I have some other issue too. Before i updated i clicked on Auto-start Application in App settings and it was hooked it wont start after a reboot thats what i already figured out on a other Topic where some asking how to activate it. Seems like to reversed. But now with this Version it didnt work anymore. So onlu option is to delete it out of the System-Settings from autostart ![]()
Uhm…
Maybe another request feature, If of course it gives sense or its not already there somewhere.
Would it be possible to have in RANI a refresh button that will check what packages are avaiable?
I know RANI is doing that each start. But would there be a possibility to execute it manually while RANI is open?
Something like this next to the bell
It seems like I forgot reimplementing that functionality
 I mean, the switch is there and all that, but after porting it to electron I didn’t add back the logic for responding to toggling it. Absolutely my bad, I’ll be adding it back very soon.
I wonder what a use case would be, given the app refreshes whenever a relevant thing was executed. But yes, that’s one of the easiest things do. I’d call a full refresh however (there is more state other than packages only).
Nice mock-up!!! ![]()
 you know my primary goal was to make you laugh!
But the use-case, … in the light I make a fool of myself…sometimes when you know the drivers are out and you want to click that refresh button to see them already replicated in the repos xD and hit the upgrade button so you can install them.
a short update ![]()
i have the newest Version now. The right click is working on my side now. Autostart isnt working but already answered to it. The Garuda Icon didnt comes back after the new update. I did delete it from the Panel and added it again it works now.
Great work anyway appreciate it ![]()
Took me a while to get back at it due to various real life events, but here we are ![]()
- Autostart
 fix(renderer): bring back reaction to auto-start toggle, handle it properly... (424d834d) · Commits · Garuda Linux 🦅 / Applications / Reliable Assistant for Native Installations · GitLab - Refresh button
  feat(renderer): add refresh button to system status (a2c3f4af) · Commits · Garuda Linux 🦅 / Applications / Reliable Assistant for Native Installations · GitLab - Save/restore window state
  feat: save and restore window state (44dc0653) · Commits · Garuda Linux 🦅 / Applications / Reliable Assistant for Native Installations · GitLab
Also, @Arcus brought descriptions to all Gamer packages in feat(added-tootips-to-games-section): Wrote a small script to pull package... (5dfda99d) · Commits · Garuda Linux 🦅 / Applications / Reliable Assistant for Native Installations · GitLab, and system status should (in theory) no longer print fastfetch output and calculate update count based on it fix(renderer): do not source bashrc or profile when calling bash (b10518b0) · Commits · Garuda Linux 🦅 / Applications / Reliable Assistant for Native Installations · GitLab ![]()
There are also ongoing efforts to migrate our Angular library to Angular 20 and outsource our themes to it in Theme Library by FilipTLW · Pull Request #97 · garuda-linux/garuda-ng · GitHub. Started work with @Vo1dSh4d0w last week, hopefully to resume this weekend ![]()
I have installed the same kernel twice → really → no → but Rani shows it to me ![]()
(installed is garuda-rani-git Vers. 3.1.5.r0.ge5fbf92-1)
start log:
╰─λ garuda-rani
(electron:148170): LIBDBUSMENU-GLIB-WARNING **: 11:47:24.655: About to Show called on an item wihtout submenus.  We're ignoring it.
(electron:148170): LIBDBUSMENU-GLIB-WARNING **: 11:47:24.660: About to Show called on an item wihtout submenus.  We're ignoring it.
INFO [11:47:24.497]: Renderer - Loaded 7 settings from store
INFO [11:47:24.868]: Renderer - Last update: 2025-08-14T08:57:57.000Z
INFO [11:47:25.481]: Renderer - No aur updates available
INFO [11:47:25.651]: Renderer - No updates available
ERROR [11:47:30.444]: Renderer - Failed to get available DKMS modules:
ERROR [11:47:30.444]: Renderer - Failed to get kernel DKMS status:
INFO [11:47:30.670]: Renderer - Found 32 available kernels
[148216:0814/114743.459029:ERROR:ui/gl/gl_surface_presentation_helper.cc:260] GetVSyncParametersIfAvailable() failed for 1 times!
[148216:0814/114743.472322:ERROR:ui/gl/gl_surface_presentation_helper.cc:260] GetVSyncParametersIfAvailable() failed for 2 times!
[148216:0814/115039.108611:ERROR:ui/gl/gl_surface_presentation_helper.cc:260] GetVSyncParametersIfAvailable() failed for 3 times!
            looks like two different version of the same kernel? ![]()
installed also on Garuda Mokka current non git version → the same →
Edit reason:
The first is the patched version (btrfs issue) from the kernel and the other is the default.
Both are in the source, that’s why Rani show me this.
 ← ..  look carefully before, sorry
Your assessment is correct.
It’s back to normal, now that the patched versions have been dropped, right?
Should probably filter and only show the relevant version (the one pacman installs).
