Garuda-update issue: could not fully load metadata for package pipewire-v4l2-1:0.3.81-1
Hi, so I am having this particular issue when trying to update my Garuda Linux.
My system is pretty stable but I’m unable to update.
:: plasma5-themes-sweet-full-git and sweet-theme-full-git are in conflict. Remove sweet-theme-full-git? [y/N] y
:: plasma5-themes-sweet-kde-git and sweet-kde-theme-git are in conflict. Remove sweet-kde-theme-git? [y/N] y
:: nvidia-container-toolkit and nvidia-container-runtime are in conflict. Remove nvidia-container-runtime? [y/N] y
ywarning: could not fully load metadata for package pipewire-v4l2-1:0.3.81-1
error: failed to prepare transaction (invalid or corrupted package)
Here is my Garuda-inxi
[🔴] × garuda-inxi        (dna_repair_env)
LANGUAGE = "",
LC_ALL = (unset),
LC_ADDRESS = "en_US.UTF-8",
LC_NAME = "en_US.UTF-8",
LC_MONETARY = "nv_US.UTF-8",
LC_PAPER = "en_US.UTF-8",
LC_IDENTIFICATION = "en_US.UTF-8",
LC_TELEPHONE = "en_US.UTF-8",
LC_MEASUREMENT = "en_IN.UTF-8",
LC_TIME = "en_IN.UTF-8",
LC_COLLATE = "en_IN.UTF-8",
LC_NUMERIC = "en_IN.UTF-8",
LANG = "en_US.UTF-8"
perl: warning: Falling back to a fallback locale ("en_US.UTF-8").
Kernel: 6.6.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: hpet available: acpi_pm
root=UUID=911a506d-6ebb-4b32-aaab-cbb05f7df3ba rw rootflags=subvol=@
quiet rd.udev.log_priority=3 vt.global_cursor_default=0
systemd.unified_cgroup_hierarchy=1 loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
dm: SDDM Distro: Arch Linux
Type: Laptop System: ASUSTeK product: ROG Zephyrus G15 GA503QR_GA503QR
Mobo: ASUSTeK model: GA503QR v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: GA503QR.416 date: 08/11/2023
ID-1: BAT0 charge: 14.7 Wh (21.1%) condition: 69.6/90.0 Wh (77.3%)
power: 74.6 W volts: 15.9 min: 15.9 model: ASUSTeK ASUS Battery type: Li-ion
serial: N/A status: charging
Info: model: AMD Ryzen 9 5900HS with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 4 level: v3 note: check bum ilt: 2021-22
microcode: 0xA50000C
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 3371 high: 4417 min/max: 400/4680 scaling:
driver: amd-pstate-epp governor: performance cores: 1: 3533 2: 3541 3: 3532
4: 3637 5: 3538 6: 400 7: 4416 8: 4417 9: 3533 10: 3851 11: 3533 12: 400
13: 3534 14: 3854 15: 3805 16: 4412 bogomips: 105405
Device-1: NVIDIA GA104M [GeForce RTX 3070 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 535.113.01 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-09) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-23 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:249d class-ID: 0300
link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1 empty: HDMI-A-1
bus-ID: 06:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 67.0 C
compositor: kwin_x11 driver: X: loaded: amdgpu dri: radeonsi gpu: amdgpu
s-diag: 777mm (30.58")
Monitor-1: eDP-1 mapped: eDP model: ChiMei InnoLux 0x152a built: 2020
res: 2560x1440 hz: 165 dpi: 189 gamma: 1.2 size: 344x193mm (13.54x7.6")
diag: 394mm (15.5") ratio: 16:9 modes: max: 2560x1440 min: 640x480
drv: nvidia device: 1 drv: radeonsi device: 2 drv: swrast surfaceless:
drv: nvidia x11: drv: radeonsi inactive: gbm,wayland
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 23.2.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (renoir LLVM
16.0.6 DRM 3.54 6.6.10-zen1-1-zen) device-ID: 1002:1638 memory: 500 MiB
unified: no
API: Vulkan v: 1.3.264 layers: 14 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:1638 surfaces: N/A device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 3070 Laptop GPU driver: nvidia v: 535.113.01
device-ID: 10de:249d surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 23.1.7-arch1.1 (LLVM
speed: 16 GT/s bus-ID: 06:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: ASUSTeK
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh pcie:
gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
API: ALSA v: k6.6.10-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.81 status: active with: 1: pipewire-pulse
vendor: ASUSTeK driver: r8168 v: 8.051.02-NAPI modules: r8169 pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168
lanes: 1 bus-ID: 04:00.0 chip-ID: 14c3:7961 class-ID: 0280
IF: wlan0 state: up mac: <filter>
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:5 chip-ID: 13d3:3563
lmp-v: 11 status: discoverable: no pairing: no class-ID: 7c010c
Local Storage: total: 1 TiB used: 250.14 GiB (24.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFM001TD3JX013N
lanes: 4 tech: SSD serial: <filter> fw-rev: 41000C20 temp: 49.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: MK8046GSX
size: 74.53 GiB block-size: physical: 512 B logical: 512 B type: USB
ID-1: / raw-size: 297.66 GiB size: 297.66 GiB (100.00%)
used: 250.09 GiB (84.0%) fs: btrfs dev: /dev/nvme0n1p7 maj-min: 259:7
used: 42.4 MiB (16.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 297.66 GiB size: 297.66 GiB (100.00%)
ID-4: /var/log raw-size: 297.66 GiB size: 297.66 GiB (100.00%)
ID-5: /var/tmp raw-size: 297.66 GiB size: 297.66 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.03 GiB used: 4.4 GiB (29.3%)
System Temperatures: cpu: 75.2 C mobo: 48.0 C gpu: amdgpu temp: 63.0 C
Fan Speeds (rpm): cpu: 2500
Processes: 505 Uptime: 6h 54m wakeups: 9 Memory: total: 16 GiB note: est.
available: 15.03 GiB used: 10.19 GiB (67.8%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 alt: 11/12
clang: 16.0.6 Packages: 2329 pm: pacman pkgs: 2322 libs: 575
tools: gnome-software,pamac,paru pm: flatpak pkgs: 7 Shell: fish v: 3.6.1
default: Zsh v: 5.9 running-in: yakuake inxi: 3.3.30
Garuda (2.6.17-1):
System install date:     2023-10-11
Last full system update: 2023-09-18
Is partially upgraded:   Yes
Relevant software:       timeshift(custom) NetworkManager mkinitcpio nvidia-dkms
Failed units:            clamav-freshclam.service ndctl-monitor.service nmb.service smb.service systemd-networkd-wait-online.service
Other issues: Recently I was forced to chroot via terminal using an external boot image, and had to do sudo pacman -S linux-zen linux-zen-headers
Any advice would be greatly appreciated.
Solution:
sudo pacman -R pipewire-v4l2 pipewire-support
sudo pacman -S pipewire-v4l2 pipewire-support
Cheers
