I noticed this started after the very first update to kernel zen 6.2 and it also happens only when I run garuda-update and there is a kernel update included.
The issue is, during the update script is running, some of my custom settings act as reset. I mainly notice it in these two:
- I have the TAB key set to change between my keyboard input layouts - so TAB stops changing my input language
- I have "Invert scroll direction (Native scrolling) - scrolling now moves the opposite direction.
At this time, when I go to check my settings, they appear exaclty as I set them. If I change them to something else, hit Apply, change them back and hit Apply again, nothing happens. It is as these settings are not even considered by Garuda.
This gets fixed after a restart or log out/log in.
Kernel: 6.2.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=7897f042-86b4-4e2a-8147-96bee9e42435 rw [email protected]
psmouse.synaptics_intertouch=0 ibt=off
Desktop: KDE Plasma v: 5.27.2 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: LENOVO product: 20B7S1J00D v: ThinkPad T440
Mobo: LENOVO model: 20B7S1J00D v: 0B98401 PRO serial: <superuser required>
UEFI-[Legacy]: LENOVO v: GJET77WW (2.27 ) date: 05/20/2014
ID-1: BAT0 charge: 2.8 Wh (28.9%) condition: 9.7/23.2 Wh (41.9%) volts: 10.8
min: 11.1 model: SANYO 45N1773 type: Li-ion serial: <filter>
ID-2: BAT1 charge: 0.3 Wh (7.7%) condition: 3.9/23.2 Wh (16.8%)
volts: 11.6 min: 11.1 model: SANYO 45N1775 type: Li-ion serial: <filter>
status: not charging
Info: model: Intel Core i5-4300U bits: 64 type: MT MCP arch: Haswell
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1146 high: 1499 min/max: 800/2900 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1499 2: 799 3: 1255
4: 1032 bogomips: 19953
Device-1: Intel Haswell-ULT Integrated Graphics vendor: Lenovo driver: i915
v: kernel arch: Gen-7.5 process: Intel 22nm built: 2013 ports: active: eDP-1
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:0a16
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo
bus-ID: 2-8:3 chip-ID: 04f2:b39a class-ID: 0e02
Display: x11 server: X.Org v: 21.1.7 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,intel,vesa dri: crocus gpu: i915
Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.65x9.37")
s-diag: 485mm (19.11")
Monitor-1: eDP-1 model: LG Display 0x0435 built: 2013 res: 1600x900 hz: 60
dpi: 132 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: 1600x900
API: OpenGL v: 4.6 Mesa 22.3.6 renderer: Mesa Intel HD Graphics 4400 (HSW
GT2) direct-render: Yes
Device-1: Intel Haswell-ULT HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 00:03.0 chip-ID: 8086:0a0c class-ID: 0403
Device-2: Intel 8 Series HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9c20 class-ID: 0403
Sound API: ALSA v: k6.2.5-zen1-1-zen running: yes
Device-1: Intel Ethernet I218-LM vendor: Lenovo ThinkPad X240 driver: e1000e
v: kernel port: 3080 bus-ID: 00:19.0 chip-ID: 8086:155a class-ID: 0200
Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:08b2 class-ID: 0280
Local Storage: total: 223.57 GiB used: 103.75 GiB (46.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37240G
type: SSD serial: <filter> rev: J4.3 scheme: MBR
ID-1: / raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
used: 103.75 GiB (46.4%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
ID-3: /var/log raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
ID-4: /var/tmp raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.46 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 54.0 C mobo: N/A
Fan Speeds (RPM): fan-1: 3264
Processes: 213 Uptime: 8m wakeups: 1 Memory: 7.46 GiB used: 3.37 GiB (45.2%)
Init: systemd v: 253 default: graphical tool: systemctl Compilers:
gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman pkgs: 1647 libs: 419
tools: pamac Shell: fish v: 3.6.0 default: Zsh v: 5.9 running-in: yakuake
inxi: 3.3.25
Garuda (2.6.15-1):
System install date: 2021-01-01
Last full system update: 2023-03-12
Failed units: swapfile.swap
