Garuda-inxi
Kernel: 6.2.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=114ea1dc-ae27-4a10-899a-761ac1fd9cc6 rw [email protected]
Desktop: KDE Plasma v: 5.27.3 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Hewlett-Packard product: HP ProBook 4510s v: F.14
serial: Chassis: type: 10 serial:
Mobo: Hewlett-Packard model: 3072 v: KBC Version 24.0E
serial: BIOS: Hewlett-Packard v: 68PZI Ver. F.14
date: 12/30/2009
ID-1: BAT0 charge: 0% condition: 45.8/47.5 Wh (96.4%) volts: 10.8 min: 10.8
model: Hewlett-Packard Primary type: Li-ion serial:
status: not charging
Info: model: Intel Core2 Duo P8700 bits: 64 type: MCP arch: Penryn level: v1
built: 2008 process: Intel 45nm family: 6 model-id: 0x17 (23)
stepping: 0xA (10) microcode: 0xA0B
Topology: cpus: 1x cores: 2 smt: cache: L1: 128 KiB
desc: d-2x32 KiB; i-2x32 KiB L2: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 798 min/max: 800/2534 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 798 2: 798
bogomips: 10108
Flags: ht lm nx pae sse sse2 sse3 sse4_1 ssse3 vmx
Device-1: Intel Mobile 4 Series Integrated Graphics vendor: Hewlett-Packard
driver: i915 v: kernel arch: Gen-5 process: Intel 45nm built: 2008 ports:
active: LVDS-1 empty: DP-1, DP-2, HDMI-A-1, SVIDEO-1, VGA-1
bus-ID: 00:02.0 chip-ID: 8086:2a42 class-ID: 0300
s-diag: 414mm (16.31")
Monitor-1: LVDS-1 model: AU Optronics 0x23ec built: 2009 res: 1366x768
hz: 60 dpi: 101 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1366x768
API: OpenGL v: 2.1 Mesa 22.3.6 renderer: Mesa Mobile Intel GM45 Express
(CTG) direct-render: Yes
Device-1: Intel 82801I HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:293e
Sound API: ALSA v: k6.2.7-zen1-1-zen running: yes
Device-1: Marvell 88E8072 PCI-E Gigabit Ethernet vendor: Hewlett-Packard
driver: sky2 v: 1.30 pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000
bus-ID: 84:00.0 chip-ID: 11ab:436c class-ID: 0200
IF: ens5 state: down mac:
Device-2: Ralink MT7601U Wireless Adapter type: USB driver: mt7601u
bus-ID: 3-2:2 chip-ID: 148f:7601 class-ID: 0000 serial:
IF: wlp0s29f7u2 state: up mac:
Local Storage: total: 149.05 GiB used: 3.94 GiB (2.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST9160412AS
size: 149.05 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 7200 serial: rev: HPM1 scheme: MBR
ID-1: / raw-size: 33.2 GiB size: 33.2 GiB (100.00%) used: 3.94 GiB (11.9%)
fs: btrfs dev: /dev/sda4 maj-min: 8:4
ID-2: /home raw-size: 33.2 GiB size: 33.2 GiB (100.00%)
used: 3.94 GiB (11.9%) fs: btrfs dev: /dev/sda4 maj-min: 8:4
ID-3: /var/log raw-size: 33.2 GiB size: 33.2 GiB (100.00%)
ID-4: /var/tmp raw-size: 33.2 GiB size: 33.2 GiB (100.00%)
ID-1: swap-1 type: zram size: 3.73 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 56.0 C mobo: N/A
Processes: 176 Uptime: 35m wakeups: 5 Memory: 3.73 GiB
used: 1.83 GiB (49.0%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1144
libs: 306 tools: octopi,paru Shell: fish v: 3.6.0 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.25
Garuda (2.6.15-1):
System install date: 2023-05-19
Last full system update: 2023-05-19
Is partially upgraded: Yes
Windows dual boot:
Failed
i have just installed alactritty and encounter this issue. i haven't changed anything in config, and this problem is not happening with konsole (i have a dual boot system)
please help i am a newbie
