Garuda-update conflict between python-vdf-solstice and python-vdf
I’m running into an issue with garuda update, i just did an update one or two days ago without issues and today i get this conflict between python-vdf-solstice and python-vdf, before accepting the sugestion to remove python-vdf i decided to check the origin of the packages however according to pacman only python-vdf exists:
╭─na-tt@katana in ~ as 🧙 took 39ms
╰─λ pacman -Qs python-vdf
local/python-vdf 3.4-3
Library for working with Valve's VDF text format
╭─na-tt@katana in ~ as 🧙 took 26ms
╰─λ pacman -Qi python-vdf
Version         : 3.4-3
Description     : Library for working with Valve's VDF text format
Architecture    : any
URL             : https://github.com/ValvePython/vdf
Licenses        : MIT
Groups          : None
Provides        : None
Depends On      : python>=3.3
Optional Deps   : None
Required By     : protontricks-git
Optional For    : None
Conflicts With  : None
Replaces        : None
Installed Size  : 100.50 KiB
Packager        : UFSCar HPC Builder <[email protected]>
Build Date      : Wed 01 May 2024 04:15:33 PM -04
Install Date    : Tue 07 May 2024 12:55:04 PM -04
Install Reason  : Installed as a dependency for another package
Install Script  : No
Validated By    : SHA-256 Sum  Signature
╭─na-tt@katana in ~ as 🧙 took 28ms
╰─λ pacman -Qi python-vdf-solstice
error: package 'python-vdf-solstice' was not found
garuda-update:
╭─na-tt@katana in ~ took 2s
╰─λ garuda-update
[sudo] password for na-tt:
╭─na-tt@katana in ~ as 🧙 took 1ms
╰─λ garuda-update
garuda is up to date
core is up to date
extra is up to date
multilib is up to date
chaotic-aur is up to date
--> Refreshing mirrorlists using rate-mirrors, please be patient..🍵R
garuda downloading...
core downloading...
extra downloading...
multilib downloading...
chaotic-aur downloading...
spawn pacman -Su
warning: reshade-shaders-git: local (r879.a2314cb-1) is newer than chaotic-aur (r80.eed46c2-1)
resolving dependencies...
:: python-vdf-solstice-3.5-1 and python-vdf-3.4-3 are in conflict. Remove python-vdf? [y/N] N
n
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
(The warning about reshade-shader-git has existed since a long while so i don’t think it has to do with this, advice on this is appreciated too)
garuda-inxi:
  Kernel: 6.10.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1 clocksource: tsc
    root=UUID=1ff06791-3783-4094-b0dd-898c4b519967 rw rootflags=subvol=@ quiet quiet
    resume=UUID=f1f58c16-f4e6-4587-b7db-88c32ef6457f loglevel=3 ibt=off
  Desktop: KDE Plasma v: 6.1.3 tk: Qt v: N/A info: frameworks v: 6.4.0 wm: kwin_wayland vt: 1
  Type: Laptop System: Micro-Star product: Katana GF66 11SC v: REV:1.0 serial: <superuser required>
    Chassis: type: 10 serial: <superuser required>
  Mobo: Micro-Star model: MS-1582 v: REV:1.0 serial: <superuser required> part-nu: 1582.3
    uuid: <superuser required> UEFI: American Megatrends LLC. v: E1582IMS.30A date: 07/22/2021
  ID-1: BAT1 charge: 37.0 Wh (93.7%) condition: 39.5/52.0 Wh (75.9%) volts: 12.2 min: 11.4
    model: MSI BIF0_9 type: Li-ion serial: N/A status: not charging
  Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: <filter>
  Info: model: 11th Gen Intel Core i5-11400H bits: 64 type: MT MCP arch: Tiger Lake gen: core 11
    level: v4 note: check built: 2020 process: Intel 10nm family: 6 model-id: 0x8D (141) stepping: 1
    microcode: 0x50
  Topology: cpus: 1x cores: 6 tpc: 2 threads: 12 smt: enabled cache: L1: 480 KiB
    desc: d-6x48 KiB; i-6x32 KiB L2: 7.5 MiB desc: 6x1.2 MiB L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 1650 high: 4188 min/max: 800/4500 scaling: driver: intel_pstate
    governor: performance cores: 1: 800 2: 801 3: 2470 4: 2216 5: 797 6: 800 7: 871 8: 800 9: 2866
    10: 1936 11: 1256 12: 4188 bogomips: 64512
  Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Micro-Star MSI driver: i915 v: kernel
    alternate: xe arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports: active: HDMI-A-1,eDP-1
    empty: none bus-ID: 00:02.0 chip-ID: 8086:9a68 class-ID: 0300
  Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Micro-Star MSI driver: nvidia
    v: 555.58.02 alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current (as of 2024-06;
    EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-2022 pcie: gen: 1
    speed: 2.5 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0
