gcompris-qt
Icon theme "gnome" not found.
exeCount set to: 14
qml: enter main.qml (run #14, ratio=2.076923076923077, fontRatio=2.25, dpi=102, userDataPath=/home/lorenzo/.lo
cal/share/GCompris)
Downloading resource file "data2/voices-ogg/voices-it.rcc"
Downloading resource file "data2/words/words.rcc"
Download of QUrl("https://cdn.kde.org/gcompris/data2/words/words.rcc") is already running, skipping second att
empt.
notifyWordset: "data2/words/words.rcc"
Downloading resource file "data2/backgroundMusic/backgroundMusic-ogg.rcc"
Successfully registered resource "/home/lorenzo/.cache/KDE/gcompris-qt/data2/backgroundMusic/backgroundMusic-o
gg.rcc"
qrc:/gcompris/src/activities/menu/Menu.qml:94:5: QML Connections: Implicitly defined onFoo properties in Conne
ctions are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
qrc:/gcompris/src/core/Bar.qml:315:5: QML Connections: Implicitly defined onFoo properties in Connections are
qrc:/gcompris/src/core/Bar.qml:268:5: QML Connections: Implicitly defined onFoo properties in Connections are
qrc:/gcompris/src/activities/menu/Menu.qml:694:13: QML Connections: Implicitly defined onFoo properties in Con
nections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Found box2d in "/usr/lib/qt/qml"
qt.qpa.wayland: Wayland does not support QWindow::requestActivate()
Local resource is up-to-date: "voices-it.rcc"
Successfully registered resource "/home/lorenzo/.cache/KDE/gcompris-qt/data2/voices-ogg/voices-it.rcc"
Local resource is up-to-date: "words.rcc"
Successfully registered resource "/home/lorenzo/.cache/KDE/gcompris-qt/data2/words/words.rcc"
Local resource is up-to-date: "backgroundMusic-ogg.rcc"
qrc:/gcompris/src/core/Bonus.qml:75:5: QML Connections: Implicitly defined onFoo properties in Connections are
DownloadManager: shutting down, 0 active jobs
file:///usr/lib/qt/qml/QtQuick/Controls/Button.qml:100: TypeError: Cannot read property 'width' of null
If you include terminal outputs in your post please
use the proper output format in your post.
Using "~" 3 times above and "~" 3 times below the text block
will provide a readable, raw look.
gcompris-qt
exeCount set to: 14
cal/share/GCompris)
empt.
gg.rcc"
If you use the version in the Arch repo, I noticed it was updated today. Maybe you could try updating.
Anyway, looking in the upstream site there seems to be nothing important...
In that site there is a note for the Linux version, not clear to me if it is valid also for the Arch package or only for their standalone release.
Was this working in the recent past? I see you have kwin_wayland. Was it working on that before?
I have updated gcompris to version gcompris-qt 2.1 but I have the same problem.
It starts, but when I choose a game it stops to work. I can only press "esc" and gcompris quit
It worked fine until 2 day ago. I use kwin_wayland & wayland since more than a month.
I don't think there's anything we can do here about that. This is an upstream problem and I don't even think it's worth reporting it. Wayland in KDE is still a bit immature, although improving, so I don't think the developers are working on that side.
At least you have a way to use it...
I noticed that I have the problem only I use gcompris in full-screen mode. So, I choose game in not-full-screen mode and after I can play or in full-screen o not-full-screen. However It is a problem related to gcompris, KDE (my window manager) and wayland.
