Kernel: 5.18.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=e46fe81f-7dfd-4f6a-a9fb-9cf9d645f98a
rw rootflags=subvol=@ quiet quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0
resume=UUID=e912bbf4-d5e0-42e1-9d5e-5f0b144b76b4 loglevel=3
Desktop: KDE Plasma v: 5.25.0 tk: Qt v: 5.15.5 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: HP product: OMEN by HP Laptop 16-c0xxx v: N/A serial: <superuser required>
Chassis: type: 10 serial: <superuser required>
Mobo: HP model: 8902 v: 89.55 serial: <superuser required> UEFI: AMI v: F.14 date: 02/11/2022
ID-1: BAT0 charge: 70.0 Wh (99.9%) condition: 70.1/70.1 Wh (100.0%) volts: 17.4 min: 15.4
model: HP Primary type: Li-ion serial: <filter> status: N/A cycles: 4
Info: model: AMD Ryzen 7 5800H with Radeon Graphics bits: 64 type: MT MCP arch: Zen 3 gen: 4
built: 2021-22 process: TSMC n7 (7nm) family: 0x19 (25) model-id: 0x50 (80) stepping: 0
microcode: 0xA50000C
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache: L1: 512 KiB
desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 3633 high: 4264 min/max: 1200/4462 boost: enabled scaling:
driver: acpi-cpufreq governor: performance cores: 1: 3602 2: 3534 3: 3543 4: 3531 5: 3583
6: 3554 7: 4095 8: 3588 9: 3877 10: 3577 11: 3536 12: 3476 13: 3458 14: 3475 15: 3443 16: 4264
bogomips: 102213
mitigation: Retpolines, IBPB: conditional, IBRS_FW, STIBP: always-on, RSB filling
Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M] vendor: Hewlett-Packard driver: amdgpu
v: kernel arch: RDNA 2 process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: none off: DP-1 empty: HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:73ff
class-ID: 0380
Device-2: AMD Cezanne vendor: Hewlett-Packard driver: amdgpu v: kernel arch: GCN 5.1
process: TSMC n7 (7nm) built: 2018-21 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s ports: active: eDP-1 empty: DP-2 bus-ID: 09:00.0 chip-ID: 1002:1638
Device-3: Luxvisions Innotech HP Wide Vision HD Camera type: USB driver: uvcvideo
bus-ID: 1-3:3 chip-ID: 30c9:000e class-ID: 0e02
Display: x11 server: X.Org v: 21.1.3 with: Xwayland v: 22.1.2 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa gpu: amdgpu display-ID: :0
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.65x15.00") s-diag: 777mm (30.58")
Monitor-1: DP-1 mapped: DisplayPort-1-0 note: disabled model: BenQ PD2700U serial: <filter>
built: 2021 res: N/A dpi: 163 gamma: 1.2 size: 597x336mm (23.5x13.23") diag: 685mm (27")
ratio: 16:9 modes: max: 3840x2160 min: 720x400
Monitor-2: eDP-1 mapped: eDP pos: primary model: BOE Display 0x09e5 built: 2020 res: 2560x1440
hz: 165 dpi: 183 gamma: 1.2 size: 355x200mm (13.98x7.87") diag: 407mm (16") ratio: 16:9 modes:
max: 2560x1440 min: 640x480
OpenGL: renderer: AMD RENOIR (LLVM 13.0.1 DRM 3.46 5.18.5-zen1-1-zen) v: 4.6 Mesa 22.1.1
direct render: Yes
Device-1: AMD Navi 21/23 HDMI/DP Audio vendor: Hewlett-Packard driver: snd_hda_intel
bus-ID: 3-1.3:11 v: kernel pcie: chip-ID: 0763:410b class-ID: fe01 gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28 class-ID: 0403
Device-2: AMD Renoir Radeon High Definition Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 09:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Hewlett-Packard
alternate: snd_pci_acp3x,snd_pci_acp5x,snd_pci_acp6x,snd_acp_pci,snd_sof_amd_renoir pcie:
gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 09:00.5
Device-4: AMD Family 17h/19h HD Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 09:00.6
Device-5: M-Audio AIR 192 4 type: USB driver: snd-usb-audio
Sound Server-1: ALSA v: k5.18.5-zen1-1-zen running: yes
Sound Server-3: PulseAudio v: 16.0 running: no
Sound Server-4: PipeWire v: 0.3.52 running: yes
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 04:00.0
Device-2: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter vendor: Hewlett-Packard
driver: rtw89_8852ae v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 05:00.0
chip-ID: 10ec:8852 class-ID: 0280
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8 bus-ID: 1-4:4
chip-ID: 0bda:2852 class-ID: e001 serial: <filter>