    chip-ID: 10de:1f9d class-ID: 0302
  Device-3: Bison HD Webcam driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
    mode: 2.0 bus-ID: 3-10:3 chip-ID: 5986:211b class-ID: 0e02
  Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.1 compositor: kwin_wayland
    driver: X: loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,intel,nv,vesa dri: iris
    gpu: i915,nvidia d-rect: 3286x1848 display-ID: 0
  Monitor-1: HDMI-A-1 pos: bottom-l res: 1366x768 size: N/A modes: N/A
  Monitor-2: eDP-1 pos: top-right res: 1920x1080 size: N/A modes: N/A
  API: EGL v: 1.5 hw: drv: intel iris drv: nvidia platforms: device: 0 drv: nvidia device: 1
    drv: iris device: 3 drv: swrast surfaceless: drv: nvidia wayland: drv: iris x11: drv: iris
    inactive: gbm,device-2
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.1.4-arch1.2 glx-v: 1.4
    direct-render: yes renderer: Mesa Intel UHD Graphics (TGL GT1) device-ID: 8086:9a68
    memory: 3.64 GiB unified: yes display-ID: :1.0
  API: Vulkan v: 1.3.279 layers: 10 device: 0 type: integrated-gpu name: Intel UHD Graphics (TGL
    GT1) driver: mesa intel v: 24.1.4-arch1.2 device-ID: 8086:9a68 surfaces: xcb,xlib,wayland
    device: 1 type: discrete-gpu name: NVIDIA GeForce GTX 1650 driver: nvidia v: 555.58.02
    device-ID: 10de:1f9d surfaces: xcb,xlib,wayland device: 2 type: cpu name: llvmpipe (LLVM
    18.1.8 256 bits) driver: mesa llvmpipe v: 24.1.4-arch1.2 (LLVM 18.1.8) device-ID: 10005:0000
  Device-1: Intel
 Tiger Lake-H HD Audio vendor: Micro-Star MSI driver: sof-audio-pci-intel-tgl
    alternate: snd_hda_intel, snd_soc_avs, snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:43c8
    class-ID: 0401
  API: ALSA v: k6.10.2-zen1-1-zen status: kernel-api with: aoss type: oss-emulator tools: N/A
  Server-1: PipeWire v: 1.2.1 status: active with: 1: pipewire-pulse status: active
  Device-1: Intel Tiger Lake PCH CNVi WiFi driver: iwlwifi v: kernel bus-ID: 00:14.3
    chip-ID: 8086:43f0 class-ID: 0280
  Device-2: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI
    driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0
    mode: 1.1 bus-ID: 3-14:4 chip-ID: 8087:0026 class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 0 state: down bt-service: enabled,running rfk-block:
    hardware: no software: no address: <filter> bt-v: 5.2 lmp-v: 11 status: discoverable: no
    pairing: no
  Local Storage: total: 476.94 GiB used: 277.82 GiB (58.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: OM8PCP3512F-AI1 size: 476.94 GiB
    fw-rev: ECFK52.8 temp: 30.9 C scheme: GPT
  ID-1: / raw-size: 467.84 GiB size: 467.84 GiB (100.00%) used: 277.82 GiB (59.4%) fs: btrfs
  ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 584 KiB (0.2%) fs: vfat
  ID-3: /home raw-size: 467.84 GiB size: 467.84 GiB (100.00%) used: 277.82 GiB (59.4%) fs: btrfs
  ID-4: /var/log raw-size: 467.84 GiB size: 467.84 GiB (100.00%) used: 277.82 GiB (59.4%)
  ID-5: /var/tmp raw-size: 467.84 GiB size: 467.84 GiB (100.00%) used: 277.82 GiB (59.4%)
  ID-1: swap-1 type: zram size: 7.46 GiB used: 1.13 GiB (15.2%) priority: 100 comp: zstd
    avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 12 dev: /dev/zram0
  ID-2: swap-2 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p3
    maj-min: 259:3
  System Temperatures: cpu: 46.0 C mobo: N/A
  Memory: total: 8 GiB note: est. available: 7.46 GiB used: 3.68 GiB (49.3%)
  Processes: 331 Power: uptime: 3h 44m states: freeze,mem,disk suspend: deep avail: s2idle
    wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 2.95 GiB
    services: org_kde_powerdevil,upowerd Init: systemd v: 256 default: graphical tool: systemctl
  Packages: 2512 pm: pacman pkgs: 2490 libs: 604 tools: paru pm: flatpak pkgs: 22 Compilers:
    clang: 18.1.8 gcc: 14.1.1 Client: shell wrapper v: 5.2.26-release inxi: 3.3.35
  System install date:     2022-08-03
  Last full system update: 2024-08-02
  Failed units:            N
Thanks in advance for any assistance
Try y(es)
pacman -Ss python-vdf-solstice
chaotic-aur/python-vdf-solstice 3.5-1
    Library for working with Valve's VDF text format (Solstice Game Studios fork)
The update went without problems and after a reboot everything is fine. After running pacman -Qi python-vdf-solstice it shows its required by protontricks-git so i guess they migrated from regular vdf to the solstice fork.
Thank you very much
