On a new install of Garuda Linux GNOME, the icons in the dock aren't centered. They are towards the bottom of the dock.
Have you updated to see if this has been fixed?
I got the newest image and installed it a few hours ago. I also just updated. It still doesn't work
What doesn’t work? The update process?
Some slightly misaligned icons doesn’t really count as “not working”…
Sorry. I meant to say the icons are still in the wrong place.
OK, so if the issue is present in the live installer environment, after installing, and after an update then that likely means there's an issue with the shell theme, so that will need to be fixed by the upstream project.
Have you checked to see if this has been reported or fixed upstream?
I have not checked.
