Garuda sytem update issue
Hey Folks,
I was on holidays 2 weeks and i get now this error when i try to update :
:: installing libdisplay-info (0.2.0-1) breaks dependency 'libdisplay-info.so=1-64' required by gamescope-amd-color
So I try this command :
sudo pacman -Syu --ignore=libdisplay-info
The system update well but after i am unable to boot into Wayland, only X11 is working, so i restore the system with the snapshot before the update.
Also When i open the terminal i have this error on top of the window :
Error: failed to parse JSON config file `/usr/share/fastfetch/presets/dr460nized` at (1, 2): no digit after minus sign
Do you have an idea how i can solve theses issues?
Kernel: 6.9.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=47a5e59d-c1a3-40b9-a0bb-bb47e82afe67 rw rootflags=subvol=@
quiet resume=UUID=0cb10512-f2ea-4a95-a5bc-d5d067138f92 loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.3.0
Mobo: ASUSTeK model: TUF GAMING X670E-PLUS WIFI v: Rev 1.xx
UEFI: American Megatrends v: 1636 date: 07/28/2023
Info: model: AMD Ryzen 7 7800X3D bits: 64 type: MT MCP arch: Zen 4 gen: 5
L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 1897 high: 4397 min/max: 400/5050 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 4397 2: 400 3: 400
4: 400 5: 400 6: 4396 7: 400 8: 4392 9: 4394 10: 4391 11: 400 12: 4387
13: 400 14: 400 15: 400 16: 400 bogomips: 134411
Device-1: AMD Navi 21 [Radeon RX 6950 XT] vendor: Sapphire driver: amdgpu
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1 empty: DP-1,
DP-2, DP-3, Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:73a5 class-ID: 0300
gpu: amdgpu display-ID: 0
Monitor-1: HDMI-A-1 res: 3072x1728 size: N/A modes: N/A
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.1-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6950 XT (radeonsi
navi21 LLVM 17.0.6 DRM 3.57 6.9.3-zen1-1-zen) device-ID: 1002:73a5
API: Vulkan v: 1.3.279 layers: 11 device: 0 type: discrete-gpu name: AMD
Radeon RX 6950 XT (RADV NAVI21) driver: mesa radv v: 24.1.1-arch1.1
device-ID: 1002:73a5 surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.1.1-arch1.1 (LLVM 17.0.6) device-ID: 10005:0000
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
Device-2: AMD Family 17h/19h HD Audio vendor: ASUSTeK
bus-ID: 13:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-3: Native Instruments Komplete Audio 6 driver: snd-usb-audio
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2
chip-ID: 17cc:1001 class-ID: fe01 serial: <filter>
API: ALSA v: k6.9.3-zen1-1-zen status: kernel-api with: aoss
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 0b:00.0
lanes: 1 bus-ID: 0c:00.0 chip-ID: 14c3:0616 class-ID: 0280
IF: wlp12s0 state: down mac: <filter>
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:2 chip-ID: 0489:e0e2
Local Storage: total: 8.64 TiB used: 4.14 TiB (47.9%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Western Digital
model: WD BLACK SN850X 2000GB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 620331WD temp: 36.9 C scheme: GPT
fw-rev: 620331WD temp: 39.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 1TB
ID-4: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 QVO 2TB
ID-5: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD20EFRX-68EUZN0 size: 1.82 TiB block-size: physical: 4096 B
fw-rev: 0A82 scheme: GPT
ID-6: /dev/sdd maj-min: 8:48 vendor: Samsung model: SSD 850 EVO 500GB
ID-1: / raw-size: 1.79 TiB size: 1.79 TiB (100.00%) used: 945.9 GiB (51.7%)
fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:5
used: 612 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:4
used: 945.9 GiB (51.7%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:5
maj-min: 259:5
maj-min: 259:5
ID-1: swap-1 type: zram size: 31.08 GiB used: 52.5 MiB (0.2%)
ID-2: swap-2 type: partition size: 34.18 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:6
System Temperatures: cpu: 47.5 C mobo: 38.0 C gpu: amdgpu temp: 45.0 C
mem: 44.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 1111
Memory: total: 32 GiB note: est. available: 31.08 GiB used: 4 GiB (12.9%)
Processes: 359 Power: uptime: 1h 18m states: freeze,mem,disk suspend: deep
Packages: pm: pacman pkgs: 1931 libs: 518 tools: octopi,pamac,paru,trizen
pm: appimage pkgs: 0 Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: garuda-inxi
default: fish v: 3.7.1 running-in: konsole inxi: 3.3.34
System install date:     2024-05-20
Last full system update: 2024-06-10
Remove that package. It doesn’t even exist anymore in the AUR.
https://wiki.archlinux.org/title/Gamescope#Linux_kernel_with_experimental_AMD_color_management_enabled
Then you’ll be able to update.
This has been fixed. As soon as your system is up to date, it should work again without this message.
Thank you very much @filo, you solve the issue.
My system is updated <3
Hi @nepti, Thank you very much for your message.
Unfortunately i still get this message. My system is up to date.
This issue don’t give the the logo and the system settings information in the terminal window. I hope it’ll be fixed after future updates to get things clean as it should.
I open the file in Kate and it looks like that :
--kitty /usr/share/icons/garuda/dr460nized-fastfetch.png
--logo-width 36
--structure Title:Separator:OS:Host:Kernel:Uptime:Battery:Break:Packages:Shell:Resolution:Terminal:Break:CPU:GPU:Memory:Break:Colors
--host-format "{/2}{-}{/}{2}{?3} {3}{?}"
--battery-format "{/4}{-}{/}{4}%{?5} [{5}]{?}"
--gpu-key "GPU"
Check if you have installed fastfetch from the extra repo (select replace when asked):
sudo pacman -S fastfetch
Please open a dedicated topic if the issue persists. We need to keep the forum tidy for future “searchers”.
thanks @nepti, i updated but it change nothing. The message is still there
ok @filo, i’ll open a new topic with this issue
