Garuda login loop problem
Hello Garuda users.
I am just update my OS and after some time trying to open but after boot in login screen I am entered the password but it again boot and suddenly it comes inlogin screen it happened again again and again I think this problem is going to :infinity: Time
How to sloved my problem and I can't reinstall the is
Because I don't have bootable and any other devices or accessories
Please guy help me
Have you tried simply rebooting your device via holding down your power button till your computer turns off? If that doesn't help can you change TTY and see if you can login there?
It doesn't not work
Give another solution
Use last working snapshot or use live ISO and chroot your system and update again.
