: 4096 B type: HDD rpm: 7200 serial: <filter> rev: 1153
ID-13: /dev/sdk maj-min: 8:160 type: USB vendor: Western Digital
model: WD My Passport 0820 size: 1.82 TiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: 1012 scheme: GPT
ID-14: /dev/sdl maj-min: 8:176 type: USB vendor: Seagate
model: Backup+ Hub BK size: 7.28 TiB block-size: physical: 4096 B
logical: 512 B type: N/A serial: <filter> rev: D781 scheme: GPT
ID-15: /dev/sdm maj-min: 8:192 type: USB vendor: ASUS model: ROG ESD-S1C
size: 1.82 TiB block-size: physical: 512 B logical: 512 B type: N/A
ID-16: /dev/sdn maj-min: 8:208 type: USB vendor: Western Digital
model: WD Game Drive size: 7.28 TiB block-size: physical: 4096 B
logical: 512 B type: N/A serial: <filter> rev: 5006 scheme: GPT
ID-17: /dev/sdo maj-min: 8:224 type: USB vendor: Western Digital
model: WD My Book 25EE size: 5.46 TiB block-size: physical: 4096 B
logical: 512 B type: N/A serial: <filter> rev: 4007 scheme: GPT
ID-1: / raw-size: 1.75 TiB size: 1.75 TiB (100.00%) used: 177.44 GiB (9.9%)
used: 29.8 MiB (10.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 1.75 TiB size: 1.75 TiB (100.00%)
used: 177.44 GiB (9.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 1.75 TiB size: 1.75 TiB (100.00%)
ID-5: /var/tmp raw-size: 1.75 TiB size: 1.75 TiB (100.00%)
ID-1: swap-1 type: zram size: 62.71 GiB used: 1.67 GiB (2.7%)
ID-2: swap-2 type: partition size: 69.05 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 76.5 C mobo: N/A gpu: nvidia temp: 37 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 60%
Processes: 581 Uptime: 3d 10m wakeups: 0 Memory: 62.71 GiB
used: 22.08 GiB (35.2%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 alt: 11 clang: 13.0.1 Packages:
pacman: 1797 lib: 489 flatpak: 0 Shell: fish v: 3.4.1
running-in: gnome-terminal inxi: 3.3.17
Garuda (2.6.3-2):
System install date: 2022-06-01
Last full system update: 2022-06-13 ↻
Can you explain what you mean by this?
I would like to share home folders Documents, Downloads, Pictures, etc just like Plasma does. What I can tell is that the KDE version of Garuda has more options than the Gnome one, at least in KDE I don't have to worry about sharing because it just works unlike on Gnome which it has to be made to share. I have been reading and got the Sharing Options CM to show in Files but I get 'net usershare' returned error 255.
Thank you
Run
setup-assistant
And install printer+ scanner+Samba support
Also install additional gnome components
Then reboot
And see if sharing works
I did what you asked and still the same.
'net usershare' returned error 255 error.
Thanks
Is nautilus-share installed?
Edit: ops, might be this bug
yes, it is
There is a possible patch attached.
Quite frankly I'm no expert on that.
You may want to give a look at
https://wiki.archlinux.org/title/Patching_packages#Applying_patches
Not expert at all on this, don't know how to do it.
Try with the guide.
Probably you could also download the source
paru -G nautilus-share
change that affected file that you see in the patch (should be shares.c) as per the bug report and compile, I think with
updpkgsums
makepkg -sri
And hopefully someone will help you better.
Thankd for your reply, I did what you asked and I was searching with google and found out that Gnome 42.2 dropped home folder sharing with samba and went the dav route.
Going with the dav route Windows can see all the home folders and media. Go figure.
