Hi folks, Just installed the above earlier today and totally impressed to say the least. Works perfect out of the box.
The only draw back is there is too many different ISO, but I have tried most of them!
Would you mind posting your system specs. It's great you're being the distro test pilot. If we know your hardware works fine then we have a yardstick to compare to when someone posts a major issue.
If you'd rather not, that's fine too.
Thanks for giving everything such a thorough testing out.
Sure no problem, below are my system specs inside of VB running Mate.
System: Host: sam-virtualbox Kernel: 5.9.1-zen2-1-zen x86_64 bits: 64 compiler: N/A Desktop: MATE 1.24.1
Distro: Garuda Linux
Machine: Type: Virtualbox System: innotek product: VirtualBox v: 1.2 serial: <superuser/root required>
Mobo: Oracle model: VirtualBox v: 1.2 serial: <superuser/root required> BIOS: innotek v: VirtualBox
date: 12/01/2006
Battery: ID-1: BAT0 charge: 50.0 Wh condition: 50.0/50.0 Wh (100%) model: innotek 1 status: Full
CPU: Info: Dual Core model: Intel Core i5 M 480 bits: 64 type: MCP arch: Nehalem rev: 5 L2 cache: 3072 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 10666
Speed: 2667 MHz min/max: N/A Core speeds (MHz): 1: 2667 2: 2667
Graphics: Device-1: InnoTek Systemberatung VirtualBox Graphics Adapter vendor: VMware driver: vboxvideo v: kernel
bus ID: 00:02.0
Display: x11 server: X.Org 1.20.9 driver: modesetting resolution: 1360x768~60Hz
Audio: Device-1: Intel 82801AA AC97 Audio vendor: Dell driver: snd_intel8x0 v: kernel bus ID: 00:05.0
Sound Server: ALSA v: k5.9.1-zen2-1-zen
Network: Device-1: Intel 82540EM Gigabit Ethernet driver: e1000 v: kernel port: d020 bus ID: 00:03.0
IF: enp0s3 state: up speed: 1000 Mbps duplex: full mac: 08:00:27:1a:3c:36
Device-2: Intel 82371AB/EB/MB PIIX4 ACPI type: network bridge driver: piix4_smbus v: N/A port: d200
bus ID: 00:07.0
Drives: Local Storage: total: 25.00 GiB used: 85.81 GiB (343.2%)
ID-1: /dev/sda vendor: VirtualBox model: VBOX HARDDISK size: 25.00 GiB
Partition: ID-1: / size: 24.99 GiB used: 7.30 GiB (29.2%) fs: btrfs dev: /dev/sda1
ID-2: /home size: 24.99 GiB used: 7.30 GiB (29.2%) fs: btrfs dev: /dev/sda1
ID-3: /var/log size: 24.99 GiB used: 7.30 GiB (29.2%) fs: btrfs dev: /dev/sda1
Swap: ID-1: swap-1 type: zram size: 491.6 MiB used: 0 KiB (0.0%) dev: /dev/zram0
ID-2: swap-2 type: zram size: 491.6 MiB used: 0 KiB (0.0%) dev: /dev/zram1
Sensors: Message: No sensors data was found. Is sensors configured?
Info: Processes: 182 Uptime: 1m Memory: 3.84 GiB used: 570.4 MiB (14.5%) Init: systemd Compilers: gcc: 10.2.0
Packages: 1078 Shell: Zsh v: 5.8 inxi: 3.1.06
Here are my specs outside of VB.
