For some reason Gaurda isn’t detecting my Rodecaster Pro II. Does anyone know how I could restart my audio to see if it picks it up?
Kernel: 6.14.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=f51aac4d-3013-4111-971c-ef3031e7c31b rw rootflags=subvol=@
loglevel=3 quiet ibt=off
Type: Desktop Mobo: Micro-Star model: MAG X870E TOMAHAWK WIFI (MS-7E59)
v: 2.0 serial: <superuser required> uuid: <superuser required> UEFI: American
Megatrends LLC. v: 2.A60 date: 04/22/2025
Info: model: AMD Ryzen 9 9950X3D bits: 64 type: MT MCP arch: N/A level: v4
note: check family: 0x1A (26) model-id: 0x44 (68) stepping: 0
microcode: 0xB404032
Topology: cpus: 1x dies: 2 clusters: 2x1 cores: 16 threads: 32 tpc: 2
smt: enabled cache: L1: 1.2 MiB desc: d-16x48 KiB; i-16x32 KiB L2: 16 MiB
desc: 16x1024 KiB L3: 128 MiB desc: 1x32 MiB, 1x96 MiB
Speed (MHz): avg: 2982 min/max: 600/5756 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 2982 2: 2982 3: 2982
4: 2982 5: 2982 6: 2982 7: 2982 8: 2982 9: 2982 10: 2982 11: 2982 12: 2982
13: 2982 14: 2982 15: 2982 16: 2982 17: 2982 18: 2982 19: 2982 20: 2982
21: 2982 22: 2982 23: 2982 24: 2982 25: 2982 26: 2982 27: 2982 28: 2982
29: 2982 30: 2982 31: 2982 32: 2982 bogomips: 275199
Device-1: NVIDIA GB202 [GeForce RTX 5090] vendor: Gigabyte driver: nvidia
v: 570.153.02 alternate: nouveau,nvidia_drm non-free: 550-570.xx+
status: current (as of 2025-04) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 5 speed: 32 GT/s lanes: 16
ports: active: none off: DP-1,HDMI-A-1 empty: DP-2,DP-3 bus-ID: 01:00.0
chip-ID: 10de:2b85 class-ID: 0300
vendor: Micro-Star MSI driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: none empty: DP-4, DP-5, DP-6, HDMI-A-2,
Writeback-1 bus-ID: 79:00.0 chip-ID: 1002:13c0 class-ID: 0300 temp: 37.0 C
Device-3: Razer USA Gaming Webcam [Kiyo] driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2
chip-ID: 1532:0e03 class-ID: 0102
gpu: nvidia,nvidia-nvswitch d-rect: 5360x2520 display-ID: 0
Monitor-1: DP-1 pos: bottom-l model: Dell AW3423DWF serial: <filter>
built: 2023 res: mode: 3440x1440 hz: 165 scale: 125% (1.25) to: 2752x1152
dpi: 109 gamma: 1.2 size: 800x337mm (31.5x13.27") diag: 868mm (34.2")
modes: max: 3440x1440 min: 640x480
Monitor-2: HDMI-A-1 pos: top-right model: BenQ GW2490E serial: <filter>
built: 2024 res: mode: 1920x1080 hz: 100 scale: 100% (1) dpi: 93 gamma: 1.2
max: 1920x1080 min: 640x480
drv: nvidia device: 1 drv: radeonsi device: 3 drv: swrast gbm: drv: radeonsi
inactive: device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 570.153.02
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 5090/PCIe/SSE2
memory: 31.1 GiB display-ID: :1.0
API: Vulkan v: 1.4.313 layers: 10 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 5090 driver: nvidia v: 570.153.02
device-ID: 10de:2b85 surfaces: N/A device: 1 type: integrated-gpu name: AMD
v: 25.1.1-arch1.2 device-ID: 1002:13c0 surfaces: N/A device: 2 type: cpu
name: llvmpipe (LLVM 19.1.7 256 bits) driver: mesa llvmpipe
v: 25.1.1-arch1.2 (LLVM 19.1.7) device-ID: 10005:0000 surfaces: N/A
de: kscreen-console,kscreen-doctor gpu: nvidia-smi wl: wayland-info
Device-1: NVIDIA driver: snd_hda_intel v: kernel pcie: gen: 5 speed: 32 GT/s
lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:22e8 class-ID: 0403
Definition Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 79:00.1 chip-ID: 1002:1640
speed: 16 GT/s lanes: 16 bus-ID: 79:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: Micro Star USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-12:3
chip-ID: 0db0:cd0e class-ID: 0300
Device-5: Razer USA Gaming Webcam [Kiyo] driver: snd-usb-audio,uvcvideo
Device-6: SteelSeries ApS Arctis Pro Wireless
lanes: 1 mode: 1.1 bus-ID: 3-5.3:11 chip-ID: 1038:1297 class-ID: 0300
API: ALSA v: k6.14.9-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.4.4 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL8126 5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 1 port: e000 bus-ID: 07:00.0
chip-ID: 10ec:8126 class-ID: 0200
Device-2: Qualcomm WCN785x Wi-Fi 7 320MHz 2x2 [FastConnect 7800]
vendor: Foxconn Band Simultaneous Wireless driver: ath12k_pci v: N/A
modules: ath12k pcie: gen: 3 speed: 8 GT/s lanes: 2 bus-ID: 08:00.0
chip-ID: 17cb:1107 class-ID: 0280
IF: wlp8s0 state: up mac: <filter>
Device-1: Foxconn / Hon Hai driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-12:6 chip-ID: 0489:e10a
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.4
lmp-v: 13 status: discoverable: no pairing: no class-ID: 6c0104
Local Storage: total: 3.64 TiB used: 485.59 GiB (13.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Corsair model: MP700 PRO
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 126 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: EQFM22.3 temp: 36.9 C
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Corsair model: MP700 PRO
lanes: 4 tech: SSD serial: <filter> fw-rev: EQFM22.3 temp: 39.9 C
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 485.59 GiB (26.1%)
fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:3
used: 620 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:2
used: 485.59 GiB (26.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:3
ID-1: swap-1 type: zram size: 30.4 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 32
System Temperatures: cpu: 43.5 C mobo: 41.5 C gpu: amdgpu temp: 38.0 C
Memory: total: 32 GiB note: est. available: 30.4 GiB used: 5.77 GiB (19.0%)
Processes: 631 Power: uptime: 4m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.11 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1622 libs: 491 tools: octopi,paru Compilers:
clang: 19.1.7 gcc: 15.1.1 Shell: garuda-inxi default: fish v: 4.0.2
System install date: 2025-04-14
Last full system update: 2025-06-01
