I know from the dragonized edition that there is a system setttings program, but in the Xfce version its missing
If you are literally talking about the program called "System Settings", it is part of KDE/plasma so it will not be present in the XFCE edition.
Try running from terminal xfce4-settings-manager
. If that doesn't work, simply install it: sudo pacman -Syu xfce4-settings-manager
They are there, you aren't there yet, keep trying.
