Garuda network manager/garuda boot options/network settings and others are not opening. Cannot run anything in Garuda Assistant nor uninstall games from Garuda Gamer. Previous issue listed here is fixed, now the OS is not responding properly when trying to modify network settings, remove preinstalled games, or access those settings. GRUB delay was manually changed via console, but no other changes have been made.
LANGUAGE = (unset),
LC_ALL = (unset),
LC_ADDRESS = "en_US.UTF-8/UTF-8",
LC_NAME = "en_US.UTF-8/UTF-8",
LC_MONETARY = "en_US.UTF-8/UTF-8",
LC_PAPER = "en_US.UTF-8/UTF-8",
LC_IDENTIFICATION = "en_US.UTF-8/UTF-8",
LC_TELEPHONE = "en_US.UTF-8/UTF-8",
LC_MEASUREMENT = "en_US.UTF-8/UTF-8",
LC_TIME = "en_US.UTF-8/UTF-8",
LC_NUMERIC = "en_US.UTF-8/UTF-8",
LANG = "en_US.UTF-8"
perl: warning: Falling back to a fallback locale ("en_US.UTF-8").
Kernel: 5.19.11-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=809146c0-942a-400e-add5-2675427eefd8 rw rootflags=subvol=@
Type: Desktop Mobo: ASUSTeK model: TUF GAMING X570-PLUS (WI-FI) v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 4204
date: 02/25/2022
Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3 gen: 4
level: v3 built: 2021-22 process: TSMC n7 (7nm) family: 0x19 (25)
model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 4197 high: 4200 min/max: 2200/5619 boost: disabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4193 2: 4200
3: 4200 4: 4200 5: 4200 6: 4200 7: 4200 8: 4200 9: 4200 10: 4200 11: 4199
12: 4200 13: 4200 14: 4200 15: 4177 16: 4165 17: 4200 18: 4200 19: 4200
20: 4200 21: 4200 22: 4200 23: 4200 24: 4200 bogomips: 201601
Device-1: NVIDIA GA102 [GeForce RTX 3080 12GB] vendor: eVga.com.
driver: nvidia v: 515.76 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-08) arch: Ampere code: GAxxx process: TSMC n7
(7nm) built: 2020-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max:
gen: 4 speed: 16 GT/s bus-ID: 08:00.0 chip-ID: 10de:220a class-ID: 0300
Screen-1: 0 s-res: 4920x1920 s-dpi: 80 s-size: 1562x609mm (61.50x23.98")
s-diag: 1677mm (66")
Monitor-1: DP-1 pos: primary,top-left res: 1080x1920 hz: 60 dpi: 94
size: 293x521mm (11.54x20.51") diag: 598mm (23.53") modes: N/A
Monitor-2: DP-2 pos: primary,bottom-c res: 1920x1080 dpi: 82
Monitor-3: HDMI-0 pos: bottom-r res: 1920x1080 hz: 60 dpi: 94
size: 520x290mm (20.47x11.42") diag: 595mm (23.44") modes: N/A
OpenGL: renderer: NVIDIA GeForce RTX 3080/PCIe/SSE2 v: 4.6.0 NVIDIA
515.76 direct render: Yes
Device-1: NVIDIA GA102 High Definition Audio vendor: eVga.com.
driver: snd_hda_intel bus-ID: 5-1:2 v: kernel pcie: chip-ID: b58e:9e84
class-ID: 0300 gen: 4 speed: 16 GT/s serial: <filter> lanes: 16
bus-ID: 08:00.1 chip-ID: 10de:1aef class-ID: 0403
bus-ID: 0a:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Blue Microphones Yeti Stereo Microphone type: USB
Sound Server-1: ALSA v: k5.19.11-zen1-1-zen running: yes
Device-1: Intel Wireless-AC 9260 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:2526 class-ID: 0280
lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
IF-ID-1: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
v: 0.8 bus-ID: 3-5:2 chip-ID: 8087:0025 class-ID: e001
Local Storage: total: 2.05 TiB used: 1.2 TiB (58.5%)
model: WD10EZEX-00BN5A0 size: 931.51 GiB block-size: physical: 4096 B
rev: 1A01 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 850 PRO 256GB
type: SSD serial: <filter> rev: 3B6Q scheme: GPT
ID-1: / raw-size: 238.17 GiB size: 238.17 GiB (100.00%) used: 21.93 GiB
(9.2%) fs: btrfs dev: /dev/sdc2 maj-min: 8:34
(0.2%) fs: vfat dev: /dev/sdc1 maj-min: 8:33
ID-3: /home raw-size: 238.17 GiB size: 238.17 GiB (100.00%) used: 21.93
GiB (9.2%) fs: btrfs dev: /dev/sdc2 maj-min: 8:34
ID-4: /var/log raw-size: 238.17 GiB size: 238.17 GiB (100.00%) used: 21.93
ID-5: /var/tmp raw-size: 238.17 GiB size: 238.17 GiB (100.00%) used: 21.93
ID-1: swap-1 type: zram size: 62.71 GiB used: 1.8 MiB (0.0%)
System Temperatures: cpu: 44.9 C mobo: N/A gpu: nvidia temp: 34 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 32%
Processes: 433 Uptime: 16m wakeups: 0 Memory: 62.71 GiB used: 5.5 GiB
(8.8%) Init: systemd v: 251 default: graphical tool: systemctl Compilers:
gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1864 libs: 515
tools: octopi,pamac,paru Shell: Bash v: 5.1.16 running-in: kitty
inxi: 3.3.21
Garuda (2.6.8-1):
System install date: 2022-09-27
Last full system update: 2022-09-28
@MANTISxB was the one controlling my previous post and handling my issues. I'm way less linux-literate as he is so he will help me to understand some of the replies.
