inxi -Faz
Kernel: 5.14.2-zen1-2-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=74892e93-a6d5-4e5a-8b06-c475c079308b rw rootflags=subvol=@
quiet
cryptdevice=UUID=bbe3dd0f-a76f-449f-86ab-0965fa559da9:luks-bbe3dd0f-a76f-449f-86ab-0965fa559da9
root=/dev/mapper/luks-bbe3dd0f-a76f-449f-86ab-0965fa559da9 splash
resume=/dev/mapper/luks-609d6135-7f4e-4100-a438-7bb3fb179b4f
Desktop: GNOME 40.4 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
Type: Laptop System: LENOVO product: 20QD001XUS
v: ThinkPad X1 Carbon 7th serial: <filter> Chassis: type: 10
Mobo: LENOVO model: 20QD001XUS v: SDK0K17763 WIN serial: <filter>
UEFI: LENOVO v: N2HET64W (1.47 ) date: 07/19/2021
ID-1: BAT0 charge: 52.0 Wh (100.0%) condition: 52.0/51.0 Wh (101.9%)
volts: 17.0 min: 15.4 model: LGC 02DL004 type: Li-poly
serial: <filter> status: Discharging cycles: 406
Info: Quad Core model: Intel Core i7-8665U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142)
stepping: C (12) microcode: EA cache: L2: 8 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
bogomips: 33599
Speed: 800 MHz min/max: 400/800 MHz Core speeds (MHz): 1: 800 2: 800
3: 800 4: 800 5: 800 6: 800 7: 800 8: 800
Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: Lenovo
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3ea0
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-8:2 chip-ID: 04f2:b67c class-ID: 0e02 serial: <filter>
Display: wayland server: X.Org 1.21.1.2 compositor: gnome-shell
driver: loaded: intel unloaded: modesetting alternate: fbdev,vesa
Screen-1: 0 s-res: 3840x2160 s-dpi: 96
s-size: 1016x572mm (40.0x22.5") s-diag: 1166mm (45.9")
Monitor-1: XWAYLAND0 res: 3840x2160 hz: 60 dpi: 315
size: 310x170mm (12.2x6.7") diag: 354mm (13.9")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2)
v: 4.6 Mesa 21.2.1 direct render: Yes
Device-1: Intel Cannon Point-LP High Definition Audio vendor: Lenovo
driver: sof-audio-pci-intel-cnl
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:9dc8 class-ID: 0403
Sound Server-1: ALSA v: k5.14.2-zen1-2-zen running: yes
Sound Server-4: PipeWire v: 0.3.35 running: yes
Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi
v: kernel port: 2000 bus-ID: 00:14.3 chip-ID: 8086:9df0
Device-2: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e
v: kernel port: efa0 bus-ID: 00:1f.6 chip-ID: 8086:15bd
IF-ID-1: ztc3q7w5bl state: unknown speed: 10 Mbps duplex: full
mac: <filter>
IF-ID-2: ztukuqdqms state: unknown speed: 10 Mbps duplex: full
mac: <filter>
driver: btusb v: 0.8 bus-ID: 1-10:4 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 953.87 GiB used: 42.33 GiB (4.4%)
model: MZVLB1T0HBLR-000L7 size: 953.87 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 5M2QEXF7 temp: 38.9 C scheme: GPT
ID-1: / raw-size: 936.66 GiB size: 936.66 GiB (100.00%)
used: 42.33 GiB (4.5%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-bbe3dd0f-a76f-449f-86ab-0965fa559da9
used: 706 KiB (0.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 936.66 GiB size: 936.66 GiB (100.00%)
ID-4: /var/log raw-size: 936.66 GiB size: 936.66 GiB (100.00%)
ID-5: /var/tmp raw-size: 936.66 GiB size: 936.66 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.41 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: partition size: 16.95 GiB used: 0 KiB (0.0%)
mapped: luks-609d6135-7f4e-4100-a438-7bb3fb179b4f
System Temperatures: cpu: 46.0 C mobo: N/A
Fan Speeds (RPM): fan-1: 0
Processes: 293 Uptime: 32m wakeups: 5 Memory: 15.41 GiB
used: 3.72 GiB (24.1%) Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1619 lib: 360
Shell: fish v: 3.3.1 running-in: tmux: inxi: 3.3.06
Hi there!
I used the GDM Wayland option in Garuda Assistant to enable wayland, and it works, but only after logging out and logging back in.
On the first login (from boot), there are only two options for sessions when logging in with GDM, Gnome, and Gnome classic. Logging in brings me to an X11 session (I've checked with loginctl show-session number -p Type
), where all extensions have been disabled, including reverting the theme back to Gnome's white default.
After logging back out, GDM starts again and this time will have three options for choosing a session, Gnome, Gnome Classic, and Gnome on Xorg. Logging in with the Gnome option brings me to a Wayland session (checked with loginctl
again) where all of the extensions are properly enabled and everything works fine.
I've tried enabling KMS Early Start, which appeared to already be in /etc/mkinitcpio.conf
. I've also tried disabling gdm and launching a graphical session with the following, XDG_SESSION_TYPE=wayland dbus-run-session gnome-session
, which worked perfectly and took me directly to a wayland session, which leads me to believe its an issue with gdm.
Here is the output of my /etc/gdm/custom.conf
# GDM configuration storage
[daemon]
AutomaticLoginEnable=False
# Uncomment the line below to force the login screen to use Xorg
#WaylandEnable=false
DefaultSession=gnome-xorg.desktop
[security]
[xdmcp]
[chooser]
[debug]
# Uncomment the line below to turn on debugging
#Enable=true
Any help would be much appreciated, thank you!