Edit: fixed
[3.3.0] - 2025-10-03
 Features
- (i18n) Bring pt-BR support
 - (i18n) Support uk, translation by devil6a
 Bug Fixes
- (renderer) Parse and check /etc/shells for valid shells / paths
 - (i18n) Typo
 - (main) ModuleRunner not being awaited, strip unnecessary things
 Performance
- Lazy-load components, spawn window first and show a static splash screen until Angular is ready
 Miscellaneous Tasks
- Drop obsolete packages from lists
There is any issue here. I cant reboot over the Icon its just spinning the wheel. I will test it after a reboot again but my system is up to date. Boot tool is not starting after typing password in it and click ok. no sign in the terminal that i triggered it.
ps forgot lol boot-tool cant go because i use grub-customizer . ( just idea to let check rani if its installed and ask for it seperatly. not to install if like me someone use other grub tools. Just beginner friendly thinkings like those merge pacdiff files)
garuda-rani
(electron:51780): LIBDBUSMENU-GLIB-WARNING **: 23:39:41.715: About to Show called on an item wihtout submenus.  We're ignoring it.
(electron:51780): LIBDBUSMENU-GLIB-WARNING **: 23:39:41.723: About to Show called on an item wihtout submenus.  We're ignoring it.
INFO [23:39:42.173]: Renderer - Loaded 1 settings from store
INFO [23:39:42.569]: Renderer - Last update: 2025-10-05T22:38:45.000Z
INFO [23:39:44.541]: Renderer - No updates available
INFO [23:39:54.258]: Renderer - Last update: 2025-10-05T22:38:45.000Z
INFO [23:39:55.109]: Renderer - Last update: 2025-10-05T22:38:45.000Z
INFO [23:39:55.159]: Renderer - No updates available
INFO [23:39:55.783]: Renderer - Last update: 2025-10-05T22:38:45.000Z
INFO [23:39:55.956]: Renderer - No updates available
INFO [23:39:56.738]: Renderer - No updates available
INFO [23:41:00.007]: Renderer - No aur updates available
INFO [23:41:14.010]: Renderer - No aur updates available
[51816:1005/234241.950065:ERROR:ui/gl/gl_surface_presentation_helper.cc:260] GetVSyncParametersIfAvailable() failed for 1 times!
INFO [23:42:41.941]: Renderer - Last update: 2025-10-05T22:38:45.000Z
INFO [23:42:43.490]: Renderer - No updates available
INFO [23:42:44.376]: Renderer - No aur updates available
[51816:1005/234248.416098:ERROR:ui/gl/gl_surface_presentation_helper.cc:260] GetVSyncParametersIfAvailable() failed for 2 times!
[51816:1005/234248.417566:ERROR:ui/gl/gl_surface_presentation_helper.cc:260] GetVSyncParametersIfAvailable() failed for 3 times!
INFO [23:42:48.408]: Renderer - Last update: 2025-10-05T22:38:45.000Z
INFO [23:42:49.192]: Renderer - No updates available
INFO [23:42:50.834]: Renderer - No aur updates available
after reboot
(electron:4542): LIBDBUSMENU-GLIB-WARNING **: 00:02:31.122: About to Show called on an item wihtout submenus.  We're ignoring it.
(electron:4542): LIBDBUSMENU-GLIB-WARNING **: 00:02:31.130: About to Show called on an item wihtout submenus.  We're ignoring it.
INFO [00:02:31.577]: Renderer - Loaded 1 settings from store
INFO [00:02:31.967]: Renderer - Last update: 2025-10-05T22:48:48.000Z
INFO [00:02:32.446]: Renderer - No aur updates available
INFO [00:02:35.106]: Renderer - No updates available
[4576:1006/000241.999595:ERROR:ui/gl/gl_surface_presentation_helper.cc:260] GetVSyncParametersIfAvailable() failed for 1 times!
[4576:1006/000242.000948:ERROR:ui/gl/gl_surface_presentation_helper.cc:260] GetVSyncParametersIfAvailable() failed for 2 times!
INFO [00:02:41.972]: Renderer - Task Install garuda-boot-options has finished
INFO [00:02:41.995]: Renderer - Last update: 2025-10-05T23:02:41.000Z
INFO [00:02:43.746]: Renderer - No updates available
[4576:1006/000247.885204:ERROR:ui/gl/gl_surface_presentation_helper.cc:260] GetVSyncParametersIfAvailable() failed for 3 times!
INFO [00:03:12.589]: Renderer - Task Install garuda-boot-options has finished
INFO [00:03:12.612]: Renderer - Last update: 2025-10-05T23:03:12.000Z
INFO [00:03:13.997]: Renderer - No updates available
Task Install garuda-boot-options has finished   (nope but yeah didnt want it )
somehow wayland crashed with blackscreen and reload. If its maybe another kernel issue . lol no good luck since 6.16 series . but now its 6.17 mainline as info. journalctl is to long to mark it all ocne many coredup red llllooooll
Interesting, I will try to reproduce it. Thanks for the report and logs!