Local Storage: total: 1.84 TiB used: 168 GiB (8.9%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Samsung model: SSD 970 EVO Plus 1TB size: 931.51 GiB
rev: 2B2QEXM7 temp: 43.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: MZVLB1T0HBLR-000H1 size: 953.87 GiB
rev: HPS0NEXF temp: 34.9 C scheme: GPT
ID-1: / raw-size: 914.67 GiB size: 914.67 GiB (100.00%) used: 168 GiB (18.4%) fs: btrfs
dev: /dev/nvme0n1p2 maj-min: 259:7
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 580 KiB (0.2%) fs: vfat
dev: /dev/nvme0n1p1 maj-min: 259:6
ID-3: /home raw-size: 914.67 GiB size: 914.67 GiB (100.00%) used: 168 GiB (18.4%) fs: btrfs
ID-4: /var/log raw-size: 914.67 GiB size: 914.67 GiB (100.00%) used: 168 GiB (18.4%) fs: btrfs
ID-5: /var/tmp raw-size: 914.67 GiB size: 914.67 GiB (100.00%) used: 168 GiB (18.4%) fs: btrfs
ID-1: swap-1 type: zram size: 14.98 GiB used: 2.2 MiB (0.0%) priority: 100 dev: /dev/zram0
ID-2: swap-2 type: partition size: 16.55 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:8
System Temperatures: cpu: 57.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2619 fan-2: 2422
GPU: device: amdgpu temp: 46.0 C mem: 46.0 C fan: 0 watts: 4.00 device: amdgpu temp: 55.0 C
Processes: 409 Uptime: 16m wakeups: 2 Memory: 14.98 GiB used: 6.35 GiB (42.4%) Init: systemd
v: 251 default: graphical tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages:
pacman: 2400 lib: 575 Client: shell wrapper v: 5.1.16-release inxi: 3.3.18
Garuda (2.6.4-1):
System install date: 2022-04-07
Last full system update: 2022-06-21
Is partially upgraded: Yes
Snapshots:
Snapper
Kernel Log
21.06.22 07:06 usb 3-2 new full-speed USB device number 22 using xhci_hcd
21.06.22 07:06 usb 3-2 New USB device found, idVendor=045e, idProduct=02ea, bcdDevice= 3.01
21.06.22 07:06 usb 3-2 New USB device strings: Mfr=1, Product=2, SerialNumber=3
21.06.22 07:06 usb 3-2 Product: Controller
21.06.22 07:06 usb 3-2 Manufacturer: ZEROPLUS
21.06.22 07:06 usb 3-2 SerialNumber: 3145303033313032364144423946
21.06.22 07:06 usb 3-2 reset full-speed USB device number 22 using xhci_hcd
21.06.22 07:06 xone-gip gip0 gip_create_adapter: registered
21.06.22 07:06 xone-gip gip0.0 gip_init_client: initialized
21.06.22 07:06 xone-gip gip0.0 gip_handle_pkt_announce: address=7e:ed:81:6a:db:9f, vendor=0x045e, product=0x02ea
21.06.22 07:06 xone-gip gip0.0 gip_handle_pkt_announce: firmware=3.1.1221.0, hardware=1284.1.1.1
21.06.22 07:06 xone-gip gip0.0 gip_parse_chunk: offset=0x00da, length=0x3a
21.06.22 07:06 xone-gip gip0.0 gip_init_chunk_buffer: length=0x00da
21.06.22 07:06 xone-gip gip0.0 gip_parse_chunk: length mismatch
21.06.22 07:06 xone-gip gip0 gip_process_buffer: process packet failed: -22
21.06.22 07:06 xone-gip packet 04 a0 01 3b 3a 00 02 00 01 00 02 00 02 00 02 00
21.06.22 07:06 xone-gip packet 03 00 03 00 01 00 00 08 01 02 03 04 06 07 0c 1e
21.06.22 07:06 xone-gip packet 07 01 04 05 06 0a 0c 1e 01 1a 00 57 69 6e 64 6f
21.06.22 07:06 xone-gip packet 77 73 2e 58 62 6f 78 2e 49 6e 70 75 74 2e 47 61
21.06.22 07:06 xone-wired 3-2 .0: xone_wired_complete_data_in: process failed: -22
21.06.22 07:06 xone-gip packet 04 a0 01 3b 75 6d 65 70 61 64 03 56 ff 76 97 fd
21.06.22 07:06 xone-gip packet 9b 81 45 ad 45 b6 45 bb a5 26 d6 2c 40 2e 08 df
21.06.22 07:06 xone-gip packet 07 e1 45 a5 ab a3 12 7a f1 97 b5 e7 1f f3 b8 86
21.06.22 07:06 xone-gip packet 73 e9 40 a9 f8 2f 21 26 3a cf b7 02 17 00 20 0e
21.06.22 07:06 xone-gip gip0.0 gip_parse_chunk: offset=0x00b0, length=0x2a
21.06.22 07:06 xone-gip gip0.0 gip_parse_chunk: offset=0x00da, length=0x00
21.06.22 07:06 xone-gip gip0.0 gip_copy_chunk_data: buffer complete
21.06.22 07:06 xone-gip gip0.0 gip_parse_capabilities: parse out failed: -524
21.06.22 07:06 xone-gip gip0 gip_process_buffer: process packet failed: -524
21.06.22 07:06 xone-gip packet 04 a0 01 00 da 01
21.06.22 07:06 xone-wired 3-2 .0: xone_wired_complete_data_in: process failed: -524
Hello,
a generic xbox one s controller not recognized. I install genric xbox controller from garuda assistent, but it dosen`t help. Any Idea?
Thx