inxi -Fx
System: Host: arch Kernel: 5.4.72-1-lts x86_64 bits: 64 compiler: gcc v: 10.2.0 Desktop: Xfce 4.14.2
Distro: Arch Linux
Machine: Type: Laptop System: TOSHIBA product: Satellite L650 v: PSK1E1-1234567 serial: <superuser/root required>
Mobo: TOSHIBA model: Portable PC serial: <superuser/root required> BIOS: INSYDE v: 2.40 date: 11/09/2011
Battery: ID-1: BAT0 charge: 35.8 Wh condition: 35.8/47.5 Wh (75%) model: PA381 status: Full
CPU: Info: Dual Core model: Intel Core i5 M 480 bits: 64 type: MT MCP arch: Nehalem rev: 5 L2 cache: 3072 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 21332
Speed: 1467 MHz min/max: 1199/2667 MHz Core speeds (MHz): 1: 1467 2: 1467 3: 1467 4: 1467
Graphics: Device-1: Intel Core Processor Integrated Graphics vendor: Toshiba driver: i915 v: kernel bus ID: 00:02.0
Display: x11 server: X.Org 1.20.9 driver: modesetting unloaded: vesa resolution: 1366x768~60Hz
Audio: Device-1: Intel 5 Series/3400 Series High Definition Audio vendor: Toshiba driver: snd_hda_intel
v: kernel bus ID: 00:1b.0
Sound Server: ALSA v: k5.4.72-1-lts
Network: Device-1: Qualcomm Atheros AR8152 v1.1 Fast Ethernet vendor: Toshiba driver: atl1c v: 1.0.1.1-NAPI
port: 3000 bus ID: 01:00.0
IF: enp1s0 state: up speed: 100 Mbps duplex: full mac: 00:26:6c:98:5a:36
Device-2: Realtek RTL8188CE 802.11b/g/n WiFi Adapter driver: rtl8192ce v: kernel port: 2000
bus ID: 02:00.0
IF: wlp2s0 state: down mac: b2:50:6a:9d:3f:39
IF-ID-1: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
Drives: Local Storage: total: 232.89 GiB used: 89.60 GiB (38.5%)
ID-1: /dev/sda vendor: Samsung model: SSD 860 EVO 250GB size: 232.89 GiB
Partition: ID-1: / size: 37.51 GiB used: 14.17 GiB (37.8%) fs: ext4 dev: /dev/sda1
ID-2: /home size: 160.03 GiB used: 75.43 GiB (47.1%) fs: ext4 dev: /dev/sda2
Swap: ID-1: swap-1 type: zram size: 485.1 MiB used: 0 KiB (0.0%) dev: /dev/zram0
ID-2: swap-2 type: zram size: 485.1 MiB used: 0 KiB (0.0%) dev: /dev/zram1
ID-3: swap-3 type: zram size: 485.1 MiB used: 0 KiB (0.0%) dev: /dev/zram2
ID-4: swap-4 type: zram size: 485.1 MiB used: 0 KiB (0.0%) dev: /dev/zram3
Sensors: System Temperatures: cpu: 57.0 C mobo: N/A
Info: Processes: 167 Uptime: 1h 33m Memory: 7.58 GiB used: 1.08 GiB (14.3%) Init: systemd Compilers:
gcc: 10.2.0 Packages: 959 Shell: Bash v: 5.0.18 inxi: 3.1.06
Thank you.
The same here. Here is my data.
Desktop: MATE 1.24.1 Distro: Garuda Linux
Type: Laptop System: LENOVO product: 20AV005GMD v: ThinkPad L540
serial:
Mobo: LENOVO model: 20AV005GMD v: SDK0E50510 Pro serial:
UEFI [Legacy]: LENOVO v: J4ET86WW(1.86) date: 04/13/2016
ID-1: BAT0 charge: 8.4 Wh condition: 32.2/47.5 Wh (68%) model: LGC 45N1161
status: Discharging
Info: Dual Core model: Intel Core i5-4300M bits: 64 type: MT MCP
arch: Haswell rev: 3 L2 cache: 3072 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
bogomips: 20753
Speed: 2595 MHz min/max: 800/3300 MHz Core speeds (MHz): 1: 2416 2: 2596
3: 2594 4: 2595
Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: Lenovo
Device-2: Realtek Integrated Camera type: USB driver: uvcvideo
bus ID: 2-12:5
Display: x11 server: X.Org 1.20.9 driver: intel unloaded: modesetting
vendor: Lenovo driver: snd_hda_intel v: kernel bus ID: 00:03.0
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus ID: 00:1b.0
Device-1: Intel Ethernet I217-V vendor: Lenovo driver: e1000e v: kernel
port: 5080 bus ID: 00:19.0
IF: enp0s25 state: up speed: 1000 Mbps duplex: full mac:
Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel port: efa0
bus ID: 02:00.0
Local Storage: total: 223.57 GiB used: 8.39 GiB (3.8%)
ID-1: /dev/sda vendor: Kingston model: SV300S37A240G size: 223.57 GiB
ID-1: / size: 223.57 GiB used: 8.39 GiB (3.8%) fs: btrfs dev: /dev/sda1
ID-2: /home size: 223.57 GiB used: 8.39 GiB (3.8%) fs: btrfs
dev: /dev/sda1
ID-3: /var/log size: 223.57 GiB used: 8.39 GiB (3.8%) fs: btrfs
dev: /dev/sda1
ID-1: swap-1 type: zram size: 983.4 MiB used: 0 KiB (0.0%) dev: /dev/zram0
ID-2: swap-2 type: zram size: 983.4 MiB used: 0 KiB (0.0%) dev: /dev/zram1
ID-3: swap-3 type: zram size: 983.4 MiB used: 0 KiB (0.0%) dev: /dev/zram2
ID-4: swap-4 type: zram size: 983.4 MiB used: 0 KiB (0.0%) dev: /dev/zram3
System Temperatures: cpu: 41.0 C mobo: 22.0 C
Fan Speeds (RPM): cpu: 0
Processes: 231 Uptime: N/A Memory: 15.37 GiB used: 729.7 MiB (4.6%)
Init: systemd Compilers: gcc: 10.2.0 clang: 10.0.1 Packages: 1124
