Well, the title says it all: the GIMP crashes when I'm trying to use my tablet. More specifically: when I'm trying to use one of things a mouse can't do but a tablet does. Like for example using pen pressure or pen's buttons.
I tried reinstall GIMP and deleting my device settings, but without any good results. I'm using also Krita app and it doesn't have problems with my tablet. I thought it may be something with GIMP, but there was no update with this program. It just suddenly stopped working I thus suspect something is with tablet's drivers. I also have looked at Arch Linux Bugtracker:: Arch Linux: Tasklist webpage (it is where the GIMP's crash dialog points at when a crash happens), but nobody posted a solution to my problem.
Kernel: 6.3.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=6a135e81-5d37-4390-8a10-a9eef293c0d9 rw [email protected]
systemd.unified_cgroup_hierarchy=1 loglevel=3 ibt=off
Desktop: Cinnamon v: 5.6.8 tk: GTK v: 3.24.37 wm: muffin dm: LightDM
v: 1.32.0 Distro: Garuda Linux base: Arch Linux
Type: Laptop System: Acer product: Aspire A515-54G v: V1.24 serial: <filter>
Mobo: CML model: Doc_WC v: V1.24 serial: <filter> UEFI: Insyde v: 1.24
date: 07/07/2021
ID-1: BAT1 charge: 38.3 Wh (100.0%) condition: 38.3/48.9 Wh (78.3%)
volts: 16.2 min: 15.2 model: LGC AC14B8K type: Li-ion serial: <filter>
status: full
Info: model: Intel Core i5-10210U socket: BGA1528 (U3E1) note: check
bits: 64 type: MT MCP arch: Comet/Whiskey Lake note: check gen: core 10
level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x8E (142) stepping: 0xC (12) microcode: 0xF6
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 1937 high: 2100 min/max: 400/4200 base/boost: 2673/8300
ext-clock: 100 MHz cores: 1: 2100 2: 2100 3: 2100 4: 2100 5: 2100 6: 2100
7: 2100 8: 800 bogomips: 33599
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Acer Incorporated ALI
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 0000:00:02.0
Device-2: NVIDIA GP108M [GeForce MX250] vendor: Acer Incorporated ALI
driver: nouveau v: kernel non-free: 530.xx+ status: current (as of 2023-05)
arch: Pascal code: GP10x process: TSMC 16nm built: 2016-21
bus-ID: 0000:02:00.0 chip-ID: 10de:1d13 class-ID: 0302
Device-3: Quanta HD User Facing driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 0408:a061
class-ID: 0e02
Display: x11 server: X.Org v: 21.1.8 driver: X: loaded: intel,nouveau
unloaded: modesetting alternate: fbdev,nv,vesa dri: i965,nouveau gpu: i915
Monitor-1: eDP-1 mapped: eDP1 model: AU Optronics 0x61ed built: 2018
res: 1920x1080 hz: 60 dpi: 143 gamma: 1.2 size: 340x190mm (13.39x7.48")
API: OpenGL v: 4.6 Mesa 23.0.3 renderer: Mesa Intel UHD Graphics (CML GT2)
direct-render: Yes
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Acer Incorporated ALI
bus-ID: 0000:00:1f.3 chip-ID: 8086:02c8 class-ID: 0403
API: ALSA v: k6.3.2-zen1-1-zen status: kernel-api with: osspd status: off
tools: N/A
Server-2: PipeWire v: 0.3.70 status: n/a (root, process) with:
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 0000:00:14.3 chip-ID: 8086:02f0 class-ID: 0280
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 3000
bus-ID: 0000:03:00.0 chip-ID: 10ec:8168 class-ID: 0200
driver: intel_nvme_remap v: N/A port: 5060 bus-ID: 0000:00:17.0
chip-ID: 8086:282a rev: class-ID: 0104
Local Storage: total: 953.87 GiB used: 147.04 GiB (15.4%)
size: 953.87 GiB block-size: physical: 512 B logical: 512 B tech: SSD
serial: <filter> fw-rev: 002C temp: 27.9 C scheme: GPT
ID-1: / raw-size: 476.38 GiB size: 476.38 GiB (100.00%)
used: 146.99 GiB (30.9%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p5
maj-min: 259:5
used: 54.6 MiB (56.9%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 476.38 GiB size: 476.38 GiB (100.00%)
maj-min: 259:5
ID-4: /var/log raw-size: 476.38 GiB size: 476.38 GiB (100.00%)
maj-min: 259:5
ID-5: /var/tmp raw-size: 476.38 GiB size: 476.38 GiB (100.00%)
maj-min: 259:5
ID-1: swap-1 type: zram size: 7.58 GiB used: 1.22 GiB (16.1%)
System Temperatures: cpu: 41.0 C pch: 44.0 C mobo: N/A gpu: nouveau
temp: 40.0 C
Processes: 293 Uptime: 10h 46m wakeups: 16 Memory: available: 7.58 GiB
used: 2.88 GiB (38.0%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: dpkg
pkgs: 0 pm: pacman pkgs: 1959 libs: 505 tools: pamac,paru
Shell: garuda-inxi (sudo) default: Bash v: 5.1.16 running-in: gnome-terminal
inxi: 3.3.27
System install date: 2021-12-22
Last full system update: 2023-05-19
Windows dual boot: Yes
