Hey all,
Running garuda-update is leaving me unable to get back to my desktop.
garuda-update
is able to complete running...
However, upon reboot I'm experiencing the following:
1.) Lots of numbers and output during boot up which were not there before
2.) Login screen appears
3.) I can login and see desktop background, but nothing else will happen
4.) Trying ctrl+alt+f1-f9 can allow access to alternate terminal and login. However, I can never reach command prompt or run any commands. Some btrfb msg appears related to disk at that time.
...After that I rely on snapshot backup to roll back before the upgrade.
So, anything else I can do to achieve a successful update?
Is there some better way for me to capture useful output in the broken state (post update) to share here?
output (before running garuda-update
garuda-inxi | tee output.txt
Kernel: 6.1.6-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=6d358332-1121-46d2-a2c5-bd235a269b18 rw [email protected]
resume=UUID=c06ef7ff-534a-46d8-a0e0-a3052b377e5f loglevel=3 ibt=off
Type: Laptop System: LENOVO product: 20X7005AUS v: ThinkPad L15 Gen 2a
Mobo: LENOVO model: 20X7005AUS serial: <superuser required> UEFI: LENOVO
v: R1KET36W (1.21 ) date: 11/25/2021
ID-1: BAT0 charge: 29.4 Wh (70.2%) condition: 41.9/45.7 Wh (91.6%)
volts: 11.4 min: 11.1 model: SMP LNV-5B10W13896 type: Li-poly
serial: <filter> status: discharging cycles: 214
Info: model: AMD Ryzen 7 PRO 5850U with Radeon Graphics bits: 64
type: MT MCP arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
microcode: 0xA50000C
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1868 high: 1900 min/max: 1600/4505 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 1900 2: 1900
3: 1900 4: 1900 5: 1900 6: 1900 7: 1900 8: 1900 9: 1900 10: 1900 11: 1900
12: 1900 13: 1397 14: 1900 15: 1900 16: 1900 bogomips: 60683
vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5.1 code: Vega-2
process: TSMC n7 (7nm) built: 2018-21 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 07:00.0 chip-ID: 1002:1638
class-ID: 0300 temp: 46.0 C
Device-2: Acer Integrated Camera type: USB driver: uvcvideo bus-ID: 1-2:2
chip-ID: 5986:212b class-ID: 0e02
Monitor-1: eDP-1 mapped: eDP model: AU Optronics 0x2e8d built: 2019
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
API: OpenGL v: 4.6 Mesa 22.3.3 renderer: AMD Radeon Graphics (renoir LLVM
15.0.7 DRM 3.49 6.1.6-zen1-2-zen) direct render: Yes
link-max: gen: 4 speed: 16 GT/s bus-ID: 07:00.1 chip-ID: 1002:1637
snd_sof_amd_rembrandt pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max:
gen: 4 speed: 16 GT/s bus-ID: 07:00.5 chip-ID: 1022:15e2 class-ID: 0480
speed: 16 GT/s bus-ID: 07:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound API: ALSA v: k6.1.6-zen1-2-zen running: yes
port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp2s0f0 state: down mac: <filter>
Device-2: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw89_8852ae v: kernel modules: rtw_8852ae pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 03:00.0
chip-ID: 10ec:8852 class-ID: 0280
bus-ID: 5-4:2 chip-ID: 0bda:4852 class-ID: e001 serial: <filter>
Local Storage: total: 476.94 GiB used: 237.59 GiB (49.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFS512GDE9X081N
lanes: 4 type: SSD serial: <filter> rev: 41730C20 temp: 42.9 C scheme: GPT
ID-1: / raw-size: 97.66 GiB size: 97.66 GiB (100.00%)
used: 45.14 GiB (46.2%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p3
maj-min: 259:3
ID-2: /boot/efi raw-size: 1000 MiB size: 998 MiB (99.80%)
used: 596 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 358.77 GiB size: 358.77 GiB (100.00%)
used: 192.45 GiB (53.6%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p4
maj-min: 259:4
ID-4: /var/log raw-size: 97.66 GiB size: 97.66 GiB (100.00%)
maj-min: 259:3
ID-5: /var/tmp raw-size: 97.66 GiB size: 97.66 GiB (100.00%)
maj-min: 259:3
ID-1: swap-1 type: partition size: 19.53 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 14.46 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 58.0 C mobo: N/A gpu: amdgpu temp: 47.0 C
Fan Speeds (RPM): fan-1: 3174
Processes: 435 Uptime: 1m wakeups: 2 Memory: 14.46 GiB
used: 5.76 GiB (39.8%) Init: systemd v: 252 default: graphical
pkgs: 2142 libs: 577 tools: gnome-software,octopi,pamac,paru Shell: fish
v: 3.6.0 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.24
Garuda (2.6.14-1):
System install date: 2022-04-06
Last full system update: 2023-01-18
